Home » Archived » Test and Performance Tools Platform (TPTP) » Cannot locate menu item
Re: Cannot locate menu item [message #121700 is a reply to message #117318] |
Fri, 01 February 2008 09:44 |
Pushparaj Messages: 62 Registered: July 2009 |
Member |
Hi Paul,
As per the description I has added the following entry in the widgetReg.xml
<class name = "org.eclipse.swt.widgets.Text" matchThreshold = "1.0">
<method name = "getData" weight = "1.0">
<argument value = "menu.new"/>
</method>
</class>
<argument value = "menu.delete"/>
</method>
</class>
I has changed my pop-up menu's code in pereference dialog like ,
public void handleEvent(Event event) {
Menu menu = new Menu(_dialog.getShell(), SWT.POP_UP);
MenuItem newItem = new MenuItem(menu, SWT.PUSH);
newItem.setText("New");
newItem.setData("menu.new", "MyNew");
newItem.addSelectionListener(new PopUpListener());
MenuItem deleteItem = new MenuItem(menu, SWT.PUSH);
deleteItem.setText("Delete");
deleteItem.setData("menu.delete", "MyDelete");
deleteItem.addSelectionListener(new PopUpListener());
menu.setLocation(event.x, event.y);
menu.setVisible(true);
then I has recorded same use case. But my AGR script is looks like
same. As per my understanding widget id should be save like this,
<command descriptive="New" type="select"
resolverId="org.eclipse.tptp.test.auto.gui.nontrivial"
contextId="popup/shell/org.eclipse.swt.widgets.Tree#1"
widgetId="{{MyNew}}-{{1.0}}"/>
But AGR script is saved like this,
widgetId="{{New}}-{{1.0}}"/>
I am not able continue my work because of this issue. Please help me ro
resolve this.
Pushparaj.
Re: Cannot locate menu item [message #121713 is a reply to message #121700] |
Fri, 01 February 2008 11:50 |
Originally posted by: any.swc.rwth-aachen.de
I think the class name should be org.eclipse.swt.widgets.MenuItem instead of
org.eclipse.swt.widgets.Text, if you want to resolve MenuItems.
Alexander
"Pushparaj" <pushparaj_94@yahoo.com> schrieb im Newsbeitrag
news:d36084abb2a5330e20bd3bf6bffef72c$1@www.eclipse.org...
> Hi Paul,
> widgetReg.xml
> </method>
> </class>
> </method>
> </class>
> resolve this.
> Pushparaj.
Re: Cannot locate menu item [message #121810 is a reply to message #121700] |
Sat, 02 February 2008 08:51 |
Jimmy Jin Messages: 32 Registered: July 2009 |
Member |
Hi, Pushparaj,
I think the way you modify the widgetReg.xml is incorrect first.
As I understand, the "value" attribute of <argument> element should be
the key of the getData()/setData() method.
So if your menuItem is set as:
newItem.setData("menu.key", "MyNew");
deleteItem.setData("menu.key", "MyDelete");
Then you can have the following lines in widgetReg.xml, for using the
"menu.key" key's value to identify the menu item.
<class name = "org.eclipse.swt.widgets.MenuItem" matchThreshold = "1.0">
<argument value = "menu.key"/>
</method>
</class>
Then your recorded script will looks like
widgetId="MyNew"/>
Your current recorded script are actually not resolved using the
widgetReg.xml file. It is resolved by
org.eclipse.tptp.test.auto.gui.internal.resolvers.NonTrivial WidgetResolver.
Only the
org.eclipse.tptp.test.auto.gui.internal.resolvers.AdaptiveWi dgetResolver
uses the widgetReg.xml file.
Jimmy Jin
Pushparaj wrote:
> Hi Paul,
> </method>
> </class>
> </method>
> </class>
> resolve this.
> Pushparaj.
Re: Cannot locate menu item [message #121866 is a reply to message #121849] |
Sun, 03 February 2008 14:47 |
Member |
Hi, Pushparaj,
I looked at the code you included in your message again, and I found
something strange in your code. You have the menu created in a
handleEvent method. What is this listener listening for? The mouse
right-click? If it is the case, I think, even you can record the script,
you still cannot playback it.
The reason is that the way MacroObjectLocator uses for finding out the
popup menu item is by using the Control.getMenu() method on all the
controls on one Shell to get all the popup menus and then try to find
out if any of them matches the desired one. Since your menu is
dynamically created, maybe when the command is running, the menu hasn't
been created, so it cannot be found. I'm not sure whether it can work,
if you simulate a mouse click to make the menu created before select the
menu. Or, if possible, you can change the mechanism to have the menu
created statically and set to certain Control on the dialog.
Maybe if you provide the script you recorded after the latest change to
the widgetReg.xml, I can provide some more advise.
Jimmy Jin
Pushparaj wrote:
> Hi Jimmy Jin,
> As per your reply I has changed my widgetReg.xml. Now the recorded
> script is proper. but while running the script i am getting the same error.
> Pushparaj.
Re: Cannot locate menu item [message #122585 is a reply to message #122143] |
Sun, 10 February 2008 11:40 |
Member |
Hello, Pushparaj,
After reading the script you recorded, I think I know your scenario more
.. Here are some suggestions from me, which I think I will take if I do
it by myself.
1. When dynamically creating the popup menu, it MUST be set to certain
Control, such as the Tree. It is for making sure that when playing back,
AGR can use the getMenu method to locate the menu. So I may add the
following lines into the handleEvent method.
Tree myTree = (Tree) event.widget;
myTree.setMenu(menu);
2. The mouse right-click event must be simulated and notify all the
listeners of the event on the Tree, so that the menu gets created. There
are 2 ways, in my mind, can achieve this.
a. Add a Verification Point before the popup menu selection command,
and in the Verification Point, find out the Tree and send it a proper
event with notifyListener method (or just call the handleEvent method
directly).
b. Add a Position Based command before popup menu selection command.
I'm not sure if this can help, since I haven't encountered this kind of
case so far.
Jimmy Jin
Pushparaj wrote:
> Hi Jimmy Jin,
> Yes. I am creating menus in mouse right-click.
> As per my requirement i should create menu itemes at
> runtime(dynamically). So Pls give me some other solutions
> <macro version="1.0">
> <shell descriptive="OpenClovis IDE - MyTestSuite1 - Eclipse SDK"
> id="org.eclipse.ui.internal.WorkbenchWindow" return-code="-1">
> <command descriptive="TestModel" type="item-select"
> resolverId="org.eclipse.tptp.test.auto.gui.adaptive"
> contextId="view/com.clovis.cw.workspace.clovisWorkspaceView "
> widgetId="{{/}}-{{1.0}}">
> <item path="{{/TestModel}}-{{1.0}}"
> resolverId="org.eclipse.tptp.test.auto.gui.adaptive"/>
> </command>
> <command type="focus"
> widgetId="org.eclipse.swt.widgets.Composite#1"/>
> <command descriptive="AMF Configuration... Ctrl+Shift+F"
> type="select" resolverId="org.eclipse.tptp.test.auto.gui.nontrivial"
> contextId="menus" widgetId="{{Clovis-AMF
> Configuration...&#x9;Ctrl+Shift+F}}-{{1.0}}"/>
> <shell descriptive="TestModel - AMF Configuration"
> id="com.clovis.cw.editor.ca.dialog.NodeProfileDialog" return-code="0">
> <command descriptive="AMS Configuration" type="item-expand"
> contextId="shell" widgetId="org.eclipse.swt.widgets.Tree#1" value="true">
> <item path="{{AMFNode}}-{{1.0}}"
> </command>
> <command descriptive="Service Group List" type="item-select"
> contextId="shell" widgetId="org.eclipse.swt.widgets.Tree#1">
> <item path="{{Service Group List}}-{{1.0}}"
> </command>
> widgetId="{{AMFNew}}-{{1.0}}"/>
> <command descriptive="SAFComponent0SG" type="choice-select"
> contextId="shell" widgetId="org.eclipse.swt.custom.CCombo#1"
> choiceId="item#0"/>
> <command descriptive="OK" type="select"
> resolverId="org.eclipse.tptp.test.auto.gui.adaptive" contextId="shell"
> widgetId="{{0}}-{{1.0}}"/>
> </shell>
> </shell>
> </macro>
> Pushparaj
Current Time: Sat Apr 27 00:27:56 GMT 2024
Powered by FUDForum. Page generated in 0.03861 seconds
