Re: crosstab multiple grand totals / summary [message #930792 is a reply to message #930157] |
Tue, 02 October 2012 16:48 |
Louisa
Can you take the following code and generate the report? Next add the grid you want and post the report back.
package DEAPI;
import java.io.IOException;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.item.crosstab.core.ICrosstabConstants;
import org.eclipse.birt.report.item.crosstab.core.de.CrosstabCellHandle;
import org.eclipse.birt.report.item.crosstab.core.de.CrosstabReportItemHandle;
import org.eclipse.birt.report.item.crosstab.core.de.DimensionViewHandle;
import org.eclipse.birt.report.item.crosstab.core.de.LevelViewHandle;
import org.eclipse.birt.report.item.crosstab.core.de.MeasureViewHandle;
import org.eclipse.birt.report.item.crosstab.core.util.CrosstabExtendedItemFactory;
import org.eclipse.birt.report.model.api.ComputedColumnHandle;
import org.eclipse.birt.report.model.api.DataItemHandle;
import org.eclipse.birt.report.model.api.DataSetHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.DesignElementHandle;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.ExtendedItemHandle;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.LabelHandle;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.ReportItemHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.activity.SemanticException;
import org.eclipse.birt.report.model.api.elements.DesignChoiceConstants;
import org.eclipse.birt.report.model.api.elements.structures.ComputedColumn;
import org.eclipse.birt.report.model.api.extension.IReportItem;
import org.eclipse.birt.report.model.api.olap.MeasureGroupHandle;
import org.eclipse.birt.report.model.api.olap.MeasureHandle;
import org.eclipse.birt.report.model.api.olap.TabularCubeHandle;
import org.eclipse.birt.report.model.api.olap.TabularDimensionHandle;
import org.eclipse.birt.report.model.api.olap.TabularHierarchyHandle;
import org.eclipse.birt.report.model.api.olap.TabularLevelHandle;
import org.eclipse.birt.report.model.elements.interfaces.ICubeModel;
import org.eclipse.birt.report.model.elements.olap.TabularMeasure;
import org.eclipse.birt.report.model.api.olap.TabularMeasureHandle;
import com.ibm.icu.util.ULocale;
* Simple BIRT Design Engine API (DEAPI) demo.
public class CreateDataCube
ReportDesignHandle designHandle = null;
ElementFactory designFactory = null;
StructureFactory structFactory = null;
public static void main( String[] args )
try
CreateDataCube de = new CreateDataCube();
de.buildReport();
catch ( IOException e )
e.printStackTrace();
catch ( SemanticException e )
void buildDataSource( ) throws SemanticException
OdaDataSourceHandle dsHandle = designFactory.newOdaDataSource(
"Data Source", "org.eclipse.birt.report.data.oda.jdbc" );
dsHandle.setProperty( "odaDriverClass",
"org.eclipse.birt.report.data.oda.sampledb.Driver" );
dsHandle.setProperty( "odaURL", "jdbc:classicmodels:sampledb" );
dsHandle.setProperty( "odaUser", "ClassicModels" );
dsHandle.setProperty( "odaPassword", "" );
designHandle.getDataSources( ).add( dsHandle );
void buildDataSet( ) throws SemanticException
OdaDataSetHandle dsHandle = designFactory.newOdaDataSet( "ds",
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
dsHandle.setDataSource( "Data Source" );
String qry = "Select * from customers";
dsHandle.setQueryText( qry );
designHandle.getDataSets( ).add( dsHandle );
void buidCube() throws SemanticException
TabularCubeHandle cubeHandle = designHandle.getElementFactory( )
.newTabularCube( "MyCube" );
cubeHandle.setDataSet((DataSetHandle)designHandle.getDataSets().get(0));
designHandle.getCubes( ).add( cubeHandle );
// measure group
MeasureGroupHandle measureGroupHandle = designHandle
.getElementFactory( ).newTabularMeasureGroup(
"testMeasureGroup" );
cubeHandle.setProperty( ICubeModel.MEASURE_GROUPS_PROP,
measureGroupHandle );
// measure
measureGroupHandle.add( MeasureGroupHandle.MEASURES_PROP, designFactory.newTabularMeasure( null ) );
TabularMeasureHandle measure = (TabularMeasureHandle) measureGroupHandle.getContent(MeasureGroupHandle.MEASURES_PROP, 0 );
measure.setName( "CREDITLIMIT" );
measure.setMeasureExpression( "dataSetRow['CREDITLIMIT']" );
measure.setFunction( DesignChoiceConstants.MEASURE_FUNCTION_SUM );
measure.setCalculated( false );
measure.setDataType( DesignChoiceConstants.COLUMN_DATA_TYPE_FLOAT );
TabularMeasure mhcopy = (TabularMeasure) measure.copy();
// dimension
TabularDimensionHandle dimension = designFactory.newTabularDimension( null );
cubeHandle.add(TabularCubeHandle.DIMENSIONS_PROP, dimension );
dimension.setTimeType( false );
//dimension.setDefaultHierarchy( factory
// .newTabularHierarchy( "testDefaultHierarchy" ) );
// hierarchy
dimension.add( TabularDimensionHandle.HIERARCHIES_PROP, designFactory.newTabularHierarchy( null ) );
TabularHierarchyHandle hierarchy = (TabularHierarchyHandle) dimension.getContent( TabularDimensionHandle.HIERARCHIES_PROP, 0 );
//hierarchy.setName( namePrix + hierarchy.getName( ) );
hierarchy.setDataSet( (DataSetHandle)designHandle.getDataSets().get(0) );
// level
hierarchy.add( TabularHierarchyHandle.LEVELS_PROP, designFactory.newTabularLevel( dimension, null ) );
TabularLevelHandle level = (TabularLevelHandle) hierarchy.getContent(TabularHierarchyHandle.LEVELS_PROP, 0 );
level.setName( "testlevel" );
level.setColumnName( "CUSTOMERNAME" );
level.setDataType( DesignChoiceConstants.COLUMN_DATA_TYPE_STRING );
//level2
TabularLevelHandle level2 = (TabularLevelHandle) hierarchy.getContent(TabularHierarchyHandle.LEVELS_PROP, 1 );
level2.setName( "testlevel2" );
level2.setColumnName( "CONTACTLASTNAME" );
level2.setDataType( DesignChoiceConstants.COLUMN_DATA_TYPE_STRING );
level.setDateTimeLevelType( DesignChoiceConstants.DATE_TIME_LEVEL_TYPE_QUARTER );
level.setDateTimeFormat( "mm" ); //$NON-NLS-1$
// level.setInterval( DesignChoiceConstants.INTERVAL_MONTH );
level.setIntervalRange( 5 );
level.setIntervalBase( valuePrix + level.getIntervalBase( ) );
ExtendedItemHandle xtab = CrosstabExtendedItemFactory.createCrosstabReportItem(designHandle, cubeHandle, "MyCrosstab" );
designHandle.getBody().add(xtab);
IReportItem reportItem = xtab.getReportItem( );
CrosstabReportItemHandle xtabHandle = (CrosstabReportItemHandle) reportItem;
//ICrosstabConstants.COLUMN_AXIS_TYPE
//ICrosstabConstants.ROW_AXIS_TYPE
//DimensionViewHandle dvh = xtabHandle.insertDimension(dimension, ICrosstabConstants.COLUMN_AXIS_TYPE, 0);
DimensionViewHandle dvh = xtabHandle.insertDimension(dimension, ICrosstabConstants.ROW_AXIS_TYPE, 0);
//insert level 1
LevelViewHandle levelViewHandle =dvh.insertLevel(level, 0);
CrosstabCellHandle cellHandle = levelViewHandle.getCell( );
//insert level 2
LevelViewHandle levelViewHandle2 =dvh.insertLevel(level2, 1);
CrosstabCellHandle cellHandle2 = levelViewHandle2.getCell( );
DesignElementHandle eii = xtabHandle.getModelHandle( );
//level one computed column
ComputedColumn bindingColumn = StructureFactory.newComputedColumn( eii, level.getName( ) );
ComputedColumnHandle bindingHandle = ((ReportItemHandle) eii).addColumnBinding( bindingColumn,false );
bindingColumn.setDataType( level.getDataType( ) );
String exp = "dimension['" + dimension.getName()+"']['"+level.getName()+"']";
bindingColumn.setExpression( exp);
//level two computed column
ComputedColumn bindingColumn2 = StructureFactory.newComputedColumn( eii, level2.getName( ) );
ComputedColumnHandle bindingHandle2 = ((ReportItemHandle) eii).addColumnBinding( bindingColumn2,false );
bindingColumn.setDataType( level2.getDataType( ) );
String exp2 = "dimension['" + dimension.getName()+"']['"+level2.getName()+"']";
bindingColumn2.setExpression( exp2);
//add data element for level 1
DataItemHandle dataHandle = designFactory.newDataItem( level.getName( ) );
dataHandle.setResultSetColumn( bindingHandle.getName( ) );
cellHandle.addContent( dataHandle );
//add data element for level 2
DataItemHandle dataHandle2 = designFactory.newDataItem( level2.getName( ) );
dataHandle2.setResultSetColumn( bindingHandle2.getName( ) );
cellHandle2.addContent( dataHandle2 );
MeasureViewHandle mvh = xtabHandle.insertMeasure(measure, 0);
//((DataItemHandle)mvh.getCell().getContents().get(0)).setProperty("style", "mydata");
//mvh.addHeader( );
MeasureViewHandle tst = (MeasureViewHandle)xtabHandle.getAllMeasures().get(0);
MeasureViewHandle tst2 = (MeasureViewHandle) tst.copy();
//System.out.println(tst2.getDataType());
LabelHandle labelHandle = designFactory.newLabel( null );
labelHandle.setText( measure.getName() );
mvh.getHeader( ).addContent( labelHandle );
void buildReport() throws IOException, SemanticException
DesignConfig config = new DesignConfig( );
config.setBIRTHome("C:/birt/birt-runtime-2_6_1/birt-runtime-2_6_1/ReportEngine");
IDesignEngine engine = null;
try{
Platform.startup( config );
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
.createFactoryObject( IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
engine = factory.createDesignEngine( config );
}catch( Exception ex){
ex.printStackTrace();
SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
try{
//open a design or a template
designHandle = session.createDesign();
designFactory = designHandle.getElementFactory( );
buildDataSource();
buildDataSet();
buidCube();
// Save the design and close it.
designHandle.saveAs("output/desample/cubetest.rptdesign" );
designHandle.close( );
Platform.shutdown();
System.out.println("Finished");
}catch (Exception e){
Jason
FUDForum. Page generated in 0.03342 seconds
