[Net4j.util 4.0.0] Set driver type in cdo-server.xml throws ClassCastException [message #881877] |
Tue, 05 June 2012 12:12 |
Robert Maier Messages: 1 Registered: June 2012 |
in method ReflectUtil.instantiate() throws exception: Cannot cast Integer to int.
if is set the parameter "driverType" in the dataSource inside the cdo-server.xml.
To change the condition in line 446 in ReflectUtil to:
else if (type.isAssignableFrom(Integer.class) || type.isAssignableFrom(int.class))
value = Integer.parseInt(str);
solves the problem.
Can we get support for this bug?
Robert
[Updated on: Tue, 05 June 2012 12:14] Report message to a moderator
Re: [Net4j.util 4.0.0] Set driver type in cdo-server.xml throws ClassCastException [message #884469 is a reply to message #881899] |
Mon, 11 June 2012 06:21 |
Hi Eike and Robert,
i fixed this for 4.1 and Robert should have the patch at hand already.
There are some other issues regarding the DB2-Adapter i would like to
discuss before raising issues but hadn't time to do so.
@Eike Maybe we can find some time at Democamp/Kassel.
Grettings
Jörg
On 06/05/2012 03:04 PM, Eike Stepper wrote:
> Hi Robert,
> Please submit a bugzilla against EMF|cdo.net4j and ideally provide the
> complete stack trace and your proposal of a fix.
> Please note that we stopped CDO 4.0 maintenance, now that 4.1 is almost
> released and all our current efforts go into the release.
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
> Am 05.06.2012 14:12, schrieb Robert Maier:
>> Integer to int.
>> cdo-server.xml.
>> // patch: || type.isAssignableFrom(int.class) added value =
>> solves the problem.
>> Thanks
>> Robert
Re: [Net4j.util 4.0.0] Set driver type in cdo-server.xml throws ClassCastException [message #884476 is a reply to message #884469] |
Mon, 11 June 2012 06:31 |
Am 11.06.2012 08:21, schrieb Joerg Pacher:
> Hi Eike and Robert,
Great! Please don't forget to attach the patch to the bugzilla Robert wants to submit ;-)
> There are some other issues regarding the DB2-Adapter i would like to discuss before raising issues but hadn't time to
> do so.
We can certainly try it ;-)
Cheers
/Eike
> Grettings
> Jörg
>> Hi Robert,
>> Cheers
>> /Eike
>>> Integer to int.
>>> cdo-server.xml.
>>> solves the problem.
>>> Thanks
>>> Robert
Cheers
/Eike
Re: [Net4j.util 4.0.0] Set driver type in cdo-server.xml throws ClassCastException [message #886239 is a reply to message #884476] |
Thu, 14 June 2012 14:06 |
Bugzilla entry is https://bugs.eclipse.org/bugs/show_bug.cgi?id=382491
>> Hi Eike and Robert,
> wants to submit ;-)
> Cheers
> /Eike
>> Grettings
>> Jörg
>>> Hi Robert,
>>> Cheers
>>> /Eike
>>>> Integer to int.
>>>> cdo-server.xml.
>>>> solves the problem.
>>>> Thanks
>>>> Robert
FUDForum. Page generated in 0.05894 seconds
