Home » Eclipse Projects » JFace » What are the alternative solutions for DecorationOverlayIcon when using org.ecli
What are the alternative solutions for DecorationOverlayIcon when using org.ecli [message #10622] Sun, 31 May 2009 10:07 Go to next message
I am working on two different version of the products. The current
version of the product consumes org.eclipse.jface.3.4.2.M2 which contains
DecorationOverlayIcon. However, the older version of the product consumes
org.eclipse.jface.3.4.2.M2 which does not contain this class.
I need to make both versions of the product have the same look and feel
for the overlay images. I would like to consult with the team here that
what are the alternative solutions for DecorationOverlayIcon when using
org.eclipse.jface.3.4.2.M2?
CORRECTION on the version number. [message #10658 is a reply to message #10622] Sun, 31 May 2009 10:09 Go to previous messageGo to next message
org.eclipse.jface.3.2.2.M2 which does not contain this class.
org.eclipse.jface.3.2.2.M2?
Re: CORRECTION on the version number. [message #10832 is a reply to message #10658] Thu, 04 June 2009 09:18 Go to previous message
Hi Florence,
I would copy DecorationOverlayIcon.java so that it is available in both
versions of your product. Of course, by doing this you are probably creating
derivative work and need to be make sure you comply with the licensing...
Boris
"Florence " <florencelu@yahoo.com> wrote in message
news:7f6571560a0de966c99ad07dee317c91$1@www.eclipse.org...
>I am working on two different version of the products. The current version
> Thanks
Previous Topic:Invoking WIzardNewFileCreator
Next Topic:Decorators
Current Time: Thu Sep 25 14:51:53 EDT 2025
Powered by FUDForum. Page generated in 0.03835 seconds
