Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Hibernate 4.1 has Trouble with Booleans
[Teneo] Hibernate 4.1 has Trouble with Booleans [message #881299] |
Mon, 04 June 2012 09:57 |
Flavio Donze Messages: 211 Registered: July 2009 Location: Switzerland |
Hi Martin
I trying to update to Teneo 2.0.0 and Hibernate 4.1. Using Eclipse 3.7.2, EMF 2.7.2.
I came acrosse a few problems and with this one I'm stuck. Getting a lot of errors durring startup:
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - HHH000388: Unsuccessful: create table [accesscontrolentry] ([id] nvarchar(255) not null, [domain] int, [context] nvarchar(255), [objectid] nvarchar(255), [objecttype] nvarchar(255), [granted] boolean, [permission] nvarchar(255), [user] nvarchar(255), [group] nvarchar(255), [origin] nvarchar(255), primary key ([id]))
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - Der boolean-Datentyp für die Spalte, den Parameter oder die Variable Nr. '6' wurde nicht gefunden.
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - HHH000388: Unsuccessful: create table [attribute] ([id] nvarchar(255) not null, [objectid] nvarchar(255), [namespace] nvarchar(255), [name] nvarchar(255), [binarydata] boolean, [value] nvarchar(1000), primary key ([id]))
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - Der boolean-Datentyp für die Spalte, den Parameter oder die Variable Nr. '5' wurde nicht gefunden.
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - HHH000388: Unsuccessful: create table [code] ([id] nvarchar(255) not null, [basiccode_parent_id] nvarchar(255), [names] nvarchar(2000), [descriptions] nvarchar(2000), [sorthint] int, [active] boolean, primary key ([id]))
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - HHH000388: Unsuccessful: create table [embeddedpart] ([id] nvarchar(255) not null, [domain] int, [locale] nvarchar(255), [documentid] nvarchar(255), [code_printformat_id] nvarchar(255), [resource] nvarchar(255), [targetblank] boolean, primary key ([id]))
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - Der boolean-Datentyp für die Spalte, den Parameter oder die Variable Nr. '7' wurde nicht gefunden.
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - HHH000388: Unsuccessful: create table [information] ([id] nvarchar(255) not null, [domain] int, [locale] nvarchar(255), [name] nvarchar(500), [description] nvarchar(1000), [richdescription] nvarchar(max), [objectref_owner_id] nvarchar(255), [objectref_responsible_id] nvarchar(255), [symbol] nvarchar(255), [code_phase_id] nvarchar(255), [validbegin] datetime, [validend] datetime, [createdate] datetime, [objectref_creator_id] nvarchar(255), [url] nvarchar(2048), [glossary] boolean, primary key ([id]))
ERROR: org.hibernate.tool.hbm2ddl.SchemaUpdate - Der boolean-Datentyp für die Spalte, den Parameter oder die Variable Nr. '16' wurde nicht gefunden.
Seems like Hibernate has trouble with booleans.
German: Der boolean-Datentyp für die Spalte, den Parameter oder die Variable Nr. '6' wurde nicht gefunden.
English: The boolean Datatype for the column, the Parameter or the Variable Nr. '6' was not found.
Here is one of the problem classifier.
<eClassifiers xsi:type="ecore:EClass" name="Attribute">
<eAnnotations source="http:///www.softmodeler.com/model/annotation/REF">
<details key="enabled" value="false"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="id" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
defaultValueLiteral="" iD="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="objectId" unique="false"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString" defaultValueLiteral="">
<eAnnotations source="http:///www.softmodeler.com/model/annotation/Validate">
<details key="validator" value="required"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="namespace" unique="false"
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" unique="false" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="binaryData" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBoolean"
defaultValueLiteral="false"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString">
<eAnnotations source="teneo.jpa">
<details key="value" value="@Column(length=1000)
</eAnnotations>
</eClassifiers>
Any Clue how to solve this?
Greets
Flavio
Prozessmanagement und Qualitätsmanagement Software QMS/IMS
https://www.scodi.ch
Re: [Teneo] Hibernate 4.1 has Trouble with Booleans [message #881323 is a reply to message #881299] |
Mon, 04 June 2012 10:35 |
Hi Flavio,
Which database, jdbc driver and which hibernate dialect are you using?
gr. Martin
On 06/04/2012 11:57 AM, Flavio Donze wrote:
> Hi Martin
> primary key ([id]))
> Seems like Hibernate has trouble with booleans. German: Der boolean-Datentyp für die Spalte, den Parameter oder die
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> Greets
> Flavio
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] Hibernate 4.1 has Trouble with Booleans [message #881330 is a reply to message #881299] |
Mon, 04 June 2012 10:54 |
Hi Flavio,
It seems to be this issue:
https://hibernate.onjira.com/browse/HHH-6420
Can you switch to this dialect:
org.hibernate.dialect.SQLServer2008Dialect
gr. Martin
> Hi Martin
> primary key ([id]))
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> Greets
> Flavio
The Netherlands
Re: [Teneo] Hibernate 4.1 has Trouble with Booleans [message #881833 is a reply to message #881377] |
Tue, 05 June 2012 10:38 |
Hi Martin
It was actually a problem of our Software at some place we called EntityManager.joinTransaction(), which is not required anymore in Hibernate 4.1.
I did have to set the following property to get CMT to work.
<prop key="hibernate.transaction.factory_class">org.hibernate.engine.transaction.internal.jta.CMTTransactionFactory</prop>
greets
Flavio
Current Time: Sat May 04 23:13:26 GMT 2024
Powered by FUDForum. Page generated in 0.04415 seconds
