Home » Modeling » TMF (Xtext) » Xbase: overwrite the Operator '='
Xbase: overwrite the Operator '=' [message #879947] Fri, 01 June 2012 03:25 Go to next message
I use Xtext with Xbase.
My Grammar is
grammar org.eclipse.xtext.example.domainmodel.Domainmodel with org.eclipse.xtext.xbase.Xbase
generate domainmodel "http://www.xtext.org/example/Domainmodel"
DomainModel:
	elements+=AbstractElement*;
AbstractElement:
	PackageDeclaration | Entity | Import;
PackageDeclaration:
	'package' name=QualifiedName elements+=AbstractElement* ';'	;
Import:
	'import' importedNamespace=QualifiedNameWithWildCard';';
Entity:
	'entity' name=ValidID ('extends' superType=JvmParameterizedTypeReference)? '{'
		features+=Feature*
Feature:
	Property | Operation;
Property:
	(modifier=Modifier)+ 'var' name=ValidID ':' type=JvmTypeReference ';';
Operation:
	(modifier=Modifier)+ 'def' name=ValidID '(' (params+=FullJvmFormalParameter (',' params+=FullJvmFormalParameter)*)? ')' ':' type=JvmTypeReference
		body=XBlockExpression ';';
Modifier:
	 final?='final' & static?='static' & visibility=Visibility;
enum Visibility:
	 PACKAGE='package' | PRIVATE='private' | PROTECTED='protected' |  PUBLIC='public';
QualifiedNameWithWildCard :
	QualifiedName  ('.' '*')?;
I have 3 questions:
Question 1) Why is the following line of sourcecode not working
Property:
	(modifier=Modifier) 'var' name=ValidID ':' type=JvmTypeReference ';';
I get the following jvmmodelinferrer:
rule ruleModifier failed predicate: {getUnorderedGroupHelper().canLeave(grammarAccess.getModifierAccess().getUnorderedGroup())}?
Question 2) Why is the following line of sourcecode not working
Operation:
	(modifier=Modifier) 'def' name=ValidID '(' (params+=FullJvmFormalParameter (',' params+=FullJvmFormalParameter)*)? ')' ':' type=JvmTypeReference
Multiple markers at this line
- rule ruleModifier failed predicate: {getUnorderedGroupHelper().canLeave(grammarAccess.getModifierAccess().getUnorderedGroup())}?
- missing ';' at 'private
Question 3) How can I overwrite the Operator '=' with ':=' in Xbase
I want to write in the model
val int value3 := value1 + value2;
I send you a picture of the error in the model.
  • Attachment: Unbenannt.png
    (Size: 176.08KB, Downloaded 170 times)
[Updated on: Fri, 01 June 2012 03:46] by Moderator
Re: Xbase: overwrite the Operator '=' [message #879959 is a reply to message #879947] Fri, 01 June 2012 03:49 Go to previous messageGo to next message
Hi Hans-Georg:
1+2) please refer to the docs on unordered groups. The group's elements
have to be optional in order to .. well .. make them optional.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 01.06.12 09:25, schrieb hans-georg Mising name:
> My Grammar is
> DomainModel:
> AbstractElement:
> PackageDeclaration:
> Import:
> Entity:
> features+=Feature*
> Feature:
> Property:
> Operation:
> Modifier:
> final?='final'& static?='static'& visibility=Visibility;
> enum Visibility:
> I have two questions:
> Property:
> Operation:
> - missing ';' at 'private'
Re: Xbase: overwrite the Operator '=' [message #879960 is a reply to message #879947] Fri, 01 June 2012 03:50 Go to previous messageGo to next message
the problem may be your errorneous Modifier definition
Modifier:
	 final?='final'? & static?='static'? & visibility=Visibility;
or
Modifier:
	 final?='final'? & static?='static'? & visibility=Visibility?;
(depending on your semantics if visibility is required)
may do the trick
~Christian
Re: Xbase: overwrite the Operator '=' [message #879981 is a reply to message #879960] Fri, 01 June 2012 04:27 Go to previous message
with this trick Question 1+2 are working.
Have a lot of thanks.
Previous Topic:[Solved] How to configure a custom QualifiedNameProvider?
Next Topic:How do I create a FOR loop that runs once?
Current Time: Mon Nov 03 14:46:35 EST 2025
Powered by FUDForum. Page generated in 0.04266 seconds
