Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » How to copy eResources such that xmi ids are maintained across resources
How to copy eResources such that xmi ids are maintained across resources [message #115948] |
Wed, 26 March 2008 19:40 |
Originally posted by: kelapure.us.ibm.com
How do I copy an eResource (say oldResource) to a new eResource (say
newResource) such that the newResource keeps the same xmi ids of the model
eobjects persisted in the oldResource.
This is what I am currently doing ..
Resource oldResource = myEObject.eResource();
ResourceSet resourceSet = oldResource.getResourceSet();
URI originalUri = oldResource.getURI();
Resource newResource = resourceSet.createResource(originalUri);
newResource.setURI(newURI);
newResource.getContents().add(newDD);
newResource().save(new HashMap());
After creating and persisting the newResource I dont see the XMI ids of
the eObjects in oldResource copy over to the newResource.
Can someone please help. What do I need to do here ...?
Thanks in advance,
Rohit Kelapure
Re: How to copy eResources such that xmi ids are maintained across resources [message #115963 is a reply to message #115948] |
Wed, 26 March 2008 19:54 |
Rohit,
This is purely an EMF question best asked on the EMF newsgroup. I'm not
sure why you wouldn't just change the URI of the existing resource.
XMLResource has methods like getID and setID that can be used to
determine the ID of the objects. You'd have to get to the old IDs
before you remove the objects from the old resource...
> model eobjects persisted in the oldResource.
> of the eObjects in oldResource copy over to the newResource.
> Thanks in advance,
> Rohit Kelapure
Re: How to copy eResources such that xmi ids are maintained across resources [message #115974 is a reply to message #115963] |
Wed, 26 March 2008 20:40 |
Ed,
Thanks for the prompt response.
I cant change the URI of the existing resource because my user application
still needs access to the unchanged existing resource.
I want to copy the existing resource into a new resource and then add more
model objects to the new resource and persist the new resource. When I
persist the new resource I need the eobjects copied over from the existing
resource to retain their xmi IDs.
Do I need to reflectively iterate over my existing Resource get the IDs of
the eObjects and then set them on the equivalent eObjects in the new
Resource. Is there an EMF API call that does this ...?
--Thanks,
Rohit
Re: How to copy eResources such that xmi ids are maintained across resources [message #115987 is a reply to message #115974] |
Wed, 26 March 2008 20:57 |
Rohit,
Comments below.
> Ed,
> application still needs access to the unchanged existing resource.
If you renamed the resource, that only affects the in-memory copy, not
what's out there in the backing store. In fact, you could still load
the old resource using the old URI and they you'd have two copies with
the same IDs but with different resource URIs.
> more model objects to the new resource and persist the new resource.
> When I persist the new resource I need the eobjects copied over from
> the existing resource to retain their xmi IDs.
Now I'm confused. If you are going to overwrite the existing resource,
then why change the URI? I must be missing something...
> IDs of the eObjects and then set them on the equivalent eObjects in
> the new Resource. Is there an EMF API call that does this ...?
You could use Resource.getAllContents() to walk the tree, but a map from
EObject to ID, and then use that map to set the IDs of all the objects,
but I'm really wondering if you aren't doing something completely
unnecessary.
> --Thanks,
> Rohit
Re: How to copy eResources such that xmi ids are maintained across resources [message #115999 is a reply to message #115974] |
Wed, 26 March 2008 21:11 |
Hi, Rohit,
Here's an idea:
1. Change the URI of your resource to the new URI.
2. Attach a ChangeRecorder to all of the contents of the resource.
3. Start recording.
4. Add your objects, make other changes.
5. Stop recording.
6. Save the resource.
7. Apply your change description obtained at step 5.
8. Change the URI back to its previous value.
9. Load the new resource from the new URI.
10. Voila! Your original resource is restored and you have a copy.
HTH,
Christian
> Ed,
> --Thanks,
> Rohit
Re: How to copy eResources such that xmi ids are maintained across resources [message #116024 is a reply to message #115987] |
Thu, 27 March 2008 02:29 |
Ed,
I cannot in any way change or overwrite the eObjects of the existing
resource. I need to create an exact in-memory copy of the existing
resource and make modifications to the copied resource.
Say..
Original/Existing resource is persisted as web.xml
New/Copied resource will be persisted as web_merged.xml
web_merged.xml consumes ALL the eObjects contained in web.xml. Other
eObjects will be added to the web_merged new resource.
Say web.xml contains...
<ejb-ref id="EJBRef_Stateful">
<ejb-ref-name>ejb/BasicCMTRemote</ejb-ref-name>
<ejb-ref-type>Session</ejb-ref-type>
</ejb-ref>
web_merged.xml ALSO needs to contain the same id for the ejb-ref eObject
</ejb-ref>
Do you think Resource.getAllContents()... is the way to go here ...?
--Thanks,
Rohit Kelapure
Ed Merks wrote:
> Rohit,
> Comments below.
>> Ed,
> unnecessary.
>> --Thanks,
>> Rohit
Re: How to copy eResources such that xmi ids are maintained across resources [message #116156 is a reply to message #116024] |
Thu, 27 March 2008 15:27 |
Rohit,
Comments below.
> Ed,
Well, what you've shown is moving the EObjects from one resource to
another, so you've already violated your one constraint. You'd need to
make a copy of the original resource. How about if you create another
resource with the same old URI, load it, and then rename that duplicate
resource's URI? Then you'll have two copies and the IDs will be what
you want. Failing that, you'd need to use an EcoreUtil.Copier to copy
the EObjects.
> Say..
> </ejb-ref>
> </ejb-ref>
> --Thanks,
> Rohit Kelapure
> Ed Merks wrote:
>> Rohit,
>> Comments below.
>>> Ed,
>> not what's out there in the backing store. In fact, you could still
>> load the old resource using the old URI and they you'd have two
>> copies with the same IDs but with different resource URIs.
>>> add more model objects to the new resource and persist the new
>>> resource. When I persist the new resource I need the eobjects copied
>>> over from the existing resource to retain their xmi IDs.
>> resource, then why change the URI? I must be missing something...
>> from EObject to ID, and then use that map to set the IDs of all the
>> objects, but I'm really wondering if you aren't doing something
>> completely unnecessary.
>>> --Thanks,
>>> Rohit
Re: How to copy eResources such that xmi ids are maintained across resources [message #116208 is a reply to message #116156] |
Thu, 27 March 2008 17:32 |
Thanks for guiding me ...This is what I have now ...
//oldDD and newDD EObjects are copies of one another created using
//ECoreUtil.copy()
public void updateCopiedDDResource(EObject oldDD, EObject newDD){
Resource oldResource = oldDD.eResource();
newResource.setURI(getMergedURI(originalURI));
Problem with this approach is that the
Contents of ((XMLResource) oldResource).getEObjectToIDMap() and
((XMLResource) newResource).getEObjectToIDMap() don't contain the same
type of EObjects.
This what I had intended to do copy the IDs over ...
for (Map.Entry<EObject, String> entry : oldEObjectToID.entrySet()) {
EObject eObj = entry.getKey();
String id = entry.getValue();
for (EObject eObjKey : newEObjectToID.keySet()) {
if (EcoreUtil.equals(eObj, eObjKey)){
if (null != id){
(XMLResource) newResource).setID(eObjKey, id);
Re: How to copy eResources such that xmi ids are maintained across resources [message #116221 is a reply to message #116208] |
Thu, 27 March 2008 18:36 |
Rohit,
Comments below.
> //ECoreUtil.copy()
What if you just called newResource.load()?
This newDD is a copy?
> type of EObjects.
Exactly.
If you look at how EcoreUtil.copy is implemented, you'll see this:
Copier copier = new Copier();
EObject result = copier.copy(eObject);
copier.copyReferences();
return result;
Note that the copier is a map that maps the original object to its copy,
so that would allow you to walk the original resource's objects, get the
ID for each, map that object to its copy, and then set the ID for the
copy in the new resource.
EObjects are only .equals if they are ==.
> if (null != id){
Re: How to copy eResources such that xmi ids are maintained across resources [message #615996 is a reply to message #115948] |
Ed Merks Messages: 33142 Registered: July 2009 |
Rohit,
> Thanks in advance,
> Rohit Kelapure
Ed Merks
Re: How to copy eResources such that xmi ids are maintained across resources [message #615998 is a reply to message #115974] |
Rohit,
Comments below.
> Ed,
unnecessary.
> --Thanks,
> Rohit
Ed Merks
Re: How to copy eResources such that xmi ids are maintained across resources [message #615999 is a reply to message #115974] |
Hi, Rohit,
Here's an idea:
3. Start recording.
5. Stop recording.
HTH,
Christian
> Ed,
> --Thanks,
> Rohit
Re: How to copy eResources such that xmi ids are maintained across resources [message #616001 is a reply to message #115987] |
Rohit Kelapure Messages: 11 Registered: July 2009 |
Ed,
Say..
</ejb-ref>
</ejb-ref>
--Thanks,
Rohit Kelapure
Ed Merks wrote:
> Rohit,
> Comments below.
>> Ed,
> unnecessary.
>> --Thanks,
>> Rohit
Re: How to copy eResources such that xmi ids are maintained across resources [message #616011 is a reply to message #116024] |
Rohit,
Comments below.
> Ed,
the EObjects.
> Say..
> </ejb-ref>
> </ejb-ref>
> --Thanks,
> Rohit Kelapure
> Ed Merks wrote:
>> Rohit,
>> Comments below.
>>> Ed,
>>> --Thanks,
>>> Rohit
Ed Merks
Re: How to copy eResources such that xmi ids are maintained across resources [message #616016 is a reply to message #116208] |
Rohit,
Comments below.
> //ECoreUtil.copy()
> type of EObjects.
Exactly.
return result;
> if (null != id){
Ed Merks
Current Time: Fri Apr 26 16:14:47 GMT 2024
Powered by FUDForum. Page generated in 0.04199 seconds
