Re: Stanford Eclipse Log Error! Please help? [message #1008543 is a reply to message #878138] |
Tue, 12 February 2013 22:20   |
Bilal Korir Messages: 2 Registered: February 2013 |
Hi, this is my solution :
I had the same problem, I think the problem is that Stanford university offers an old version of eclipse that doesn't work with new version of jdk/jre, some people suggested re-installing jdk/jre but that didn't work in my case.
Solution 1 (using Stanford's eclipse):
- Uninstall the jdk/jre -if you already have it-.
- Download eclipse afforded by Stanford website.
- Download JAVA 1.6 jre afforded by Stanford website, and install it.
- Run eclipse.
Solution 2 (using new/different version of eclipse):
-At this step you have two version of Eclipse,
> extract/decompose the downloaded file -Stanford's eclipse- and find a file named "plugins", juts copy everything from it.
> go to the file where you have the new/different version of eclipse that you are using and find a file called "plugins", paste what you copied from other file to it
- Run eclipse -your version of eclipse-.
note: I did this on Eclipse IDE for Java EE Developers (Juno) and Eclipse classic 4.2.1 (Juno), both worked.
Learn and Share!
FUDForum. Page generated in 0.02692 seconds
