Stanford Eclipse Log Error! Please help? [message #878138] |
Mon, 28 May 2012 12:48  |
I'm taking the Prgoramming Methadology CS106A online course and we have to download a special stanford version of eclipse. I downloaded it and unzipped the folder to "C:\Program Files\Eclipse\eclipse" and everything goes good but when i try to launch the program it flashes the eclipse 3.2 startup then goes away and gives me the error "An error has occured. See the log file." and this is what the log file says. Can somebody tell me what im doing wrong?
!SESSION 2012-05-28 12:45:32.828 -----------------------------------------------
eclipse.buildId=M20060921-0945
java.version=1.7.0_04
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY system.bundle 4 0 2012-05-28 12:45:34.156
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle system.bundle.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:1010)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:966)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:549)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:484)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:275)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.launch(StartLevelManager.java:245)
at org.eclipse.osgi.framework.internal.core.SystemBundle.resume(SystemBundle.java:155)
at org.eclipse.osgi.framework.internal.core.Framework.launch(Framework.java:503)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.java:51)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:289)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:173)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.IllegalStateException
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.checkSystemState(BaseStorage.java:654)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.getStateManager(BaseStorage.java:634)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.getPlatformAdmin(BaseAdaptor.java:385)
at org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook.frameworkStart(EclipseAdaptorHook.java:80)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.frameworkStart(BaseAdaptor.java:260)
at org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start(SystemBundleActivator.java:55)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:991)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:985)
... 18 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2012-05-28 12:45:34.187
!MESSAGE Startup error
!STACK 1
java.lang.RuntimeException: Exception in org.eclipse.osgi.framework.internal.core.SystemBundleActivator.start() of bundle system.bundle.
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:557)
!SESSION Mon May 28 12:45:34 EDT 2012 ------------------------------------------
!ENTRY org.eclipse.core.launcher 4 0 2012-05-28 12:45:34.218
!MESSAGE Exception launching the Eclipse Platform:
!STACK
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:186)
Re: Stanford Eclipse Log Error! Please help? [message #1008543 is a reply to message #878138] |
Tue, 12 February 2013 17:20   |
Hi, this is my solution :
I had the same problem, I think the problem is that Stanford university offers an old version of eclipse that doesn't work with new version of jdk/jre, some people suggested re-installing jdk/jre but that didn't work in my case.
Solution 1 (using Stanford's eclipse):
- Uninstall the jdk/jre -if you already have it-.
- Download eclipse afforded by Stanford website.
- Download JAVA 1.6 jre afforded by Stanford website, and install it.
- Run eclipse.
Solution 2 (using new/different version of eclipse):
-At this step you have two version of Eclipse,
> extract/decompose the downloaded file -Stanford's eclipse- and find a file named "plugins", juts copy everything from it.
> go to the file where you have the new/different version of eclipse that you are using and find a file called "plugins", paste what you copied from other file to it
- Run eclipse -your version of eclipse-.
note: I did this on Eclipse IDE for Java EE Developers (Juno) and Eclipse classic 4.2.1 (Juno), both worked.
Learn and Share!
FUDForum. Page generated in 0.11719 seconds
