Home » Language IDEs » Java Development Tools (JDT) » Failing to create JVM, but I have more than enough RAM(I've edited the .ini file and made some tests, but I can't assign more than 1024MB)
Re: Failing to create JVM, but I have more than enough RAM [message #877816 is a reply to message #877766] |
Sun, 27 May 2012 20:49 |
On 5/27/2012 1:21 PM, Jorge Antonio Díaz-Benito Soriano wrote:
> I'm getting it because of my program, as a runtime exception. No matter if I run it from inside Eclipse or from the command line through java -jar. In that case, doesn't the virtual machine get as
> much memory as it needs?
No there are certain defaults that java runtime would use. I think you would need to use cmdline arguments to override defaults.
My guess is a programming issue more than java runtime issue. (that is, something your doing is likely causing the exhaustion rather than an actually case of the program taking to much memory doing
its correct function.
Current Time: Fri Sep 20 11:34:13 GMT 2024
Powered by FUDForum. Page generated in 0.05397 seconds
