Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo - NamedQuery annotation support
Re: Teneo - NamedQuery annotation support [message #115552 is a reply to message #115463] |
Mon, 24 March 2008 07:34 |
Phaneesh Messages: 16 Registered: July 2009 |
Hi Martin,
Please find the attached patch. I have added NamedQuery annotation support
for Hibernate mapper. I have followed the first approach.
Please let me know if you face problems integrating the patch.
Phaneesh
"Phaneesh" <n_phaneesh17010@yahoo.com> wrote in message
news:fs5s4p$ka$1@build.eclipse.org...
> Hi Martin,
> Thanks for a very descriptive explanation. As soon as I get it working I
> will send you the patch. If I have any queries regarding this will ping
> you
> back.
> Regards
> Phaneesh
> "Martin Taal" <mtaal@elver.org> wrote in message
> news:fs57t1$79l$1@build.eclipse.org...
>> Hi Phaneesh,
>> After adding the namedquery annotation to the hbannotation.ecore: Then
>> you
>> should add the NamedQuery element (Upper Bound==-1) as an ereference to
>> the HbAnnotatedEPackage and the HbAnnotatedEClass. Then reload the
>> hbannotation.genmodel and regenerate the source code.
>> The next step is to create the correct hibernate mapping.
>> The global namedqueries can be processed as follows: see the
>> processPersistentClasses method in the
>> HibernateMappingGenerator. As the namedquery should be placed at the end
>> of the mapping file I would add a for loop (at the end of the try block)
>> which walks through the paModel.getPaEPackages and for each package gets
>> the namedqueries and create the correct elements and add to the mapping
>> document (see other mappers for examples).
>> The namedqueries on class level can be processed as follows: see the
>> method processEntity in the EntityMapper class. As the namedquery should
>> be added to the end I would add the handling of the namedquery to the end
>> of this method. The namedqueries can be handled in the same way as on
>> package level (so it makes probably sense to have a separate global
>> method
>> somewhere handling these).
>> If you don't want to change the standard then the above changes in the
>> HibernateMappingGenerator and EntityMapper can be made in custom
>> subclasses. Teneo can be directed to use your subclasses using the Teneo
>> ExtensionManager approach
>> (http://www.elver.org/hibernate/extensions.html).
>> To be complete, the NamedQuery element in hbannotation.ecore should have
>> a
>> Target eannotation pointing to EClass and one pointing to EPackage (see
>> the other annotations for an example). Then the xsd generator (see
>> HbMappingSchemaGenerator) knows where to create an xsd element. Note that
>> the HbMappingSchemaGenerator currently is set to create an xsd in a path
>> which is specific for my computer so you would need to change that before
>> running the xsd generator.
>> Afaics the above description is complete, let me know if I missed
>> something. And ofcourse feel free to contribute any changes to Teneo when
>> it works for you (just send me a patch)...
>> gr. Martin
>> Phaneesh wrote:
>>> Hi,
>>> I am trying to extend the hibernate annotation support for NamedQuery. I
>>> have added a new NamedQuery element to hbannotation.ecore. Then I am
>>> trying to extend the HibernateMappingGenerator with a new
>>> NamedQueryMapper. But I am not able to understand how I can process the
>>> NamedQuery annotation from the new Mapper I am trying to create. Please
>>> help me understand this so that I can implement NamedQuery support
>>> hibernate.
>>> Thanks
>>> Phaneesh
>> With Regards, Martin Taal
>> Springsite/Elver.org
>> Office: Hardwareweg 4, 3821 BV Amersfoort
>> Postal: Nassaulaan 7, 3941 EC Doorn
>> The Netherlands
>> Tel: +31 (0)84 420 2397
>> Fax: +31 (0)84 225 9307
>> Mail: mtaal@springsite.com - mtaal@elver.org
>> Web: www.springsite.com - www.elver.org
Re: Teneo - NamedQuery annotation support [message #115578 is a reply to message #115552] |
Mon, 24 March 2008 21:10 |
Hi Phaneesh,
Thanks, I will take a look at/apply it within a few days.
gr. Martin
Phaneesh wrote:
> Hi Martin,
> Regards
> Phaneesh
>> Hi Martin,
>> you
>> back.
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> you
>>> method
>>> a
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi,
>>>> hibernate.
>>>> Thanks
>>>> Phaneesh
>>> The Netherlands
The Netherlands
Re: Teneo - NamedQuery annotation support [message #116065 is a reply to message #115552] |
Thu, 27 March 2008 09:05 |
Hi Phaneesh,
One administrative question, can you open a bugzilla and attach your patch to it? Afaik because of
licensing reasons contributions should be send in as part of a bugzilla.
Thanks!
gr. Martin
Phaneesh wrote:
> Hi Martin,
> Regards
> Phaneesh
>> Hi Martin,
>> you
>> back.
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> you
>>> method
>>> a
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi,
>>>> hibernate.
>>>> Thanks
>>>> Phaneesh
>>> The Netherlands
The Netherlands
Re: Teneo - NamedQuery annotation support [message #615965 is a reply to message #115463] |
Hi Martin,
Phaneesh
> Hi Martin,
> you
> back.
> Regards
> Phaneesh
>> Hi Phaneesh,
>> you
>> method
>> a
>> gr. Martin
>> Phaneesh wrote:
>>> Hi,
>>> hibernate.
>>> Thanks
>>> Phaneesh
>> The Netherlands
Re: Teneo - NamedQuery annotation support [message #615967 is a reply to message #115552] |
Hi Phaneesh,
gr. Martin
Phaneesh wrote:
> Hi Martin,
> Regards
> Phaneesh
>> Hi Martin,
>> you
>> back.
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> you
>>> method
>>> a
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi,
>>>> hibernate.
>>>> Thanks
>>>> Phaneesh
>>> The Netherlands
The Netherlands
Re: Teneo - NamedQuery annotation support [message #616004 is a reply to message #115552] |
Hi Phaneesh,
Thanks!
gr. Martin
Phaneesh wrote:
> Hi Martin,
> Regards
> Phaneesh
>> Hi Martin,
>> you
>> back.
>> Regards
>> Phaneesh
>>> Hi Phaneesh,
>>> you
>>> method
>>> a
>>> gr. Martin
>>> Phaneesh wrote:
>>>> Hi,
>>>> hibernate.
>>>> Thanks
>>>> Phaneesh
>>> The Netherlands
The Netherlands
Current Time: Fri Apr 26 22:46:35 GMT 2024
Powered by FUDForum. Page generated in 0.04298 seconds
