Re: Where can I find proper documentation? [message #885689 is a reply to message #885312] |
Wed, 13 June 2012 12:43 |
Andreas Mihm Messages: 3 Registered: May 2012 |
Junior Member |
Hi Marton,
here are some answers for your questions:
2. Setup a Gyrex cluster
in the gyrex wiki you'll find a screen cast showing, how easy it is to setup a gyrex cluster wiki.eclipse.org/Gyrex/ClusterTutorial
3. External ZooKeeper
when you want to use an external ZooKeeper for cluster coordination, you just need to connect every gyrex instance to it:
Please go to the gyrex admin ui at localhost:3110 and select the CLoud section from the left hand menu,
Below the node id you'll find the Membership information with a connect link,
please press the connect link and enter the ip address and port of your ZooKeeper Machine,
If you don't provide a port, it will use the ZooKeeper standard port 2181
On the other two questions I'll come back to you later,
I hope the answers help you out for the moment,
best regards
Andreas
Re: Where can I find proper documentation? [message #891576 is a reply to message #885312] |
Mon, 25 June 2012 09:33 |
Hi Marton,
Am 12.06.2012 21:41, schrieb Marton Sigmond:
> What is default user/password when ssh into the Equinox console?
There is no default user/password. Currently, only key-based
authentication is available. You need to create an authorized keys file.
Any user name will do. The OSGi Console doesn't have a permission/roles
concept at the moment.
I've updated the admin guide at
http://wiki.eclipse.org/Gyrex/Administrator_Guide/Console
> How should I configure two Gyrex instances so, that they find each other?
> How should I configure and use an external Zookeeper and disable the embedded one?
Andreas already posted the link to the screencast. Let me know if that
is sufficient or you need more info.
> Is there OSGi remote service support?
Not yet. Contributions are welcome. :)
http://bugs.eclipse.org/383415
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
http://wagenknecht.org/
FUDForum. Page generated in 0.03214 seconds
