Home » Modeling » GMF (Graphical Modeling Framework) » Custom create command does not work with CreateViewCommand properly
Custom create command does not work with CreateViewCommand properly [message #115323] Thu, 29 March 2007 08:05 Go to next message
I have a problem integrating my custom create element command with the
GMF create process.
I use my edit helper to return a customized creation command for my
semantoc model. I replace the default semantic creation command so that
I have now two chained commands:
1. customized semantic creation command
2. default create view command
The problem is that my creation command does not provide the new element
in andvance. So I cannot set the newElement-attribute of the request
accordingly.
I'm currently out of ideas where to look at or who I can conceptually
integrate my custom command into GMF.
Must I change the CreateViewCommand after execution of my semantic
command? Or must I override some view related command?
Greetings,
Alexander
Re: Custom create command does not work with CreateViewCommand properly [message #115559 is a reply to message #115323] Fri, 30 March 2007 04:42 Go to previous message
I found it out myself by debugging.
The CommandResult of a AbstractTransactionalCommand does contain a
returnBalue which is set as newElement for the following "Create
View"-Command.
Alexander
Previous Topic:GMFGen and GMFMap Editor missing in S-2.0M5-200702211500??
Next Topic:Create elements from the palette
Current Time: Sun Nov 09 11:45:54 EST 2025
Powered by FUDForum. Page generated in 0.02899 seconds
