Method 'satisfiesOne' not found for ... [message #876970] |
Fri, 25 May 2012 16:00 |
I was starting to work on some validations and from the error message it seems either I am doing something wrong, or satisfiesAll is buggy . This is the code, the metamodel is Papyrus SysML.
context SysML!sysml::portandflows::FlowPort
// The base port must be typed
constraint IsTyped
check : self.base_Port.type.isDefined()
message : "FlowPort" + self.base_Port.name + " is not typed"
constraint IsTypedWithHiLeS
guard : self.satisfies("IsTyped") and
self.satisfiesOne("IsBooleanOrLogic", "IsTerminalOrNode")
check : true
// Logic and Boolean are not generalizations
@lazy
constraint IsBooleanOrLogic
check : self.type.name = "Logic"
or self.type.name = "Boolean"
@lazy
constraint HasGeneralization
check : self.base_Port.type.generalization.isDefined()
message : "FlowPort" + self.base_Port.name + " type is not a generalization "
+ "of another type (All HiLeS library types are generalizations)."
@lazy
constraint IsTerminalOrNode
guard : self.satisfies("HasGeneralization")
check : self.base_Port.type.generalization.general.name = "Terminal" or
self.base_Port.type.generalization.general.name = "Node"
message : "Flow Port " + self.base_Port.name + " NOT"
Horacio Hoyos Rodriguez
Kinori Tech
Need professional support for Epsilon, EMF?
Go to: https://kinori.tech
FUDForum. Page generated in 0.03488 seconds
