Re: PDF Render: Export to PDF file exports only first page [message #876930 is a reply to message #876660] |
Fri, 25 May 2012 14:20 |
Can you try the attached? It take a little bit after running for the
handle to be released.
Jason
On 5/24/2012 11:48 PM, Madhana Gopal wrote:
> I am trying to export the report as PDF while rendering the report using
> JAVASCRIPT. I have put the below code under afterFactory event (actually
> tried in all event beforeFactory, beforeRender & afterRender). It is
> generating the PDF file successfully, but it is generating only the
> first page. But while rendering the report it shows 2 pages.
> Below here is my Code:
> mmap =
> reportContext.getHttpServletRequest().getAttribute("attributeBean").getModuleOptions();
> myAttributeBean =
> reportContext.getHttpServletRequest().getAttribute('attributeBean');
> rptdoc = myAttributeBean.getReportDocumentName();
> importPackage(Packages.org.eclipse.birt.report.engine.api);
> importPackage(Packages.java.io);
> importPackage(Packages.java.util);
> importPackage(Packages.java.lang);
> var re = reportContext.getReportRunnable().getReportEngine();
> var mdocument = re.openReportDocument(rptdoc);
> var fName = reportContext.getPersistentGlobalVariable("ponumber");
> var cNum = reportContext.getPersistentGlobalVariable("compnumber")+"";
> var options = new PDFRenderOption();
> options.setOption(PDFRenderOption.PAGE_OVERFLOW,
> Integer.valueOf(PDFRenderOption.OUTPUT_TO_MULTIPLE_PAGES));
> options.setOutputFormat("pdf");
> IPDFRenderOption.FIT_TO_PAGE_SIZE);
> options.setOption( IRenderOption.HTML_PAGINATION, Boolean.FALSE );
> switch (cNum){
> case '201':
> options.setOutputFileName("D:/InforWflow/attachment/test/comp201/" +
> fName +".pdf");
> break;
> case '202':
> options.setOutputFileName("D:/InforWflow/attachment/test/comp202/" +
> fName +".pdf");
> break;
> case '801':
> options.setOutputFileName("D:/InforWflow/attachment/test/comp801/" +
> fName +".pdf");
> break;
> case '802':
> options.setOutputFileName("D:/InforWflow/attachment/test/comp802/" +
> fName +".pdf");
> break;
> case '251':
> options.setOutputFileName("D:/InforWflow/attachment/test/comp251/" +
> fName +".pdf");
> break;
> case '252':
> options.setOutputFileName("D:/InforWflow/attachment/test/comp252/" +
> fName +".pdf");
> break;
> case '851':
> options.setOutputFileName("D:/InforWflow/attachment/test/comp851/" +
> fName +".pdf");
> break;
> case '852':
> options.setOutputFileName("D:/InforWflow/attachment/test/comp852/" +
> fName +".pdf");
> break;
> default:
> options.setOutputFileName("D:/InforWflow/attachment/test/" + fName
> +".pdf");
> break;
> var ntask = re.createRenderTask(mdocument); ntask.setRenderOption(options);
> ntask.render();
> ntask.close();
> if (ntask != null) ntask = null;
> mdocument.close();
> if (mdocument != null) mdocument = null;
> Please let me know, is there any mistake i am doing and i am badly
> struck over here.
> Thanks in Advance
> Madhan
FUDForum. Page generated in 0.02822 seconds
