Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #876910 is a reply to message #876655] |
Fri, 25 May 2012 14:07 |
Tom,
You do this with a hidden table above the chart that loads data into
persistent global variables that are then used in chart script. Look at
the attached example. Make sure to update the file path and look at the
table detail row's oncreate method and then look at the script on the chart.
Jason
On 5/24/2012 11:30 PM, Tom Yamada wrote:
> CAT DISPTO COL_01 COL_02 COL_03 COL_04 LAB_01 LAB_02 LAB_03
> LAB_04
> AA 3 40 30 50 0 S_01 S_02 S_03
> S_04
> BB 3 25 65 5 0 S_01 S_02 S_03
> S_04
> CC 3 9 19 29 0 S_01 S_02 S_03
> S_04
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #876912 is a reply to message #876655] |
Tom,
Jason
> LAB_04
> S_04
> S_04
> S_04
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #876915 is a reply to message #876655] |
Tom,
Jason
> LAB_04
> S_04
> S_04
> S_04
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #876919 is a reply to message #876655] |
Tom,
Jason
> LAB_04
> S_04
> S_04
> S_04
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #876923 is a reply to message #876655] |
Tom,
Jason
> LAB_04
> S_04
> S_04
> S_04
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #876928 is a reply to message #876655] |
Tom,
Jason
> LAB_04
> S_04
> S_04
> S_04
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878588 is a reply to message #878274] |
Tue, 29 May 2012 15:12 |
If you are not use using optional grouping on the chart use the runtime
series that are generated. Take a look at the modified example. Note
that the data set should be setting the series values to some number not
a string. I did not change this because the chart still ran.
I also moved the script on the table group header to onrender as charts
are generated at render time. This is the only report item that does this.
Jason
On 5/28/2012 8:52 PM, Tom Yamada wrote:
> Because I have no life :p , I was able to try out some things on this design over the weekend.
> Unfortunately, not with much success. I am attaching a copy of the design with the epitome of my efforts. What I am doing in this version is using copyInstance() to make a copy of the first series and updating the data definition and series identifier before adding it to the series list in beforeGeneration().
> It appears that the timing is incorrect for this to be effective as this does not restore the series in output. As a test I used some assignments on the first series and discovered that the changed data column and series identifier were only effective for the next chart not the one where I made the change. These lines are commented-out in the script of the attached design.
> I don't know if there is someplace earlier to restore the necessary series, both before and after-DataSetFilled only work on individual series.
> If it is not possible then I would be satisfied with just manipulating the legend as that is the only place that the excess series show up -- they are not messing-up the chart plot but the legend should only show the first DISPTO series labels and swatches. Is there a way to only suppress the legend entries in a way that can be restored in subsequent iterations?
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878593 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878596 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878598 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878601 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878603 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878607 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878611 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878614 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878618 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878622 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878624 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878629 is a reply to message #878274] |
Jason
> Thanks.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #878799 is a reply to message #878680] |
Wed, 30 May 2012 00:31 |
Do you mean on the labels? You will have to remove the valueData from
the labels and put in Percentile Value Data. This is done on the Series
labels under values. You will see a drop down box and an add, remove
and format button.
Jason
On 5/29/2012 2:09 PM, Tom Yamada wrote:
> Thanks Jason, that's awesome. I've applied this technique to my actual
> design and it is working just as desired. It's nice to understand this
> important distinction in when to use the series vs. the run-time series!
> My data set is returning the series values as numbers so that is not a
> problem.
> One thing that I noticed when playing around with your example, but that
> does not affect my current requirements, is that if I switch the chart
> from a stacked bar to a percent stacked bar in the designer it looks
> correct but at run time it shows as a regular stacked bar still. The
> axis scale is 0 to 100 so that part is correct but the bars themselves
> are not percentage.
Re: Stacked Bar Chart in 2.5.2 -- need to set series visibility based on other data column value [message #879163 is a reply to message #878871] |
Wed, 30 May 2012 16:25 |
Tom,
Thanks for the images. I am still a bit confused as I do not see the
issue. It looks like a percent stacked to me.
Jason
On 5/30/2012 1:28 AM, Tom Yamada wrote:
> Jason, what I am seeing is that when I just change the chart type in your example to a percent stacked bar it looks good in the designer but when run in preview or the web viewer the bars are not percent (they appear to remain regular stacked bar proportion) while the scale does change to a percentage range.
> This is not a problem with my current development but I thought that you should know that this might be an issue. I am attaching a couple of screenshots to illustrate the apparent discrepancy.
