Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » RE: Merge EMF Models
RE: Merge EMF Models [message #115181] |
Thu, 20 March 2008 11:16 |
Originally posted by: mmelia.computing.dcu.ie
Hi all,
I am looking for something to merge two ecore models which are defined
according to the same metamodel - does anyone have an idea. I would
ideally like to use an ant script for the merge.
I have been looking at EMF Compare but cant access the developer guide,
maybe someone can tell me if this would suit my needs - possibly point me
to a tutorial.
Thanks for your help,
Mark
Re: Merge EMF Models [message #115195 is a reply to message #115181] |
Thu, 20 March 2008 11:56 |
--------------090309010109040405010705
Mark,
EMF Compare would meet your needs if what you're looking for is to
compare your two models and have a way to merge the differences between
them. For example, if you wish to merge differences between model1 (old)
and model2 (new) from left to right (undo differences in the new model),
you can use
// Matches elements of the two models
final MatchModel match = MatchService.doResourceMatch(model1, model2,
Collections.emptyMap());
// Detects differences
final DiffModel diff = DiffService.doDiff(match);
// Merges all differences from model1 to model2
MergeService.merge(diff.getOwnedElements());
Laurent
Mark Melia a
Re: Merge EMF Models [message #115591 is a reply to message #115207] |
Mon, 24 March 2008 22:11 |
Hi Laurent,
Thanks for your reply, I tried to put what you said into action - the code
is below. I still have a problem, I get a build error which states that
org.eclipse.core.runtime.IPath is required for creating model1, but when I
have a look in my library files, there doesnt seem to be an IPath class in
I am using Eclipse 3.4, and installed EMF compare through the software
updates mechinism, EMF Compare version is 0.8.0, can you see where I am
going wrong?
Thanks again,
Mark
CODE
package test;
import java.io.File;
import java.util.Collections;
import org.eclipse.emf.compare.diff.merge.service.MergeService;
import org.eclipse.emf.compare.diff.metamodel.DiffModel;
import org.eclipse.emf.compare.diff.service.DiffService;
import org.eclipse.emf.compare.match.metamodel.MatchModel;
import org.eclipse.emf.compare.match.service.MatchService;
import org.eclipse.emf.compare.util.ModelUtils;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.common.util.URI;
public class Test {
* @param args
try
final ResourceSet modelResourceSet = new ResourceSetImpl();
Resource model1 =
ModelUtils.load(URI.createFileURI("/home/mark/workspace/ATestProject/mikaelHigh.ecore "),
modelResourceSet).eResource();
Resource model2 = ModelUtils.load(new
java.io.File("/home/mark/workspace/ATestProject/mikaelLow.ecore "),
model2, null);
MergeService.merge(diff.getOwnedElements(), true);
catch (Exception exception)
exception.printStackTrace();
laurent Goubet wrote:
> Sorry, clicked "send" before actually answering all questions ;).
> About documentation on EMF Compare... Well we currently have no real
> documentation other than the examples on eclipse CVS, the home page
> http://www.eclipse.org/modeling/emft/?project=compare on Eclipse and the
> wiki at http://wiki.eclipse.org/index.php/EMF_Compare .
> Laurent
> laurent Goubet a écrit :
>> Mark,
>> you can use
>> Cheers,
>> Laurent
>> Mark Melia a écrit :
>>> Hi all,
>>> guide, maybe someone can tell me if this would suit my needs -
>>> possibly point me to a tutorial.
>>> Mark
Re: Merge EMF Models [message #115641 is a reply to message #115591] |
Tue, 25 March 2008 12:07 |
--------------080000020706080903060400
Mark,
Yup, org.eclipse.core.runtime is located in plug-in
org.eclipse.equinox.common. You need to add that one in your
dependencies as well.
Who said qualified names are unambiguous? :D
Cheers
Laurent Goubet
Obeo
Mark Melia a
Merge EMF Models [message #115654 is a reply to message #115641] |
Tue, 25 March 2008 12:49 |
Originally posted by: arist102.hotmail.com
Hey Laurent,Mark,
I need your help too. I am a rookie in eclipse and I need also to merge 2
EMF models according to the same metamodel.I already installed EMF Compare
but I donŽt know further.Please can you help me?
thx Ari
Re: Merge EMF Models [message #115668 is a reply to message #115641] |
Tue, 25 March 2008 12:51 |
Laurent,
Thanks again for your help. I imported the plugin jars:
org.eclipse.equinox.common_3.4.0v20080201.jar, but I still have the same
problem - I looked through this package and could not find the package the
IFile class should be in.
I also tried to get the code working by passing ModelUtils a File rather
than a URI, but this gives me the following runtime error - do you have
any ideas? Am I using the ModelUtils.load method with a java.io.File
parameter correctly?
Mark
Exception in thread "main" java.lang.ExceptionInInitializerError
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.<init>(XMLHelperImpl.java:91)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.<init>(XMLHelperImpl.java:194)
at
org.eclipse.emf.ecore.xmi.impl.XMIHelperImpl.<init>(XMIHelperImpl.java:32)
at
org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl.createXMLHelp er(XMIResourceImpl.java:53)
at
org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl.createXMLLoad (XMIResourceImpl.java:59)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:166)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1414)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1210)
at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :333)
at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :217)
at test.Test.main(Test.java:29)
Caused by: java.lang.SecurityException: SHA1 digest error for
org/eclipse/emf/ecore/util/ECrossReferenceEList.class
at
sun.security.util.ManifestEntryVerifier.verify(ManifestEntry Verifier.java:194)
at java.util.jar.JarVerifier.processEntry(JarVerifier.java:201)
at java.util.jar.JarVerifier.update(JarVerifier.java:188)
> Mark,
> Cheers
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> code is below. I still have a problem, I get a build error which states
>> that org.eclipse.core.runtime.IPath is required for creating model1,
>> but when I have a look in my library files, there doesnt seem to be an
>> IPath class in org.eclipse.core.runtime.
>> going wrong?
>> Thanks again,
>> Mark
>> CODE
>> package test;
>> public class Test {
>> * @param args
>> public static void main(String[] args) {
>> try {
>> Resource model1 =
>> model2, null);
>> } catch (Exception exception) {
>>> the wiki at http://wiki.eclipse.org/index.php/EMF_Compare .
>>> Laurent
>>>> Mark,
>>>> between them. For example, if you wish to merge differences between
>>>> model1 (old) and model2 (new) from left to right (undo differences in
>>>> the new model), you can use
>>>> Cheers,
>>>> Laurent
>>>>> Hi all,
>>>>> defined according to the same metamodel - does anyone have an idea.
>>>>> I would ideally like to use an ant script for the merge.
>>>>> Mark
Re: Merge EMF Models [message #115726 is a reply to message #115668] |
Wed, 26 March 2008 07:50 |
--------------040804010601030507010401
Mark,
You need to resolve all dependencies before actually running the code.
As said earlier, org.eclipse.core.runtime.IPath is located in
org.eclipse.equinox.common, which you seem to have imported
successfully. As for IFile, it is located in org.eclipse.core.resources.
If you ever need to find the plugin a given class belongs to, use the
eclipse menu "navigate => open type" (ctrl+shift+T) then in the package
explorer, click on the icon with two arrows "Link with editor". This
should show you the .class file of the class you're seeking. From there,
simply look at the name of the jar this file is in.
Laurent Goubet
Obeo
Mark Melia a
Re: Merge EMF Models [message #115739 is a reply to message #115681] |
Wed, 26 March 2008 07:59 |
--------------000808080808070203010507
Ari,
If you don't give us any more information, it might be difficult to help
you out ;). Here's a somewhat generic answer :
How do you wish to compare/merge your models? 1) Directly from eclipse
(GUI)? Or 2) programmatically?
If 1), you simply have to select your two models in eclipse's package
explorer, right-click, then select "compare with => each other". The
comparison result shows up (might take a while depending on your models'
size) and you simply have to select the action "copy all changes from
left(right) to right(left)".
If 2), you might be interested in reading this whole thread, then asking
us what you do not understand.
Laurent Goubet
Obeo
Mark Melia a
Re: Merge EMF Models [message #115832 is a reply to message #115726] |
Wed, 26 March 2008 13:28 |
Hi Laurent,
I dont think the problem is about the dependencies, as the error is being
caused by
and the exception points to a line in the XMLHelperImpl.java (91) that my
eclipse says doesnt exist??
I think I dont have the right combination of plugins that the EMF compare
jars were originally compiled with, but i did download the dependencies
from the site - they are as follows:
emft-compare-SDK-incubation-I200803130951
emf-sdo-xsd-SDK-I200803041800
eclipse-SDK-3.4M5-linux-gtk
JDK1.5.0_15
can you see any problems with this? Do you think I am correct in my
diagnosis of the problem? Any thoughts?
Thanks again for your time on this.
Mark
> Mark,
> Cheers,
> Laurent Goubet
> Obeo
>> Laurent,
>> the IFile class should be in.
>> Mark
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Mark,
>>> Cheers
>>> Laurent Goubet
>>> Obeo
>>>> Hi Laurent,
>>>> states that org.eclipse.core.runtime.IPath is required for creating
>>>> model1, but when I have a look in my library files, there doesnt seem
>>>> to be an IPath class in org.eclipse.core.runtime.
>>>> software updates mechinism, EMF Compare version is 0.8.0, can you see
>>>> where I am going wrong?
>>>> Thanks again,
>>>> Mark
>>>> CODE
>>>> package test;
>>>> public class Test {
>>>> * @param args
>>>> try {
>>>> Resource model1 =
>>>> MatchService.doResourceMatch(model1, model2, null);
>>>>> Laurent
>>>>>> Mark,
>>>>>> in the new model), you can use
>>>>>> model2, Collections.emptyMap());
>>>>>> Cheers,
>>>>>> Laurent
>>>>>>> Hi all,
>>>>>>> idea. I would ideally like to use an ant script for the merge.
>>>>>>> Mark
Re: Merge EMF Models [message #115858 is a reply to message #115832] |
Wed, 26 March 2008 14:02 |
Mark,
This looks to be a problem purely with the JVM not recognizing the
signed jar as having been properly signed, though I'm sure the jar is
properly signed. I think there might be a way to tell the JVM not to
verify signatures as a workaround, but I don't recall the flag for
that. I also seem to recall some issue with specific versions of
certain JDKs having a bug related to this...
Mark Melia wrote:
> Hi Laurent,
> being caused by Caused by: java.lang.SecurityException: SHA1 digest
> error for
> my eclipse says doesnt exist??
> compare jars were originally compiled with, but i did download the
> dependencies from the site - they are as follows:
> JDK1.5.0_15
> Mark
>> Mark,
>> code. As said earlier, org.eclipse.core.runtime.IPath is located in
>> package explorer, click on the icon with two arrows "Link with
>> editor". This should show you the .class file of the class you're
>> seeking. From there, simply look at the name of the jar this file is in.
>> Cheers,
>> Laurent Goubet
>> Obeo
>>> Laurent,
>>> same problem - I looked through this package and could not find the
>>> package the IFile class should be in.
>>> rather than a URI, but this gives me the following runtime error -
>>> do you have any ideas? Am I using the ModelUtils.load method with a
>>> java.io.File parameter correctly?
>>> Mark
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> Mark,
>>>> Cheers
>>>> Laurent Goubet
>>>> Obeo
>>>>> Hi Laurent,
>>>>> the code is below. I still have a problem, I get a build error
>>>>> which states that org.eclipse.core.runtime.IPath is required for
>>>>> creating model1, but when I have a look in my library files, there
>>>>> doesnt seem to be an IPath class in org.eclipse.core.runtime.
>>>>> see where I am going wrong?
>>>>> Thanks again,
>>>>> Mark
>>>>> CODE
>>>>> package test;
>>>>> public class Test {
>>>>> * @param args
>>>>> try {
>>>>> ResourceSetImpl();
>>>>> Resource model1 =
>>>>>> real documentation other than the examples on eclipse CVS, the
>>>>>> home page http://www.eclipse.org/modeling/emft/?project=compare
>>>>>> on Eclipse and the wiki at
>>>>>> Laurent
>>>>>>> Mark,
>>>>>>> to compare your two models and have a way to merge the
>>>>>>> differences between them. For example, if you wish to merge
>>>>>>> differences between model1 (old) and model2 (new) from left to
>>>>>>> right (undo differences in the new model), you can use
>>>>>>> Cheers,
>>>>>>> Laurent
>>>>>>>> Hi all,
>>>>>>>> developer guide, maybe someone can tell me if this would suit
>>>>>>>> my needs - possibly point me to a tutorial.
>>>>>>>> Mark
Re: Merge EMF Models [message #115872 is a reply to message #115858] |
Wed, 26 March 2008 14:31 |
--------------060008090506080600040804
Ed to the rescue :). So this could be JVM related? I must admit I have
never seen such exceptions.
Yet Mark did say he downloaded the correct dependencies from eclipse,
and those build IDs are indeed the correct ones.
As for disabling jar the jar signing verification ... well I doubt such
a jvm option exists as it would practically defeat the purpose of
signing jars.
@Mark : are you sure there is only a single version of EMF in your
classpath when you launch this app?
Cheers
Laurent Goubet
Obeo
Ed Merks a
Re: Merge EMF Models [message #115887 is a reply to message #115872] |
Wed, 26 March 2008 15:02 |
--------------070501070703040100060300
Laurent,
When I asked Nick about this familiar looking issue he said:
codeslave@c... if it's EMF 2.4M5 specifically, tell them to use an
I build
? otherwise, no clue 11:01:17 AM
merks Okay. 11:01:25 AM
> such a jvm option exists as it would practically defeat the purpose of
> signing jars.
> Cheers
> Laurent Goubet
> Obeo
> Ed Merks a
Re: Merge EMF Models [message #115899 is a reply to message #115858] |
Wed, 26 March 2008 15:12 |
Hi Ed,
I think you are thinking of the following bug
http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=5078608 which should be
fixed in the java version I am using.
I noted that someone else got this problem:
http://www.eclipsepowered.org/eclipse/forums/t107293.html, from the post
the guy got this solved by changing a plugin, so I will try another
version of the EMF plugin see if that makes any difference.
Mark
Ed Merks wrote:
> Mark,
> Mark Melia wrote:
>> Hi Laurent,
>> error for
>> JDK1.5.0_15
>> Mark
>>> Mark,
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>> Laurent,
>>>> Mark
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> Mark,
>>>>> Cheers
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Hi Laurent,
>>>>>> Thanks again,
>>>>>> Mark
>>>>>> CODE
>>>>>> package test;
>>>>>> public class Test {
>>>>>> * @param args
>>>>>> try {
>>>>>> ResourceSetImpl();
>>>>>> Resource model1 =
>>>>>>> Laurent
>>>>>>>> Mark,
>>>>>>>> Cheers,
>>>>>>>> Laurent
>>>>>>>>> Hi all,
>>>>>>>>> Mark
Re: Merge EMF Models [message #615938 is a reply to message #115181] |
Mark,
you can use
Laurent
Mark Melia a
Re: Merge EMF Models [message #615968 is a reply to message #115207] |
Mark Melia Messages: 142 Registered: July 2009 |
Hi Laurent,
going wrong?
Thanks again,
Mark
CODE
package test;
public class Test {
* @param args
try
Resource model1 =
model2, null);
> Laurent
>> Mark,
>> you can use
>> Cheers,
>> Laurent
>>> Hi all,
>>> Mark
Re: Merge EMF Models [message #615972 is a reply to message #115591] |
Mark,
Cheers
Laurent Goubet
Obeo
Mark Melia a
Merge EMF Models [message #615973 is a reply to message #115641] |
Hey Laurent,Mark,
thx Ari
Re: Merge EMF Models [message #615974 is a reply to message #115641] |
Laurent,
Mark
at
at
at
at
at
at
at
at
at
> Mark,
> Cheers
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> going wrong?
>> Thanks again,
>> Mark
>> CODE
>> package test;
>> public class Test {
>> * @param args
>> try {
>> Resource model1 =
>> model2, null);
>>> Laurent
>>>> Mark,
>>>> Cheers,
>>>> Laurent
>>>>> Hi all,
>>>>> Mark
Re: Merge EMF Models [message #615978 is a reply to message #115668] |
Mark,
Laurent Goubet
Obeo
Mark Melia a
Re: Merge EMF Models [message #615979 is a reply to message #115681] |
Ari,
Laurent Goubet
Obeo
Mark Melia a
Re: Merge EMF Models [message #615986 is a reply to message #115726] |
Hi Laurent,
caused by
JDK1.5.0_15
Mark
> Mark,
> Cheers,
> Laurent Goubet
> Obeo
>> Laurent,
>> Mark
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Mark,
>>> Cheers
>>> Laurent Goubet
>>> Obeo
>>>> Hi Laurent,
>>>> Thanks again,
>>>> Mark
>>>> CODE
>>>> package test;
>>>> public class Test {
>>>> * @param args
>>>> try {
>>>> Resource model1 =
>>>>> Laurent
>>>>>> Mark,
>>>>>> Cheers,
>>>>>> Laurent
>>>>>>> Hi all,
>>>>>>> Mark
Re: Merge EMF Models [message #615988 is a reply to message #115832] |
Ed Merks Messages: 33142 Registered: July 2009 |
Mark,
Mark Melia wrote:
> Hi Laurent,
> error for
> JDK1.5.0_15
> Mark
>> Mark,
>> Cheers,
>> Laurent Goubet
>> Obeo
>>> Laurent,
>>> Mark
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> Mark,
>>>> Cheers
>>>> Laurent Goubet
>>>> Obeo
>>>>> Hi Laurent,
>>>>> Thanks again,
>>>>> Mark
>>>>> CODE
>>>>> package test;
>>>>> public class Test {
>>>>> * @param args
>>>>> try {
>>>>> ResourceSetImpl();
>>>>> Resource model1 =
>>>>>> Laurent
>>>>>>> Mark,
>>>>>>> Cheers,
>>>>>>> Laurent
>>>>>>>> Hi all,
>>>>>>>> Mark
Ed Merks
Re: Merge EMF Models [message #615989 is a reply to message #115858] |
signing jars.
Cheers
Laurent Goubet
Obeo
Ed Merks a
Re: Merge EMF Models [message #615990 is a reply to message #115872] |
Laurent,
I build
> signing jars.
> Cheers
> Laurent Goubet
> Obeo
> Ed Merks a
Ed Merks
Re: Merge EMF Models [message #615991 is a reply to message #115858] |
Hi Ed,
Mark
Ed Merks wrote:
> Mark,
> Mark Melia wrote:
>> Hi Laurent,
>> error for
>> JDK1.5.0_15
>> Mark
>>> Mark,
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>> Laurent,
>>>> Mark
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> Mark,
>>>>> Cheers
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Hi Laurent,
>>>>>> Thanks again,
>>>>>> Mark
>>>>>> CODE
>>>>>> package test;
>>>>>> public class Test {
>>>>>> * @param args
>>>>>> try {
>>>>>> ResourceSetImpl();
>>>>>> Resource model1 =
>>>>>>> Laurent
>>>>>>>> Mark,
>>>>>>>> Cheers,
>>>>>>>> Laurent
>>>>>>>>> Hi all,
>>>>>>>>> Mark
Current Time: Fri Apr 26 15:32:23 GMT 2024
Powered by FUDForum. Page generated in 0.07225 seconds
