Can't show the project explorer properly in RCP [message #115038] |
Wed, 28 March 2007 08:49  |
Helow Everyone,
I developed an application using GMF, the plugins work well as projects
in Eclipse workspace(when I run them using eclipse ide). However, if I
want to make a RCP application, and run all the plugins using my defined
application, the project explorer shows nothing. I had configured the
perspective, and added the "org.eclipse.ui.navigator.ProjectExplorer"
view, but it shows nothing when I run my application.
another problem is that the eclipse navigator can't show some images.
What should I do?
Re: Can't show the project explorer properly in RCP [message #115243 is a reply to message #115038] |
Thu, 29 March 2007 06:22   |
Hello nemo,
> defined application, the project explorer shows nothing. I had configured
Are you re-creating .gmfgen model from .gmfmap with setting "Generate RCP
application" checkbox?
Navigator will not be generated in RCP mode because we are providing diagram/model
file contents below the corresponding file node in ProjectExplorer. Pure
RCP application has no "resources" plugins available (in particular, "org.eclipse.ui.navigator.resources").
So, GMF can not generate Navigator for RCP application because:
1. This is useless – content will be invisible because ProjectExplorer in
RCP application has no “files” – parent nodes for diagram/domain model contents
2. We should not introduce dependency from .resources plugin into the generated
code for RCP, but current state of Navigator has these dependencies.
As a workaround you can generate navigator for non-RCP mode, take the generated
code, modify it in accordance (get rid of resources dependencies + provide
additional structure into ProjectExplorer) and put into your application.
> view, but it shows nothing when I run my application. another problem
Is it just empty? Do you have org.eclipse.ui.navigator.resources plugin in
your RCP application plugins set?
Looks like a question to Eclipse navigator subsystem.
Alex Shatalin
Re: Can't show the project explorer properly in RCP [message #115686 is a reply to message #115243] |
Fri, 30 March 2007 08:59  |
Thanks, That's usful to me:)
Alex Shatalin 写道:
> Hello nemo,
> RCP application" checkbox?
> diagram/model file contents below the corresponding file node in
> ProjectExplorer. Pure RCP application has no "resources" plugins
> available (in particular, "org.eclipse.ui.navigator.resources"). So, GMF
> ProjectExplorer in RCP application has no “files” – parent nodes for
> generated code for RCP, but current state of Navigator has these
> dependencies.
> generated code, modify it in accordance (get rid of resources
> dependencies + provide additional structure into ProjectExplorer) and
> in your RCP application plugins set?
> Alex Shatalin
FUDForum. Page generated in 0.03201 seconds
