Home » Newcomers » Newcomers » Internal Exception: java.lang.NoSuchFieldException
Internal Exception: java.lang.NoSuchFieldException [message #875452] |
Tue, 22 May 2012 19:23 |
i have a java app that displays data from a table called ScripMaster using jpa. i wish to add an extra field to my table but, when i add the extra field named 'holdValue' to my database table ScripMaster i get following exception, when i remove the field, the app works fine
Exception [EclipseLink-0] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.IntegrityException
Descriptor Exceptions:
Exception [EclipseLink-59] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: The instance variable [lastTradeDate] is not defined in the domain class [entity.ScripMaster], or it is not accessible.
Internal Exception: java.lang.NoSuchFieldException: lastTradeDate
Mapping: org.eclipse.persistence.mappings.DirectToFieldMapping[lastTradeDate-->StockCommodityDB.ScripMaster.LastTradeDate]
Descriptor: RelationalDescriptor(entity.ScripMaster --> [DatabaseTable(StockCommodityDB.ScripMaster)])
Exception Description: The instance variable [holdValue] is not defined in the domain class [entity.ScripMaster], or it is not accessible.
Internal Exception: java.lang.NoSuchFieldException: holdValue
my entity class is as follows:
* To change this template, choose Tools | Templates
* and open the template in the editor.
package entity;
import java.io.Serializable;
import java.util.Collection;
import java.util.Date;
import javax.persistence.Basic;
import javax.persistence.CascadeType;
import javax.persistence.Column;
import javax.persistence.Entity;
import javax.persistence.FetchType;
import javax.persistence.GeneratedValue;
import javax.persistence.GenerationType;
import javax.persistence.Id;
import javax.persistence.JoinColumn;
import javax.persistence.ManyToOne;
import javax.persistence.NamedQueries;
import javax.persistence.NamedQuery;
import javax.persistence.OneToMany;
import javax.persistence.Table;
import javax.persistence.Temporal;
import javax.persistence.TemporalType;
import javax.validation.constraints.NotNull;
import javax.validation.constraints.Size;
import javax.xml.bind.annotation.XmlRootElement;
import javax.xml.bind.annotation.XmlTransient;
* @author root
@Entity
@Table(name = "ScripMaster", catalog = "StockCommodityDB", schema = "")
@XmlRootElement
@NamedQueries({
@NamedQuery(name = "ScripMaster.findAll", query = "SELECT s FROM ScripMaster s"),
@NamedQuery(name = "ScripMaster.findByScripID", query = "SELECT s FROM ScripMaster s WHERE s.scripID = :scripID"),
@NamedQuery(name = "ScripMaster.findByScripSymbol", query = "SELECT s FROM ScripMaster s WHERE s.scripSymbol = :scripSymbol"),
@NamedQuery(name = "ScripMaster.findByType", query = "SELECT s FROM ScripMaster s WHERE s.type = :type"),
@NamedQuery(name = "ScripMaster.findByCompanyName", query = "SELECT s FROM ScripMaster s WHERE s.companyName = :companyName"),
@NamedQuery(name = "ScripMaster.findByLastTradedPrice", query = "SELECT s FROM ScripMaster s WHERE s.lastTradedPrice = :lastTradedPrice"),
@NamedQuery(name = "ScripMaster.findByLastTradedQuantity", query = "SELECT s FROM ScripMaster s WHERE s.lastTradedQuantity = :lastTradedQuantity"),
@NamedQuery(name = "ScripMaster.findByOpenPrice", query = "SELECT s FROM ScripMaster s WHERE s.openPrice = :openPrice"),
@NamedQuery(name = "ScripMaster.findByHighPrice", query = "SELECT s FROM ScripMaster s WHERE s.highPrice = :highPrice"),
@NamedQuery(name = "ScripMaster.findByLowPrice", query = "SELECT s FROM ScripMaster s WHERE s.lowPrice = :lowPrice"),
@NamedQuery(name = "ScripMaster.findByTotalTradedQuantity", query = "SELECT s FROM ScripMaster s WHERE s.totalTradedQuantity = :totalTradedQuantity"),
@NamedQuery(name = "ScripMaster.findByTotalTradedVolume", query = "SELECT s FROM ScripMaster s WHERE s.totalTradedVolume = :totalTradedVolume"),
@NamedQuery(name = "ScripMaster.findByExchange", query = "SELECT s FROM ScripMaster s WHERE s.exchange = :exchange"),
@NamedQuery(name = "ScripMaster.findByBrokerageCharge", query = "SELECT s FROM ScripMaster s WHERE s.brokerageCharge = :brokerageCharge"),
@NamedQuery(name = "ScripMaster.findByPreviousClose", query = "SELECT s FROM ScripMaster s WHERE s.previousClose = :previousClose"),
@NamedQuery(name = "ScripMaster.findByChnge", query = "SELECT s FROM ScripMaster s WHERE s.chnge = :chnge"),
@NamedQuery(name = "ScripMaster.findByChngePer", query = "SELECT s FROM ScripMaster s WHERE s.chngePer = :chngePer"),
@NamedQuery(name = "ScripMaster.findByHoldValue", query = "SELECT s FROM ScripMaster s WHERE s.holdValue = :holdValue"),
@NamedQuery(name = "ScripMaster.findByLastTradeDate", query = "SELECT s FROM ScripMaster s WHERE s.lastTradeDate = :lastTradeDate")})
public class ScripMaster implements Serializable {
private static final long serialVersionUID = 1L;
@Id
@GeneratedValue(strategy = GenerationType.IDENTITY)
@Basic(optional = false)
@NotNull
@Column(name = "ScripID", nullable = false)
private Integer scripID;
@Size(max = 15)
@Column(name = "ScripSymbol", length = 15)
private String scripSymbol;
@Size(max = 10)
@Column(name = "Type", length = 10)
private String type;
@Size(max = 50)
@Column(name = "CompanyName", length = 50)
private String companyName;
// @Max(value=?) @Min(value=?)//if you know range of your decimal fields consider using these annotations to enforce field validation
@Column(name = "LastTradedPrice", precision = 22)
private Double lastTradedPrice;
@Column(name = "LastTradedQuantity")
private Integer lastTradedQuantity;
@Column(name = "OpenPrice", precision = 22)
private Double openPrice;
@Column(name = "HighPrice", precision = 22)
private Double highPrice;
@Column(name = "LowPrice", precision = 22)
private Double lowPrice;
@Column(name = "TotalTradedQuantity")
private Integer totalTradedQuantity;
@Column(name = "TotalTradedVolume")
private Integer totalTradedVolume;
@Size(max = 30)
@Column(name = "Exchange", length = 30)
private String exchange;
@Column(name = "BrokerageCharge", precision = 22)
private Double brokerageCharge;
@Column(name = "PreviousClose", precision = 22)
private Double previousClose;
@Column(name = "Chnge", precision = 22)
private Double chnge;
@Column(name = "ChngePer", precision = 22)
private Double chngePer;
@Column(name = "HoldValue", precision = 22)
private Double holdValue;
@Column(name = "LastTradeDate")
@Temporal(TemporalType.DATE)
private Date lastTradeDate;
@OneToMany(cascade = CascadeType.ALL, mappedBy = "scripID", fetch = FetchType.EAGER)
private Collection<UserStock> userStockCollection;
private Collection<UserTrack> userTrackCollection;
@JoinColumn(name = "CommoditySubCategoryID", referencedColumnName = "CommoditySubCategoryID")
@ManyToOne(fetch = FetchType.EAGER)
private CommoditySubCategoryMaster commoditySubCategoryID;
private Collection<OrderStock> orderStockCollection;
private Collection<TradeStock> tradeStockCollection;
public ScripMaster() {
public ScripMaster(Integer scripID) {
this.scripID = scripID;
public Integer getScripID() {
return scripID;
public void setScripID(Integer scripID) {
public String getScripSymbol() {
return scripSymbol;
public void setScripSymbol(String scripSymbol) {
this.scripSymbol = scripSymbol;
public String getType() {
return type;
public void setType(String type) {
this.type = type;
public String getCompanyName() {
return companyName;
public void setCompanyName(String companyName) {
this.companyName = companyName;
public Double getLastTradedPrice() {
return lastTradedPrice;
public void setLastTradedPrice(Double lastTradedPrice) {
this.lastTradedPrice = lastTradedPrice;
public Integer getLastTradedQuantity() {
return lastTradedQuantity;
public void setLastTradedQuantity(Integer lastTradedQuantity) {
this.lastTradedQuantity = lastTradedQuantity;
public Double getOpenPrice() {
return openPrice;
public void setOpenPrice(Double openPrice) {
this.openPrice = openPrice;
public Double getHighPrice() {
return highPrice;
public void setHighPrice(Double highPrice) {
this.highPrice = highPrice;
public Double getLowPrice() {
return lowPrice;
public void setLowPrice(Double lowPrice) {
this.lowPrice = lowPrice;
public Integer getTotalTradedQuantity() {
return totalTradedQuantity;
public void setTotalTradedQuantity(Integer totalTradedQuantity) {
this.totalTradedQuantity = totalTradedQuantity;
public Integer getTotalTradedVolume() {
return totalTradedVolume;
public void setTotalTradedVolume(Integer totalTradedVolume) {
this.totalTradedVolume = totalTradedVolume;
public String getExchange() {
return exchange;
public void setExchange(String exchange) {
this.exchange = exchange;
public Double getBrokerageCharge() {
return brokerageCharge;
public void setBrokerageCharge(Double brokerageCharge) {
this.brokerageCharge = brokerageCharge;
public Double getPreviousClose() {
return previousClose;
public void setPreviousClose(Double previousClose) {
this.previousClose = previousClose;
public Double getChnge() {
return chnge;
public void setChnge(Double chnge) {
this.chnge = chnge;
public Double getChngePer() {
return chngePer;
public void setChngePer(Double chngePer) {
this.chngePer = chngePer;
public Double getHoldValue() {
return holdValue;
public void setHoldValue(Double holdValue) {
this.holdValue = holdValue;
public Date getLastTradeDate() {
return lastTradeDate;
public void setLastTradeDate(Date lastTradeDate) {
this.lastTradeDate = lastTradeDate;
@XmlTransient
public Collection<UserStock> getUserStockCollection() {
return userStockCollection;
public void setUserStockCollection(Collection<UserStock> userStockCollection) {
this.userStockCollection = userStockCollection;
@XmlTransient
public Collection<UserTrack> getUserTrackCollection() {
return userTrackCollection;
public void setUserTrackCollection(Collection<UserTrack> userTrackCollection) {
this.userTrackCollection = userTrackCollection;
public CommoditySubCategoryMaster getCommoditySubCategoryID() {
return commoditySubCategoryID;
public void setCommoditySubCategoryID(CommoditySubCategoryMaster commoditySubCategoryID) {
this.commoditySubCategoryID = commoditySubCategoryID;
@XmlTransient
public Collection<OrderStock> getOrderStockCollection() {
return orderStockCollection;
public void setOrderStockCollection(Collection<OrderStock> orderStockCollection) {
this.orderStockCollection = orderStockCollection;
@XmlTransient
public Collection<TradeStock> getTradeStockCollection() {
return tradeStockCollection;
public void setTradeStockCollection(Collection<TradeStock> tradeStockCollection) {
this.tradeStockCollection = tradeStockCollection;
public int hashCode() {
int hash = 0;
hash += (scripID != null ? scripID.hashCode() : 0);
return hash;
public boolean equals(Object object) {
// TODO: Warning - this method won't work in the case the id fields are not set
if (!(object instanceof ScripMaster)) {
return false;
ScripMaster other = (ScripMaster) object;
if ((this.scripID == null && other.scripID != null) || (this.scripID != null && !this.scripID.equals(other.scripID))) {
return false;
return true;
public String toString() {
return "entity.ScripMaster[ scripID=" + scripID + " ]";
what is the cause of this exception? how do i solve it?
Re: Internal Exception: java.lang.NoSuchFieldException [message #875457 is a reply to message #875452] |
Tue, 22 May 2012 19:30 |
> [snip]
This isn't a Java or JPA forum. You might have some success with the
Eclipse data tool forum, but your best bet is probably javaranch or
stackoverflow.
Current Time: Thu Sep 26 02:34:59 GMT 2024
Powered by FUDForum. Page generated in 0.09868 seconds
