| Unable to find Library file [message #114807] |
Tue, 10 August 2004 04:00  |
Originally posted by: alanbocutt.ntlworld.com
I am sure that I am doing something stupid here so some help would be
appreciated if possible.
I have two projects in my workspace one to create a library file and one
which uses this library for inclusion of some functions..
The library file compiles correctly but the executable fails saying that
it cant find the library archive.
I have the library file complete pathed in the linker section of the
executable project but the only error I get is that the library cannot be
found
| Re: Unable to find Library file [message #114887 is a reply to message #114860] |
Tue, 10 August 2004 11:52   |
Alan,
Usually, you spec the name of the library with the -l flag, and the
search path with the -L flag (i.e. -library and
-L/home/bocutta/workspace/library/Release). If you want to use the full
path as the argument to -l, I think you will want to format it as
-l/home/bocutta/workspace/library/Release/library.
Assuming you are using the managed build system, this is a problem that
is caused by the UI not stripping off the path and extension when you
browse to a library file. There's an open bug on it, 70274.
Alan Bocutt wrote:
> Sean
> this is the output that I get from the Linker
> **** Incremental build of configuration Debug for project chprn_parser ****
> make -k all
> Building target: chprn_parser
> gcc -static -ochprn_parser chprn_fun_parser.o
> -l/home/bocutta/workspace/library/Release/liblibrary.a
> /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../../../i686-pc -linux-gnu/bin/ld:
> cannot find -l/home/bocutta/workspace/library/Release/liblibrary.a
> collect2: ld returned 1 exit status
> make: *** [chprn_parser] Error 1
> make: Target `all' not remade because of errors.
> Build complete for project chprn_parser
> and this is the library location
> bocutta@jaguar Release $ ls -l
> total 96
> -rw-r--r-- 1 bocutta users 767 Aug 10 08:43 chprn_fun_asc2int_s.d
> -rw-r--r-- 1 bocutta users 2152 Aug 10 08:43 chprn_fun_asc2int_s.o
> -rw-r--r-- 1 bocutta users 1265 Aug 10 08:43 chprn_fun_asc2ip4_s.d
> -rw-r--r-- 1 bocutta users 2196 Aug 10 08:43 chprn_fun_asc2ip4_s.o
> -rw-r--r-- 1 bocutta users 1265 Aug 10 08:43 chprn_fun_asc2ip6_s.d
> -rw-r--r-- 1 bocutta users 2524 Aug 10 08:43 chprn_fun_asc2ip6_s.o
> -rw-r--r-- 1 bocutta users 767 Aug 10 08:43 chprn_fun_asc2num_s.d
> -rw-r--r-- 1 bocutta users 2168 Aug 10 08:43 chprn_fun_asc2num_s.o
> -rw-r--r-- 1 bocutta users 503 Aug 10 08:43 chprn_fun_instr.d
> -rw-r--r-- 1 bocutta users 1008 Aug 10 08:43 chprn_fun_instr.o
> -rw-r--r-- 1 bocutta users 1172 Aug 10 08:43 chprn_fun_parser_stack.d
> -rw-r--r-- 1 bocutta users 5528 Aug 10 08:43 chprn_fun_parser_stack.o
> -rw-r--r-- 1 bocutta users 635 Aug 10 08:43 chprn_fun_strings.d
> -rw-r--r-- 1 bocutta users 1172 Aug 10 08:43 chprn_fun_strings.o
> -rw-r--r-- 1 bocutta users 17706 Aug 10 08:43 liblibrary.a
> -rw-r--r-- 1 bocutta users 704 Aug 10 08:43 makefile
> -rw-r--r-- 1 bocutta users 663 Aug 10 08:43 objects.mk
> -rw-r--r-- 1 bocutta users 383 Aug 10 08:43 sources.mk
> -rw-r--r-- 1 bocutta users 1169 Aug 10 08:43 subdir.mk
> Thanks for your help
> Alan
> Sean Evoy wrote:
>>Alan,
>>Copy the linker output in your reply to the group. It might help us
>>diagnose the problem. Usually, it's something easy like a bad path, but
>>it could be the actual library you are telling the linker to link
>>against. Either way, it's easier to help with a real error output to
>>look at.
>>Sean
>>>found
| Re: Unable to find Library file [message #114978 is a reply to message #114887] |
Wed, 11 August 2004 02:22   |
Hi Sean
Thanks for your help this has solved my problem for me now just down to
debugging my code :)
Regs
Alan
Sean Evoy wrote:
> Alan,
> Alan Bocutt wrote:
> > Sean
> > make -k all
> > total 96
> > Alan
> > Sean Evoy wrote:
> >>Alan,
> >>look at.
> >>Sean
> >>>found
| Re: Unable to find Library file [message #117139 is a reply to message #114887] |
Wed, 25 August 2004 06:16  |
Originally posted by: toereki.web.de
Sean,
any workaround available ?
Andreas
Sean Evoy wrote:
> Alan,
> Alan Bocutt wrote:
>> Sean
>> make -k all Building target: chprn_parser
>> total 96
>> Alan
>> Sean Evoy wrote:
>>> Alan,
>>> but it could be the actual library you are telling the linker to link
>>> look at.
>>> Sean
>>>> one
>>>> that
>>>> cannot be
>>>> found
FUDForum. Page generated in 0.05126 seconds
