Re: HelpSystem in Tomcat + WAR [message #135824 is a reply to message #135152] |
Fri, 12 June 2009 08:21 |
Rüdiger Herrmann Messages: 581 Registered: July 2009 |
Markus,
I think this has been discussed here before. Please search this
newsgroup for "help in rap", "help system", "help webapp", ...
One note though, I think in the aforementioned example, the URL to
open the help browser is missing the servlet name.
Rüdiger
Markus Krüger wrote:
> is there a solution to this? The problem is, that the servlet is defined in
> "org.eclipse.help.webapp", so I can not change the registered servlets :-)
> Did you solve this Rainer?
> Any Ideas?
> " Rainer" <rbaumx@googlemail.com> schrieb im Newsbeitrag
> news:38d131d02f5199d4363ffd27a061b733$1@www.eclipse.org...
>> Hi all,
>> with the tips from this newsgroup it's easy to get the Eclipse Help System
>> running - in the IDE and Jetty as container. Unfortunately a deployement
>> in a self-fulfilling WAR under Tomcat seems to require some additional
>> steps that are not so obvious ... (for me!)
>> I've tried to deploy the demo of Rüdiger from
>> http://www.eclipse.org/newsportal/article.php?id=4912&gr oup=eclipse.technology.rap#4912.
>> In the Eclipse-IDE it works fine and under (a stand-alone) Tomcat the
>> application itself starts too.
>> The problem arises when the application triggers the help sytem with the
>> url String helpURL = "http://{0}:{1}/index.jsp". Even though the
>> webapp-bundle with the servlet registrations is active (and the extension
>> elements are available at runtime - I did a dump) the index.jsp is taken
>> from the webapp/ROOT directory, i.e. I see the start page of Tomcat.
>> Changing the name of the jsp to a unique name (unknown to Tomcat) hoping
>> that the registration <servlet
>> alias="/*.jsp"
>> class="org.eclipse.equinox.jsp.jasper.registry.JSPFactory:/ "
>> httpcontextId="help">
>> </servlet>
>> of the webapp extension would take care for the servlet only leads to a
>> "resource not available" HTTP message.
>> Seems that I haven't found the operative point yet!?! Can anyone give a
>> tip what's the missing link?
>> Many thanks & best regards
>> Rainer
>> Ps: my deployment consists of a WAR with the servletbridge and the
>> following bundles where org.eclipse.rap.help.integration_1.0.0 is the demo
>> application mentioned above.
>> osgi> ss
>> Framework is launched.
>> id State Bundle
>> 0 ACTIVE org.eclipse.osgi_3.5.0.v20080916-2300
>> Fragments=42
>> 1 ACTIVE org.eclipse.equinox.common_3.4.0.v20080421-2006
>> 2 ACTIVE org.eclipse.update.configurator_3.2.101.R33x_v20070810
>> 3 ACTIVE
>> org.eclipse.equinox.http.servletbridge_1.0.0.v20080427-0830
>> 4 ACTIVE
>> org.eclipse.equinox.http.registry_1.0.100.v20080427-0830
>> 5 ACTIVE org.eclipse.rap.help.integration_1.0.0
>> 6 ACTIVE javax.servlet.jsp_2.0.0.v200806031607
>> 7 ACTIVE javax.servlet_2.4.0.v200806031604
>> 8 ACTIVE
>> org.eclipse.equinox.http.servlet_1.0.100.v20080427-0830
>> 9 ACTIVE org.apache.jasper_5.5.17.v200806031609
>> 10 ACTIVE
>> org.eclipse.equinox.jsp.jasper.registry_1.0.0.v20080427-0830
>> 11 ACTIVE org.eclipse.equinox.jsp.jasper_1.0.100.v20080427-0830
>> 12 ACTIVE org.apache.lucene.analysis_1.9.1.v200706181610
>> 13 ACTIVE org.apache.lucene_1.9.1.v200706111724
>> 14 ACTIVE org.eclipse.help.appserver_3.1.200.v20070510
>> 15 ACTIVE org.eclipse.help.base_3.3.1.v20070813_33x
>> 16 ACTIVE org.eclipse.help.webapp_3.3.2.v20071102_33x
>> 17 ACTIVE org.eclipse.help_3.3.2.v20071126_33x
>> 18 <<LAZY>> com.ibm.icu_3.8.1.v20080530
>> 21 RESOLVED org.apache.commons.el_1.0.0.v200806031608
>> 25 RESOLVED org.eclipse.core.commands_3.4.0.I20080509-2000
>> 26 <<LAZY>> org.eclipse.core.contenttype_3.3.0.v20080604-1400
>> 27 RESOLVED
>> org.eclipse.core.databinding.beans_1.2.0.I20080915-1800
>> 28 ACTIVE org.eclipse.core.databinding_1.2.0.I20080917-1800
>> 29 ACTIVE org.eclipse.core.expressions_3.4.100.v20080915-0800
>> 30 ACTIVE org.eclipse.core.jobs_3.4.100.v20080825
>> 31 ACTIVE org.eclipse.core.runtime_3.4.100.v20080714
>> 32 ACTIVE org.eclipse.equinox.app_1.2.0.v20080901
>> 34 <<LAZY>> org.eclipse.equinox.http.jetty_1.1.0.v20080425
>> 40 ACTIVE org.eclipse.equinox.preferences_3.2.300.v20080722-0430
>> 41 ACTIVE org.eclipse.equinox.registry_3.4.100.v20080722-0430
>> 42 RESOLVED
>> org.eclipse.equinox.servletbridge.extensionbundle_1.0.0
>> Master=0
>> 47 RESOLVED org.eclipse.osgi.services_3.1.200.v20071203
>> 50 RESOLVED org.eclipse.rap.jface.databinding_1.2.0.20081118-1809
>> 51 ACTIVE org.eclipse.rap.jface_1.2.0.200811271636
>> 52 RESOLVED org.eclipse.rap.rwt.q07_1.2.0.200811271636
>> Master=53
>> 53 RESOLVED org.eclipse.rap.rwt_1.2.0.200811271636
>> Fragments=52
>> 54 ACTIVE org.eclipse.rap.ui.forms_1.2.0.20081118-1809
>> 55 <<LAZY>> org.eclipse.rap.ui.views_1.2.0.20081118-1809
>> 56 ACTIVE org.eclipse.rap.ui.workbench_1.2.0.20081118-1809
>> 57 ACTIVE org.eclipse.rap.ui_1.2.0.20081118-1809
>> 59 RESOLVED org.mortbay.jetty_5.1.14.v200806031611
>> 60 RESOLVED org.ops4j.pax.logging.pax-logging-api_1.1.1
>> (The effect is the same when I start all of the bundles.)
Re: HelpSystem in Tomcat + WAR [message #138034 is a reply to message #135824] |
Thu, 25 June 2009 22:24 |
Jorge Messages: 13 Registered: July 2009 |
Any solution?
I could not find anything useful to resolve this.
Rüdiger Herrmann wrote:
> Markus,
> Cheers,
> Rüdiger
>> Hi,
>> Any Ideas?
>>> Hi all,
>>> I've tried to deploy the demo of RÃŒdiger from
>>> alias="/*.jsp"
>>> </servlet>
>>> Rainer
>>> osgi> ss
>>> id State Bundle
>>> Fragments=42
>>> 3 ACTIVE
>>> 4 ACTIVE
>>> 8 ACTIVE
>>> 10 ACTIVE
>>> 27 RESOLVED
>>> 42 RESOLVED
>>> Master=0
>>> Master=53
>>> Fragments=52
Any Solution?
I could not find nothing that can be usefull to solve this in this group.
FUDForum. Page generated in 0.03199 seconds
