| Eclipse-CDT startup error "Java heap space" [message #872041] |
Tue, 15 May 2012 07:07  |
I have freshly installed Ubuntu 12.04 LTS on a PC with 6GB of RAM.
I then installed Eclipse Indigo and then the CDT addon.
When I start the Eclipse-CDT IDE it immediately crashes with the following message:
'Project Explorer' has encountered a problem
An internal error has occured
Java heap space
Here is the log...
java.lang.OutOfMemoryError: Java heap space
at org.eclipse.ui.part.ResourceTransfer.nativeToJava(ResourceTransfer.java:162)
at org.eclipse.swt.dnd.Clipboard.getContents(Clipboard.java:323)
at org.eclipse.swt.dnd.Clipboard.getContents(Clipboard.java:241)
at org.eclipse.cdt.internal.ui.cview.PasteAction$1.run(PasteAction.java:174)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4330)
at org.eclipse.cdt.internal.ui.cview.PasteAction.updateSelection(PasteAction.java:170)
at org.eclipse.ui.actions.BaseSelectionListenerAction.selectionChangedBaseSelectionListenerAction.java:124)
at org.eclipse.cdt.internal.ui.cview.RefactorActionGroup.updateActionBarsRefactorActionGroup.java:149)
at org.eclipse.cdt.internal.ui.cview.MainActionGroup.updateActionBarsMainActionGroup.java:313)
at org.eclipse.cdt.internal.ui.cview.CView.updateActionBars(CView.java:779)
at org.eclipse.cdt.internal.ui.cview.CView.createPartControl(CView.java:554)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:375)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPartWorkbenchPartReference.java:595)
at org.eclipse.ui.internal.Perspective.showView(Perspective.java:2245)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1145)
at org.eclipse.ui.internal.WorkbenchPage$20.run(WorkbenchPage.java:3921)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3918)
at org.eclipse.ui.handlers.ShowViewHandler.openView(ShowViewHandler.java:162)
at org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHandler.java:76)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecksParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommandHandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommandSlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelectionCommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEventCommandContributionItem.java:805)
Here is the session data...
eclipse.buildId=I20110613-1736
java.version=1.7.0_03
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_GB
Command-line arguments: -os linux -ws gtk -arch x86
I have tried increasing the Java Heap space, but this did not help.
I even tried a upgrading the Java version to 1.7, but there was no improvement.
Here is the contents of my /etc/eclipse.ini file
-startup
plugins/org.eclipse.equinox.launcher_1.2.0.dist.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.100.dist
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
512m
--launcher.defaultAction
openFile
-vmargs
-Xms512m
-Xmx1024m
-XX:MaxPermSize=512M
-Dorg.eclipse.equinox.p2.reconciler.dropins.directory=/usr/share/eclipse/dropins
-XX:-UseCompressedOops
NB: Whilst this may be a red-herring, I access this headless PC using VNC.
NB: I also see the following error in the logs...
String index out of range: -7
java.lang.StringIndexOutOfBoundsException: String index out of range: -7
at java.lang.String.substring(String.java:1949)
at java.lang.String.substring(String.java:1916)
at org.eclipse.cdt.managedbuilder.internal.core.AdditionalInput$1LibFilter.acceptAdditionalInput.java:488)
at org.eclipse.cdt.managedbuilder.internal.core.AdditionalInput.findLibraryAdditionalInput.java:522)
at org.eclipse.cdt.managedbuilder.internal.core.AdditionalInput.getDepLibsAdditionalInput.java:457)
at org.eclipse.cdt.managedbuilder.internal.core.AdditionalInput.dependencyChangedAdditionalInput.java:405)
at org.eclipse.cdt.managedbuilder.internal.core.AdditionalInput.needsRebuildAdditionalInput.java:343)
at org.eclipse.cdt.managedbuilder.internal.core.InputType.needsRebuildInputType.java:1619)
at org.eclipse.cdt.managedbuilder.internal.core.Tool.needsRebuild(Tool.java:3307)
at org.eclipse.cdt.managedbuilder.internal.core.ToolChain.needsRebuildToolChain.java:2068)
at org.eclipse.cdt.managedbuilder.internal.core.ToolChain.saveRebuildStateToolChain.java:2101)
at org.eclipse.cdt.managedbuilder.internal.core.ToolChain.serialize(ToolChain.java:872)
at org.eclipse.cdt.managedbuilder.internal.core.FolderInfo.serialize(FolderInfo.java:385)
at org.eclipse.cdt.managedbuilder.internal.core.Configuration.serializeConfiguration.java:953)
at org.eclipse.cdt.managedbuilder.internal.dataprovider.ConfigurationDataProvider.writeConfigurationConfigurationDataProvider.java:124)
at org.eclipse.cdt.managedbuilder.internal.dataprovider.ConfigurationDataProvider.applyConfigurationConfigurationDataProvider.java:162)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.applyDataCProjectDescriptionManager.java:1124)
at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescriptionCache.applyDataCConfigurationDescriptionCache.java:137)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescription.applyDatasCProjectDescription.java:218)
at org.eclipse.cdt.internal.core.settings.model.SetCProjectDescriptionOperation.executeOperationSetCProjectDescriptionOperation.java:97)
at org.eclipse.cdt.internal.core.model.CModelOperation.execute(CModelOperation.java:339)
at org.eclipse.cdt.internal.core.model.CModelOperation.run(CModelOperation.java:602)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.cdt.internal.core.model.CModelOperation.runOperationCModelOperation.java:633)
at org.eclipse.cdt.internal.core.settings.model.AbstractCProjectDescriptionStorage.setProjectDescriptionAbstractCProjectDescriptionStorage.java:203)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionStorageManager.setProjectDescriptionCProjectDescriptionStorageManager.java:149)
at rg.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.setProjectDescriptionCProjectDescriptionManager.java:836)
at org.eclipse.cdt.managedbuilder.internal.core.BuildSettingsUtil.checkApplyDescriptionBuildSettingsUtil.java:211)
at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.updateCoreSettingsManagedBuildManager.java:1561)
at org.eclipse.cdt.build.internal.core.scannerconfig.CfgDiscoveredPathManager$1.runCfgDiscoveredPathManager.java:152)
at org.eclipse.cdt.internal.core.model.BatchOperation.executeOperationBatchOperation.java:36)
at org.eclipse.cdt.core.model.CoreModel.run(CoreModel.java:1233)
at org.eclipse.cdt.core.model.CoreModel.run(CoreModel.java:1190)
at org.eclipse.cdt.build.internal.core.scannerconfig.CfgDiscoveredPathManager.updateCoreSettingsCfgDiscoveredPathManager.java:155)
at org.eclipse.cdt.build.core.scannerconfig.ScannerConfigBuilder.buildScannerConfigBuilder.java:124)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Nicholas Lee
| Re: Eclipse-CDT startup error "Java heap space" [message #880960 is a reply to message #878053] |
Sun, 03 June 2012 09:45   |
On 05/28/2012 02:27 PM, Nicholas Lee wrote:
> It may be due to something else, but it is Eclipse CDT that reports the
> error message, not x11vnc.
> In the problem described at the link you gave (I.e. Q-71), x11vnc itself
> fails with an error message, and I am not seeing that happen.
True that. On the other side:
1) it mentions shared memory. If I understand correctly x11vnc and
Eclipse run on the same machine, so if Eclipse uses shared memory (which
might be the case with copy and paste) it could be a problem. Also, the
way that question starts "I have lots of memory", got me thinking. And
it's strange how Eclipse is giving memory problems exactly in the moment
you use x11vnc.
I have never tried it, but maybe you can monitor your memory, shared and
not, using one of the /proc files. Look here:
http://linux.die.net/man/5/proc
/proc/meminfo seems to be quite interesting. And in /proc you can also
change the amount of shared memory slots
2) if the problem is not with Eclipse it might be worth looking
somewhere else. If there is another option to consider I would consider
it, no matter where the error comes from.
FUDForum. Page generated in 0.07964 seconds
