Proper use of libraries [message #871639] |
Mon, 14 May 2012 11:43  |
I have several transformations with partial functional overlaps. The
shared mappings/queries are in several libraries. Loading and modifying
one of the toplevel scripts is now very slow (the qvt compiler/analyzer
takes a lot of time until the syntax coloring is done). I'm wondering if
I'm using the library facility correctly:
Transformation:
import LibA;
LibA:
import LibB;
import LibC;
LibB:
import a;
import b;
import c;
LibC:
import LibD;
LibD:
import a;
import b;
import c;
liba, libb, libc contain no further imports
Each library contains a number of "modeltype ... uses ..." statements.
Specifically, I'm not sure whether:
- it's ok that essential liba, libb and libc are referenced twice in the
above example. Is that ok? Is there a way around it?
- it's ok that all units are referencing the modeltypes over and over again.
I've tried to understand the spec wrt this, but so far I could not find
what I might do differently.
Any hints?
Marius
Re: Proper use of libraries [message #873446 is a reply to message #873425] |
Fri, 18 May 2012 04:58  |
If you can produce a simple repro for the deficiency, please raise a
Bugzilla. I can't promise a rapid
response but ultimately the repro may become a JUnit for future code.
Ed Willink
On 18/05/2012 08:59, Marius Gröger wrote:
> Hello Ed,
> On 17.05.2012 20:56, Ed Willink wrote:
>> I suspect you're at the boundary of usage and identifying limitations
>> that could be addressed by the specification/tool.
>> My only suggestion is to remodularize to see if you can eliminate some
>> of the sharing that you suspect may be a problem.
> I'm now pretty sure that there is some underlying inefficiency in the
> library handling that somehow causes the compiler to run through the
> included libraries multiple times. So indeed my best option is to
> optimize the sharing as much as possible, and to avoid multiple levels
> of inclusion where possible.
> Thanks for answering anyway!
> Marius
FUDForum. Page generated in 0.03687 seconds
