Home » Eclipse Projects » EclipseLink » stackOverFlowError
Re: stackOverFlowError [message #871706 is a reply to message #871690] |
Mon, 14 May 2012 17:56 |
Chris V Messages: 10 Registered: February 2012 |
When I removed the "MappedBy" parm in CpTransaction, I get the following error
Internal Exception: java.sql.SQLException: [SQL0205] Column CPTERRORISMCOVERAGE_COVERAGE_ID not in table CP_COVERAGE in WBQUOTEVI.
Error Code: -205
Call: SELECT t1.COVERAGE_ID, t1.COVERAGE_TYPE, t1.BUILDING_NUMBER, t1.COV_GROUP, t1.COVERAGE_CLASS_CODE, t1.COVERAGE_CODE, t1.COVERAGE_DESC, t1.FORM_NUMBER, t1.LIABILITY_LIMIT, t1.LOB_CODE, t1.LOCATION_NUMBER, t1.PREMIUM_ACTUAL, t1.PREMIUM_MEET_MIN, t1.PREMIUM_MIN, t1.PREMIUM_OVERRIDE, t1.PREMIUM_OVERRIDE_RESET, t1.PREMIUM_PREVIOUS, t1.PREMIUM_PREVIOUS_PRO, t1.RATED_COVERAGE_FLAG, t1.RATING_MODIFIED_RATE, t1.RATING_ORIGINAL_RATE, t1.RATING_RMF, t1.SORT_SEQ, t1.STATE_CODE, t1.SUBCOVERAGE_DESC, t1.ACTION_CODE, t1.BLANKET_ID, t1.PARENT_ID FROM CP_COVERAGE t0, CP_COVERAGE t1 WHERE (((t0.PARENT_ID = ?) AND (t1.COVERAGE_ID = t0.cpTerrorismCoverage_COVERAGE_ID)) AND (t1.COVERAGE_TYPE = ?))
bind => [81111, P]
Query: ReadObjectQuery(name="cpTerrorismCoverage" referenceClass=CpTransCoverage sql="SELECT t1.COVERAGE_ID, t1.COVERAGE_TYPE, t1.BUILDING_NUMBER, t1.COV_GROUP, t1.COVERAGE_CLASS_CODE, t1.COVERAGE_CODE, t1.COVERAGE_DESC, t1.FORM_NUMBER, t1.LIABILITY_LIMIT, t1.LOB_CODE, t1.LOCATION_NUMBER, t1.PREMIUM_ACTUAL, t1.PREMIUM_MEET_MIN, t1.PREMIUM_MIN, t1.PREMIUM_OVERRIDE, t1.PREMIUM_OVERRIDE_RESET, t1.PREMIUM_PREVIOUS, t1.PREMIUM_PREVIOUS_PRO, t1.RATED_COVERAGE_FLAG, t1.RATING_MODIFIED_RATE, t1.RATING_ORIGINAL_RATE, t1.RATING_RMF, t1.SORT_SEQ, t1.STATE_CODE, t1.SUBCOVERAGE_DESC, t1.ACTION_CODE, t1.BLANKET_ID, t1.PARENT_ID FROM CP_COVERAGE t0, CP_COVERAGE t1 WHERE (((t0.PARENT_ID = ?) AND (t1.COVERAGE_ID = t0.cpTerrorismCoverage_COVERAGE_ID)) AND (t1.COVERAGE_TYPE = ?))")} Local Exception Stack: ;Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.2.0.v20110202-r8913): org.eclipse.persistence.exceptions.DatabaseException;Internal Exception: java.sql.SQLException: [SQL0205] Column CPTERRORISMCOVERAGE_COVERAGE_ID not in table CP_COVERAGE in WBQUOTEVI.;Error Code: -205;Call: SELECT t1.COVERAGE_ID, t1.COVERAGE_TYPE, t1.BUILDING_NUMBER, t1.COV_GROUP, t1.COVERAGE_CLASS_CODE, t1.COVERAGE_CODE, t1.COVERAGE_DESC, t1.FORM_NUMBER, t1.LIABILITY_LIMIT, t1.LOB_CODE, t1.LOCATION_NUMBER, t1.PREMIUM_ACTUAL, t1.PREMIUM_MEET_MIN, t1.PREMIUM_MIN, t1.PREMIUM_OVERRIDE, t1.PREMIUM_OVERRIDE_RESET, t1.PREMIUM_PREVIOUS, t1.PREMIUM_PREVIOUS_PRO, t1.RATED_COVERAGE_FLAG, t1.RATING_MODIFIED_RATE, t1.RATING_ORIGINAL_RATE, t1.RATING_RMF, t1.SORT_SEQ, t1.STATE_CODE, t1.SUBCOVERAGE_DESC, t1.ACTION_CODE, t1.BLANKET_ID, t1.PARENT_ID FROM CP_COVERAGE t0, CP_COVERAGE t1 WHERE (((t0.PARENT_ID = ?) AND (t1.COVERAGE_ID = t0.cpTerrorismCoverage_COVERAGE_ID)) AND (t1.COVERAGE_TYPE = ?));bind => [81111, P];Query: ReadObjectQuery(name="cpTerrorismCoverage" referenceClass=CpTransCoverage sql="SELECT t1.COVERAGE_ID, t1.COVERAGE_TYPE, t1.BUILDING_NUMBER, t1.COV_GROUP, t1.COVERAGE_CLASS_CODE, t1.COVERAGE_CODE, t1.COVERAGE_DESC, t1.FORM_NUMBER, t1.LIABILITY_LIMIT, t1.LOB_CODE, t1.LOCATION_NUMBER, t1.PREMIUM_ACTUAL, t1.PREMIUM_MEET_MIN, t1.PREMIUM_MIN, t1.PREMIUM_OVERRIDE, t1.PREMIUM_OVERRIDE_RESET, t1.PREMIUM_PREVIOUS, t1.PREMIUM_PREVIOUS_PRO, t1.RATED_COVERAGE_FLAG, t1.RATING_MODIFIED_RATE, t1.RATING_ORIGINAL_RATE, t1.RATING_RMF, t1.SORT_SEQ, t1.STATE_CODE, t1.SUBCOVERAGE_DESC, t1.ACTION_CODE, t1.BLANKET_ID, t1.PARENT_ID FROM CP_COVERAGE t0, CP_COVERAGE t1 WHERE (((t0.PARENT_ID = ?) AND (t1.COVERAGE_ID = t0.cpTerrorismCoverage_COVERAGE_ID)) AND (t1.COVERAGE_TYPE = ?))");at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:333);at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:684);at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:526);at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:1729);at org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:566);at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:207);at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:193);at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectOneRow(DatasourceCallQueryMechanism.java:667);at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRowFromTable(ExpressionQueryMechanism.java:2603);at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRow(ExpressionQueryMechanism.java:2574);at org.eclipse.persistence.queries.ReadObjectQuery.executeObjectLevelReadQuery(ReadObjectQuery.java:444);at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1080);at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:808);at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1040);at org.eclipse.persistence.queries.ReadObjectQuery.execute(ReadObjectQuery.java:412);at org.eclipse.persistence.internal.sessions.AbstractSession.internalExecuteQuery(AbstractSession.java:2800);at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1521);at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1503);at org.eclipse.persistence.internal.indirection.NoIndirectionPolicy.valueFromQuery(NoIndirectionPolicy.java:323);at org.eclipse.persistence.mappings.ForeignReferenceMapping.valueFromRowInternal(ForeignReferenceMapping.java:2061);at org.eclipse.persistence.mappings.OneToOneMapping.valueFromRowInternal(OneToOneMapping.java:1635);at org.eclipse.persistence.mappings.ForeignReferenceMapping.valueFromRow(ForeignReferenceMapping.java:1950);at org.eclipse.persistence.mappings.ForeignReferenceMapping.readFromRowIntoObject(ForeignReferenceMapping.java:1332);at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildAttributesIntoObject(ObjectBuilder.java:344);at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:694);at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildWorkingCopyCloneNormally(ObjectBuilder.java:612);at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObjectInUnitOfWork(ObjectBuilder.java:565);at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:497);at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:456);at org.eclipse.persistence.queries.ObjectLevelReadQuery.buildObject(ObjectLevelReadQuery.java:723);at org.eclipse.persistence.queries.ReadAllQuery.registerResultInUnitOfWork(ReadAllQuery.java:742);at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:423);at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1080);at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:808);at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1040);at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:383);at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1126);at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2842);at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1521);at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1503);at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1477);at org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:484);at org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultList(EJBQueryImpl.java:741);at com.gmrc.jpa.domain.controller.CpTransactionManagerImpl.findByProperty(CpTransactionManagerImpl.java:921);at com.gmrc.jpa.domain.controller.CpTransactionManagerImpl.findByPolicyNumber(CpTransactionManagerImpl.java:750);at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method);at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60);at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37);at java.lang.reflect.Method.invoke(Method.java:611);at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307);at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182);at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149);at org.springframework.dao.support.PersistenceExceptionTranslationInterceptor.invoke(PersistenceExceptionTranslationInterceptor.java:138);at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171);at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:106);at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171);at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204);at $Proxy122.findByPolicyNumber(Unknown Source);at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method);at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60);at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37);at java.lang.reflect.Method.invoke(Method.java:611);at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307);at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:198);at $Proxy123.findByPolicyNumber(Unknown Source);at com.gmrc.jpa.domain.service.ManagedCpTransactionService.isLastTransactionCheck(ManagedCpTransactionService.java:138);at com.gmrc.cpp.struts.actions.OpenAction.open(OpenAction.java:142);at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method);at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60);at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37);at java.lang.reflect.Method.invoke(Method.java:611);at com.gmrc.cpp.struts.actions.CppBaseAction.dispatchMethod(CppBaseAction.java:962);at com.gmrc.cpp.struts.actions.CppBaseAction.execute(CppBaseAction.java:330);at org.springframework.web.struts.DelegatingActionProxy.execute(DelegatingActionProxy.java:110);at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431);at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236);at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196);at org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:414);at javax.servlet.http.HttpServlet.service(HttpServlet.java:575);at javax.servlet.http.HttpServlet.service(HttpServlet.java:668);at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1214);at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:774);at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:456);at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178);at com.ibm.ws.webcontainer.filter.WebAppFilterChain.invokeTarget(WebAppFilterChain.java:125);at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:92);at org.ajaxanywhere.AAFilter.doFilter(AAFilter.java:46);at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:192);at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:89);at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:926);at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1023);at com.ibm.ws.webcontainer.webapp.WebApp.handleRequest(WebApp.java:3703);at com.ibm.ws.webcontainer.webapp.WebGroup.handleRequest(WebGroup.java:304);at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:962);at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1662);at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:195);at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:452);at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:511);at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:305);at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:83);at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:165);at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217);at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161);at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138);at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204);at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775);at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905);at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1659);Caused by: java.sql.SQLException: [SQL0205] Column CPTERRORISMCOVERAGE_COVERAGE_ID not in table CP_COVERAGE in WBQUOTEVI.;at com.ibm.as400.access.JDError.throwSQLException(JDError.java:650);at com.ibm.as400.access.JDError.throwSQLException(JDError.java:621);at com.ibm.as400.access.AS400JDBCStatement.commonPrepare(AS400JDBCStatement.java:1557);at com.ibm.as400.access.AS400JDBCPreparedStatement.<init>(AS400JDBCPreparedStatement.java:193);at com.ibm.as400.access.AS400JDBCConnection.prepareStatement(AS400JDBCConnection.java:2025);at com.ibm.as400.access.AS400JDBCConnection.prepareStatement(AS400JDBCConnection.java:1967);at com.ibm.as400.access.AS400JDBCConnectionHandle.prepareStatement(AS400JDBCConnectionHandle.java:915);at com.ibm.ws.rsadapter.jdbc.WSJdbcConnection.pmiPrepareStatement(WSJdbcConnection.java:2530);at com.ibm.ws.rsadapter.jdbc.WSJdbcConnection.prepareStatement(WSJdbcConnection.java:2775);at com.ibm.ws.rsadapter.jdbc.WSJdbcConnection.prepareStatement(WSJdbcConnection.java:2723);at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.prepareStatement(DatabaseAccessor.java:1402);at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.prepareStatement(DatabaseAccessor.java:1351);at org.eclipse.persistence.internal.databaseaccess.DatabaseCall.prepareStatement(DatabaseCall.java:658);at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:576);... 106 more;
Current Time: Fri Apr 26 23:09:49 GMT 2024
Powered by FUDForum. Page generated in 0.03946 seconds
