Home » Eclipse Projects » Gemini » [Gemini JPA] Gemini JPA and e4 : *** FATAL ERROR *** Could not load domain class in p-unit(*** FATAL ERROR *** Could not load domain class in p-unit in E4)
[Gemini JPA] Gemini JPA and e4 : *** FATAL ERROR *** Could not load domain class in p-unit [message #871403] Sun, 13 May 2012 07:38 Go to next message
I'm having trouble developing persistence for my first RCP application.
I am using the following configuration
- Eclipse 4.2 M6
- Apache Derby
- Gemini DBAccess
- Gemini JPA
- DI Injection plugin for Gemini as seen here github.com/muuki88/e4GeminiJPA and here -www.eclipse.org/forums/index.php/mv/msg/290891/797712/
The sample application from github.com/muuki88/e4GeminiJPA works fine on my system.
The start order and autostart of plugins in my product is correct according to : wiki.eclipse.org/Gemini/JPA/Documentation/OtherTopics
However, I end up having this problem, which i don't know how to solve.
Here is the full trace :
Gemini DBAccess Derby starting
!SESSION 2012-05-13 12:24:20.358 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_04
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=fr_FR
Framework arguments:  -product org.crubier.dynamo.plugin.core.product -clearPersistedState
Command-line arguments:  -product org.crubier.dynamo.plugin.core.product -data /Users/vincent/workspaceDynamo/../runtime-Dynamo.product -dev file:/Users/vincent/workspaceDynamo/.metadata/.plugins/org.eclipse.pde.core/Dynamo.product/dev.properties -os macosx -ws cocoa -arch x86_64 -consoleLog -clearPersistedState
!ENTRY org.eclipse.osgi 2 0 2012-05-13 12:24:25.738
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-05-13 12:24:25.738
!MESSAGE Bundle org.crubier.dynamo.plugin.dataview_1.0.0 [143] was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-05-13 12:24:25.739
!MESSAGE Bundle org.crubier.dynamo.plugin.data_1.0.0 [154] was not resolved.
[EL Finest]: jpa: 2012-05-13 12:24:26.001--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Begin predeploying Persistence Unit org.crubier.dynamo.db; session org.crubier.dynamo.db; state Initial; factoryCount 0
[EL Finest]: properties: 2012-05-13 12:24:26.108--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--property=eclipselink.orm.throw.exceptions; default value=true
[EL Finest]: properties: 2012-05-13 12:24:26.108--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--property=eclipselink.weaving.changetracking; default value=true
[EL Finest]: properties: 2012-05-13 12:24:26.108--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--property=eclipselink.weaving.lazy; default value=true
[EL Finest]: properties: 2012-05-13 12:24:26.108--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--property=eclipselink.weaving.eager; default value=false
[EL Finest]: properties: 2012-05-13 12:24:26.108--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--property=eclipselink.weaving.fetchgroups; default value=true
[EL Finest]: properties: 2012-05-13 12:24:26.109--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--property=eclipselink.weaving.internal; default value=true
[EL Finest]: properties: 2012-05-13 12:24:26.109--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--property=eclipselink.multitenant.tenants-share-emf; default value=true
[EL Finest]: properties: 2012-05-13 12:24:26.109--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--property=eclipselink.multitenant.tenants-share-cache; default value=false
[EL Finer]: metadata: 2012-05-13 12:24:26.123--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Searching for default mapping file in bundleentry://154.fwk2072777878 (There is no English translation for this message.)
[EL Config]: metadata: 2012-05-13 12:24:26.41--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The access type for the persistent class [class org.crubier.dynamo.plugin.data.datarecord.DataRecord1D] is set to [FIELD].
[EL Config]: metadata: 2012-05-13 12:24:26.452--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The element [field stats] is being defaulted to a one to one mapping.
[EL Config]: metadata: 2012-05-13 12:24:26.46--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target entity (reference) class for the one to one mapping element [field stats] is being defaulted to: class org.crubier.dynamo.plugin.data.datastats.DataStatistics.
[EL Config]: metadata: 2012-05-13 12:24:26.461--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The element [field dataItems] is being defaulted to a one to many mapping.
[EL Config]: metadata: 2012-05-13 12:24:26.466--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target entity (reference) class for the one to many mapping element [field dataItems] is being defaulted to: class org.crubier.dynamo.plugin.data.dataitem.DataItemMatrix1D.
[EL Config]: metadata: 2012-05-13 12:24:26.467--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The access type for the persistent class [class org.crubier.dynamo.plugin.data.dataitem.DataItem] is set to [FIELD].
[EL Config]: metadata: 2012-05-13 12:24:26.467--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The element [field dataType] is being defaulted to a one to one mapping.
[EL Config]: metadata: 2012-05-13 12:24:26.468--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target entity (reference) class for the one to one mapping element [field dataType] is being defaulted to: class org.crubier.dynamo.plugin.data.datatype.DataType.
[EL Config]: metadata: 2012-05-13 12:24:26.468--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The element [field dataGroup] is being defaulted to a one to one mapping.
[EL Config]: metadata: 2012-05-13 12:24:26.468--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target entity (reference) class for the one to one mapping element [field dataGroup] is being defaulted to: class org.crubier.dynamo.plugin.data.datagroup.DataGroup.
[EL Config]: metadata: 2012-05-13 12:24:26.468--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The access type for the persistent class [class org.crubier.dynamo.plugin.data.dataitem.DataItemString] is set to [FIELD].
[EL Config]: metadata: 2012-05-13 12:24:26.469--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The access type for the persistent class [class org.crubier.dynamo.plugin.data.dataitem.DataItemDouble] is set to [FIELD].
[EL Config]: metadata: 2012-05-13 12:24:26.47--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The access type for the persistent class [class org.crubier.dynamo.plugin.data.dataitem.DataItemDate] is set to [FIELD].
[EL Config]: metadata: 2012-05-13 12:24:26.471--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The access type for the persistent class [class org.crubier.dynamo.plugin.data.dataitem.DataItemMatrix1D] is set to [FIELD].
[EL Config]: metadata: 2012-05-13 12:24:26.471--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The element [field matrix1DStats] is being defaulted to a one to one mapping.
[EL Config]: metadata: 2012-05-13 12:24:26.471--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target entity (reference) class for the one to one mapping element [field matrix1DStats] is being defaulted to: class org.crubier.dynamo.plugin.data.datastats.DataStatistics.
[EL Config]: metadata: 2012-05-13 12:24:26.472--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The element [field matrix1DRecord] is being defaulted to a one to one mapping.
[EL Config]: metadata: 2012-05-13 12:24:26.472--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target entity (reference) class for the one to one mapping element [field matrix1DRecord] is being defaulted to: class org.crubier.dynamo.plugin.data.datarecord.DataRecord1D.
[EL Config]: metadata: 2012-05-13 12:24:26.473--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The access type for the persistent class [class org.crubier.dynamo.plugin.data.datatype.DataType] is set to [FIELD].
[EL Config]: metadata: 2012-05-13 12:24:26.473--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The element [field dataItems] is being defaulted to a one to many mapping.
[EL Config]: metadata: 2012-05-13 12:24:26.473--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target entity (reference) class for the one to many mapping element [field dataItems] is being defaulted to: class org.crubier.dynamo.plugin.data.dataitem.DataItem.
[EL Config]: metadata: 2012-05-13 12:24:26.474--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The access type for the persistent class [class org.crubier.dynamo.plugin.data.datatype.DataTypePhysical] is set to [FIELD].
[EL Config]: metadata: 2012-05-13 12:24:26.475--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The access type for the persistent class [class org.crubier.dynamo.plugin.data.dataitem.DataItemInteger] is set to [FIELD].
[EL Config]: metadata: 2012-05-13 12:24:26.475--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The access type for the persistent class [class org.crubier.dynamo.plugin.data.datastats.DataStatistics] is set to [FIELD].
[EL Config]: metadata: 2012-05-13 12:24:26.476--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The access type for the persistent class [class org.crubier.dynamo.plugin.data.datagroup.DataGroup] is set to [FIELD].
[EL Config]: metadata: 2012-05-13 12:24:26.477--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The element [field dataItems] is being defaulted to a one to many mapping.
[EL Config]: metadata: 2012-05-13 12:24:26.477--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target entity (reference) class for the one to many mapping element [field dataItems] is being defaulted to: class org.crubier.dynamo.plugin.data.dataitem.DataItem.
[EL Config]: metadata: 2012-05-13 12:24:26.477--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The alias name for the entity class [class org.crubier.dynamo.plugin.data.datarecord.DataRecord1D] is being defaulted to: DataRecord1D.
[EL Config]: metadata: 2012-05-13 12:24:26.48--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The table name for entity [class org.crubier.dynamo.plugin.data.datarecord.DataRecord1D] is being defaulted to: DATARECORD1D.
[EL Config]: metadata: 2012-05-13 12:24:26.536--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [id] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.537--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [content] is being defaulted to: CONTENT.
[EL Config]: metadata: 2012-05-13 12:24:26.547--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [unit] is being defaulted to: UNIT.
[EL Config]: metadata: 2012-05-13 12:24:26.549--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The alias name for the entity class [class org.crubier.dynamo.plugin.data.dataitem.DataItemString] is being defaulted to: DataItemString.
[EL Config]: metadata: 2012-05-13 12:24:26.549--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The alias name for the entity class [class org.crubier.dynamo.plugin.data.dataitem.DataItem] is being defaulted to: DataItem.
[EL Config]: metadata: 2012-05-13 12:24:26.549--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The table name for entity [class org.crubier.dynamo.plugin.data.dataitem.DataItem] is being defaulted to: DATAITEM.
[EL Config]: metadata: 2012-05-13 12:24:26.559--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [id] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.56--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [stringValue] is being defaulted to: STRINGVALUE.
[EL Config]: metadata: 2012-05-13 12:24:26.56--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The alias name for the entity class [class org.crubier.dynamo.plugin.data.dataitem.DataItemDouble] is being defaulted to: DataItemDouble.
[EL Config]: metadata: 2012-05-13 12:24:26.56--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [doubleValue] is being defaulted to: DOUBLEVALUE.
[EL Config]: metadata: 2012-05-13 12:24:26.561--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The alias name for the entity class [class org.crubier.dynamo.plugin.data.dataitem.DataItemDate] is being defaulted to: DataItemDate.
[EL Config]: metadata: 2012-05-13 12:24:26.561--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [dateValue] is being defaulted to: DATEVALUE.
[EL Config]: metadata: 2012-05-13 12:24:26.562--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The alias name for the entity class [class org.crubier.dynamo.plugin.data.dataitem.DataItemMatrix1D] is being defaulted to: DataItemMatrix1D.
[EL Config]: metadata: 2012-05-13 12:24:26.562--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [matrix1DWidth] is being defaulted to: MATRIX1DWIDTH.
[EL Config]: metadata: 2012-05-13 12:24:26.563--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [matrix1DPosition] is being defaulted to: MATRIX1DPOSITION.
[EL Config]: metadata: 2012-05-13 12:24:26.563--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The alias name for the entity class [class org.crubier.dynamo.plugin.data.datatype.DataTypePhysical] is being defaulted to: DataTypePhysical.
[EL Config]: metadata: 2012-05-13 12:24:26.563--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The alias name for the entity class [class org.crubier.dynamo.plugin.data.datatype.DataType] is being defaulted to: DataType.
[EL Config]: metadata: 2012-05-13 12:24:26.563--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The table name for entity [class org.crubier.dynamo.plugin.data.datatype.DataType] is being defaulted to: DATATYPE.
[EL Config]: metadata: 2012-05-13 12:24:26.564--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [id] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.564--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [description] is being defaulted to: DESCRIPTION.
[EL Config]: metadata: 2012-05-13 12:24:26.564--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [name] is being defaulted to: NAME.
[EL Config]: metadata: 2012-05-13 12:24:26.565--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [dimension] is being defaulted to: DIMENSION.
[EL Config]: metadata: 2012-05-13 12:24:26.565--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The alias name for the entity class [class org.crubier.dynamo.plugin.data.dataitem.DataItemInteger] is being defaulted to: DataItemInteger.
[EL Config]: metadata: 2012-05-13 12:24:26.565--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [integerValue] is being defaulted to: INTEGERVALUE.
[EL Config]: metadata: 2012-05-13 12:24:26.565--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The alias name for the entity class [class org.crubier.dynamo.plugin.data.datastats.DataStatistics] is being defaulted to: DataStatistics.
[EL Config]: metadata: 2012-05-13 12:24:26.565--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The table name for entity [class org.crubier.dynamo.plugin.data.datastats.DataStatistics] is being defaulted to: DATASTATISTICS.
[EL Config]: metadata: 2012-05-13 12:24:26.566--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [min] is being defaulted to: MIN.
[EL Config]: metadata: 2012-05-13 12:24:26.566--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [sumOfSquares] is being defaulted to: SUMOFSQUARES.
[EL Config]: metadata: 2012-05-13 12:24:26.566--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [kurtosis] is being defaulted to: KURTOSIS.
[EL Config]: metadata: 2012-05-13 12:24:26.566--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [max] is being defaulted to: MAX.
[EL Config]: metadata: 2012-05-13 12:24:26.567--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [rms] is being defaulted to: RMS.
[EL Config]: metadata: 2012-05-13 12:24:26.567--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [sum] is being defaulted to: SUM.
[EL Config]: metadata: 2012-05-13 12:24:26.567--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [variance] is being defaulted to: VARIANCE.
[EL Config]: metadata: 2012-05-13 12:24:26.567--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [size] is being defaulted to: SIZE.
[EL Config]: metadata: 2012-05-13 12:24:26.567--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [product] is being defaulted to: PRODUCT.
[EL Config]: metadata: 2012-05-13 12:24:26.567--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [id] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.568--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [median] is being defaulted to: MEDIAN.
[EL Config]: metadata: 2012-05-13 12:24:26.568--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [geometricMean] is being defaulted to: GEOMETRICMEAN.
[EL Config]: metadata: 2012-05-13 12:24:26.568--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [standardError] is being defaulted to: STANDARDERROR.
[EL Config]: metadata: 2012-05-13 12:24:26.568--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [standardDeviation] is being defaulted to: STANDARDDEVIATION.
[EL Config]: metadata: 2012-05-13 12:24:26.568--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [harmonicMean] is being defaulted to: HARMONICMEAN.
[EL Config]: metadata: 2012-05-13 12:24:26.569--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [mean] is being defaulted to: MEAN.
[EL Config]: metadata: 2012-05-13 12:24:26.569--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [skew] is being defaulted to: SKEW.
[EL Config]: metadata: 2012-05-13 12:24:26.569--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [sumOfInversions] is being defaulted to: SUMOFINVERSIONS.
[EL Config]: metadata: 2012-05-13 12:24:26.569--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The alias name for the entity class [class org.crubier.dynamo.plugin.data.datagroup.DataGroup] is being defaulted to: DataGroup.
[EL Config]: metadata: 2012-05-13 12:24:26.569--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The table name for entity [class org.crubier.dynamo.plugin.data.datagroup.DataGroup] is being defaulted to: DATAGROUP.
[EL Config]: metadata: 2012-05-13 12:24:26.57--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The column name for element [id] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.626--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The join table name for the many to many mapping [field dataItems] is being defaulted to: DATARECORD1D_DATAITEM.
[EL Config]: metadata: 2012-05-13 12:24:26.627--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The source primary key column name for the many to many mapping [field dataItems] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.627--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The source foreign key column name for the many to many mapping [dataItems] is being defaulted to: DataRecord1D_ID.
[EL Config]: metadata: 2012-05-13 12:24:26.628--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target primary key column name for the many to many mapping [field dataItems] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.628--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target foreign key column name for the many to many mapping [dataItems] is being defaulted to: dataItems_ID.
[EL Config]: metadata: 2012-05-13 12:24:26.64--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The primary key column name for the mapping element [field stats] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.64--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The foreign key column name for the mapping element [stats] is being defaulted to: STATS_ID.
[EL Config]: metadata: 2012-05-13 12:24:26.641--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The primary key column name for the mapping element [field dataType] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.641--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The foreign key column name for the mapping element [dataType] is being defaulted to: DATATYPE_ID.
[EL Config]: metadata: 2012-05-13 12:24:26.641--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The primary key column name for the mapping element [field dataGroup] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.641--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The foreign key column name for the mapping element [dataGroup] is being defaulted to: DATAGROUP_ID.
[EL Config]: metadata: 2012-05-13 12:24:26.642--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The primary key column name for the mapping element [field matrix1DStats] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.642--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The foreign key column name for the mapping element [matrix1DStats] is being defaulted to: MATRIX1DSTATS_ID.
[EL Config]: metadata: 2012-05-13 12:24:26.642--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The primary key column name for the mapping element [field matrix1DRecord] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.642--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The foreign key column name for the mapping element [matrix1DRecord] is being defaulted to: MATRIX1DRECORD_ID.
[EL Config]: metadata: 2012-05-13 12:24:26.643--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The join table name for the many to many mapping [field dataItems] is being defaulted to: DATATYPE_DATAITEM.
[EL Config]: metadata: 2012-05-13 12:24:26.643--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The source primary key column name for the many to many mapping [field dataItems] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.643--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The source foreign key column name for the many to many mapping [dataItems] is being defaulted to: DataType_ID.
[EL Config]: metadata: 2012-05-13 12:24:26.643--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target primary key column name for the many to many mapping [field dataItems] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.643--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target foreign key column name for the many to many mapping [dataItems] is being defaulted to: dataItems_ID.
[EL Config]: metadata: 2012-05-13 12:24:26.644--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The join table name for the many to many mapping [field dataItems] is being defaulted to: DATAGROUP_DATAITEM.
[EL Config]: metadata: 2012-05-13 12:24:26.644--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The source primary key column name for the many to many mapping [field dataItems] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.644--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The source foreign key column name for the many to many mapping [dataItems] is being defaulted to: DataGroup_ID.
[EL Config]: metadata: 2012-05-13 12:24:26.645--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target primary key column name for the many to many mapping [field dataItems] is being defaulted to: ID.
[EL Config]: metadata: 2012-05-13 12:24:26.645--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--The target foreign key column name for the many to many mapping [dataItems] is being defaulted to: dataItems_ID.
[EL Finer]: weaver: 2012-05-13 12:24:26.648--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Class [org.crubier.dynamo.plugin.data.datarecord.DataRecord1D] registered to be processed by weaver.
[EL Finer]: weaver: 2012-05-13 12:24:26.65--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Class [org.crubier.dynamo.plugin.data.dataitem.DataItemString] registered to be processed by weaver.
[EL Finer]: weaver: 2012-05-13 12:24:26.651--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Class [org.crubier.dynamo.plugin.data.dataitem.DataItemDouble] registered to be processed by weaver.
[EL Finer]: weaver: 2012-05-13 12:24:26.651--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Class [org.crubier.dynamo.plugin.data.dataitem.DataItemDate] registered to be processed by weaver.
[EL Finer]: weaver: 2012-05-13 12:24:26.651--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Class [org.crubier.dynamo.plugin.data.dataitem.DataItemMatrix1D] registered to be processed by weaver.
[EL Finer]: weaver: 2012-05-13 12:24:26.651--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Class [org.crubier.dynamo.plugin.data.datatype.DataTypePhysical] registered to be processed by weaver.
[EL Finer]: weaver: 2012-05-13 12:24:26.652--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Class [org.crubier.dynamo.plugin.data.datatype.DataType] registered to be processed by weaver.
[EL Finer]: weaver: 2012-05-13 12:24:26.652--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Class [org.crubier.dynamo.plugin.data.dataitem.DataItemInteger] registered to be processed by weaver.
[EL Finer]: weaver: 2012-05-13 12:24:26.652--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Class [org.crubier.dynamo.plugin.data.dataitem.DataItem] registered to be processed by weaver.
[EL Finer]: weaver: 2012-05-13 12:24:26.652--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Class [org.crubier.dynamo.plugin.data.datastats.DataStatistics] registered to be processed by weaver.
[EL Finer]: weaver: 2012-05-13 12:24:26.653--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--Class [org.crubier.dynamo.plugin.data.datagroup.DataGroup] registered to be processed by weaver.
[EL Finest]: jpa: 2012-05-13 12:24:26.655--ServerSession(1421890531)--Thread(Thread[Refresh Packages,5,main])--End predeploying Persistence Unit org.crubier.dynamo.db; session org.crubier.dynamo.db; state Predeployed; factoryCount 0
java.lang.ClassNotFoundException: org.crubier.dynamo.plugin.data.datarecord.DataRecord1D
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
	at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
	at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
	at org.eclipse.gemini.jpa.GeminiServicesUtil.proxyLoader(GeminiServicesUtil.java:268)
	at org.eclipse.gemini.jpa.GeminiServicesUtil.tryToRegisterEMFService(GeminiServicesUtil.java:361)
	at org.eclipse.gemini.jpa.GeminiServicesUtil.registerEMFServices(GeminiServicesUtil.java:128)
	at org.eclipse.gemini.jpa.provider.EclipseLinkOSGiProvider.registerPersistenceUnits(EclipseLinkOSGiProvider.java:226)
	at org.eclipse.gemini.jpa.PersistenceBundleExtender.registerPersistenceUnitsInBundle(PersistenceBundleExtender.java:209)
	at org.eclipse.gemini.jpa.PersistenceBundleExtender.bundleChanged(PersistenceBundleExtender.java:286)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1569)
	at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1505)
	at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1500)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:367)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.resumeBundles(PackageAdminImpl.java:314)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.processDelta(PackageAdminImpl.java:558)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl.doResolveBundles(PackageAdminImpl.java:254)
	at org.eclipse.osgi.framework.internal.core.PackageAdminImpl$1.run(PackageAdminImpl.java:174)
	at java.lang.Thread.run(Thread.java:722)
!ENTRY org.eclipse.osgi 4 0 2012-05-13 12:24:26.841
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
java.lang.RuntimeException: Could not load domain class in p-unit
	at org.eclipse.gemini.jpa.GeminiUtil.fatalError(GeminiUtil.java:109)
	at org.eclipse.gemini.jpa.GeminiServicesUtil.proxyLoader(GeminiServicesUtil.java:274)
Caused by: java.lang.ClassNotFoundException: org.crubier.dynamo.plugin.data.datarecord.DataRecord1D
	... 18 more
!ENTRY org.eclipse.gemini.jpa 4 0 2012-05-13 12:24:26.843
!MESSAGE FrameworkEvent ERROR
!STACK 0
	... 18 more
No binding table for org.eclipse.ui.contexts.dialog
FileViewer actif
Plot actif
DataView Actif
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-05-13 12:24:29.617
!MESSAGE Unable to create class 'org.crubier.dynamo.plugin.dataview.DataViewPart' from bundle '143'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: org/crubier/dynamo/plugin/data/dataitem/DataItem
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:853)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:318)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:882)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:616)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:718)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:689)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:683)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:668)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1010)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:66)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4597)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:184)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:57)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:102)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:632)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:628)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:626)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:950)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:909)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:85)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:147)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:601)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.NoClassDefFoundError: org/crubier/dynamo/plugin/data/dataitem/DataItem
	at org.crubier.dynamo.plugin.dataview.DataTableWidget$DataBaseContentProvider.getElements(DataTableWidget.java:224)
	at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(StructuredViewer.java:1010)
	at org.eclipse.jface.viewers.ColumnViewer.getRawChildren(ColumnViewer.java:703)
	at org.eclipse.jface.viewers.AbstractTableViewer.getRawChildren(AbstractTableViewer.java:1087)
	at org.eclipse.jface.viewers.StructuredViewer.getFilteredChildren(StructuredViewer.java:917)
	at org.eclipse.jface.viewers.StructuredViewer.getSortedChildren(StructuredViewer.java:1067)
	at org.eclipse.jface.viewers.AbstractTableViewer.internalRefreshAll(AbstractTableViewer.java:701)
	at org.eclipse.jface.viewers.AbstractTableViewer.internalRefresh(AbstractTableViewer.java:649)
	at org.eclipse.jface.viewers.AbstractTableViewer.internalRefresh(AbstractTableViewer.java:636)
	at org.eclipse.jface.viewers.AbstractTableViewer$2.run(AbstractTableViewer.java:592)
	at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1443)
	at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1404)
	at org.eclipse.jface.viewers.AbstractTableViewer.inputChanged(AbstractTableViewer.java:590)
	at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:280)
	at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1690)
	at org.crubier.dynamo.plugin.dataview.DataTableWidget.<init>(DataTableWidget.java:75)
	at org.crubier.dynamo.plugin.dataview.DataViewPart.createControls(DataViewPart.java:25)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	... 99 more
Caused by: java.lang.ClassNotFoundException: org.crubier.dynamo.plugin.data.dataitem.DataItem
	... 121 more
I would appreciate any help here, as i'm really stuck after having been trying to find a solution for a while...
Thank you in advance for your attention, and please excuse if I made an obvious mistake. For the moment, there's noting obvious for me on that topic Smile And sorry, i can't use link until i have posted more than 25 messages.
Thank you Smile
[Updated on: Sun, 13 May 2012 07:40] by Moderator
Re: [Gemini JPA] Gemini JPA and e4 : *** FATAL ERROR *** Could not load domain class in p-unit [message #872260 is a reply to message #871403] Tue, 15 May 2012 15:41 Go to previous messageGo to next message
Hi Vincent,
Are you able to recreate a simple test case and attach it to a bug?
-Mike
Re: [Gemini JPA] Gemini JPA and e4 : *** FATAL ERROR *** Could not load domain class in p-unit [message #872666 is a reply to message #871403] Wed, 16 May 2012 11:07 Go to previous message
Hi Vincent,
Sorry for the late reply. For me it looks like
you don't export your entity classes. Checky your
MANIFEST.MF
What could be wrong, too:
  • persistence.xml and entity classes are not in the same bundle
  • Add DREFRESH_BUNDLES=false to your program arguments
  • Startlevels: Gemini Derby (2), Gemini JPA(3) (my conf)
cheers,
Muki
Previous Topic:Gemini Naming 1.0.0.RC1
Next Topic:Gemini JPA 1.1.0 M1 now available
Current Time: Sat Nov 08 05:59:36 EST 2025
Powered by FUDForum. Page generated in 0.03880 seconds
