Home » Eclipse Projects » Eclipse 4 » Eclipse 3.x RCP application on Compatibility Layer - Exceptions
Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #870991] Thu, 10 May 2012 09:39 Go to next message
I could successfully bring my RCP application on e4 M6.
After it launched I continuously get the below exception message in the Console view.
Please help.
!ENTRY org.eclipse.e4.ui.workbench.renderers.swt 4 2 2012-05-10 18:47:32.237
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.renderers.swt".
!STACK 0
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.generateParameterizedCommand(HandledContributionItem.java:547)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.getToolTipText(HandledContributionItem.java:511)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.updateToolItem(HandledContributionItem.java:498)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.update(HandledContributionItem.java:443)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.update(HandledContributionItem.java:430)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$3.run(HandledContributionItem.java:197)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.updateItemEnablement(HandledContributionItem.java:223)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$ToolItemUpdateTimer.run(HandledContributionItem.java:129)
at org.eclipse.swt.widgets.Display.timerProc(Display.java:4120)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2326)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3176)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1015)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:909)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:85)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:580)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:535)
at com.novell.idm.rcp.DesignerApplication.start(DesignerApplication.java:118)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
[Updated on: Thu, 10 May 2012 09:40] by Moderator
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #871000 is a reply to message #870991] Thu, 10 May 2012 09:56 Go to previous messageGo to next message
What if you clear you workspace and run it again? Do you see any other errors in your error log?
PW
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #871137 is a reply to message #871000] Fri, 11 May 2012 02:08 Go to previous messageGo to next message
1) Re-running after clearing the workspace had the same behavior!
2) When I start the application I get the below message for all the plugins
!ENTRY org.eclipse.update.configurator 4 0 2012-05-11 11:26:19.558
!MESSAGE Could not install bundle ../../../../../cheetah/designer_workspace/eWorkspace/org.eclipse.wst.javascript.ui/ Bundle "org.eclipse.wst.javascript.ui" version "1.0.200.v200805160650" has already been installed from: reference:file:/cheetah/designer_workspace/eWorkspace/org.eclipse.wst.javascript.ui/
!ENTRY org.eclipse.update.configurator 4 0 2012-05-11 11:26:19.559
!MESSAGE Could not install bundle ../../../../../cheetah/designer_workspace/eWorkspace/org.eclipse.wst.javascript.core/ Bundle "org.eclipse.wst.javascript.core" version "1.0.200.v200805140200" has already been installed from: reference:file:/cheetah/designer_workspace/eWorkspace/org.eclipse.wst.javascript.core/
3) The other error message I see is as below -
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. org.eclipse.ui.externaltools.ExternalToolsSet
at org.eclipse.core.commands.contexts.Context.getParentId(Context.java:201)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.getLevel(ContextSet.java:48)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:38)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:1)
at java.util.Arrays.mergeSort(Arrays.java:1293)
at java.util.Arrays.sort(Arrays.java:1210)
at java.util.Collections.sort(Collections.java:159)
at org.eclipse.e4.ui.bindings.internal.ContextSet.<init>(ContextSet.java:76)
at org.eclipse.e4.ui.bindings.internal.BindingTableManager.createContextSet(BindingTableManager.java:88)
at org.eclipse.e4.ui.bindings.internal.BindingServiceImpl.setContextIds(BindingServiceImpl.java:232)
at sun.reflect.GeneratedMethodAccessor13.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:77)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:106)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:298)
at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:312)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activate(EclipseContext.java:598)
at org.eclipse.e4.ui.internal.workbench.PartActivationHistory.activate(PartActivationHistory.java:56)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:560)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.switchPerspective(PartServiceImpl.java:507)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:124)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:66)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4290)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:184)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:57)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:380)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.e4.ui.workbench.addons.perspectiveswitcher.PerspectiveSwitcher$13.widgetSelected(PerspectiveSwitcher.java:436)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1271)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3553)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3178)
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #871245 is a reply to message #870991] Fri, 11 May 2012 11:39 Go to previous messageGo to next message
What is the build ID that you found this on? I'm having a hard time matching the numbers in your stack trace.
Can you please reproduce the problem on 4.2 M7 http://download.eclipse.org/eclipse/downloads/drops4/S-4.2M7-201205031800/
Then you can post the stack trace with line numbers to https://bugs.eclipse.org/bugs/show_bug.cgi?id=379272
PW
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #871248 is a reply to message #871245] Fri, 11 May 2012 11:57 Go to previous messageGo to next message
Sorry I missed putting the build ID. It is on M6
Eclipse SDK
Version: 4.2.0
Build id: I20120315-1300
Yet to try with M7.
-KPRajesh
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #871926 is a reply to message #871248] Tue, 15 May 2012 02:44 Go to previous messageGo to next message
I tried with M7 build and my product is not launching! It throws following exception
e4 M7 build ID is
Eclipse SDK
Version: 4.2.0
Build id: I20120503-1800
In fact when I switched back to M6 build and I'm facing the same issue!
!SESSION 2012-05-15 11:55:29.350 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_31
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product com.novell.idm.rcp.Designer
Command-line arguments: -product com.novell.idm.rcp.Designer -data /cheetah/designer_workspace/eWorkspace/../runtime-Designer4x.product123 -dev file:/cheetah/designer_workspace/eWorkspace/.metadata/.plugins/org.eclipse.pde.core/Designer4x.product/dev.properties -os linux -ws gtk -arch x86 -consoleLog -clean
!ENTRY org.eclipse.osgi 4 0 2012-05-15 11:55:51.459
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.<init>(ModelServiceImpl.java:92)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:442)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:182)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:551)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:537)
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #871942 is a reply to message #871926] Tue, 15 May 2012 03:34 Go to previous messageGo to next message
Can you please check if:
* equinox.ds
* equinox.event
Are in your launch config!
Tom
Am 15.05.12 08:44, schrieb Rajesh KP:
> following exception
> e4 M7 build ID is
> Eclipse SDK
> Version: 4.2.0
> -dev
> !STACK 1
> java.lang.NullPointerException
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #871949 is a reply to message #871942] Tue, 15 May 2012 03:41 Go to previous messageGo to next message
Yes they are present.
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #871967 is a reply to message #871949] Tue, 15 May 2012 04:24 Go to previous messageGo to next message
Have you tried to add all required plugins into the product you are launching the app from? At least that helped with the problems I had when trying to make use of the compat layer.
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #871977 is a reply to message #871949] Tue, 15 May 2012 04:31 Go to previous messageGo to next message
Show us the output of the "ss" command in your OSGi-Console. The problem
is that IEventBroker is not found. It is defined in
Please check that your launch configuration has no resolution problems
by hitting validate in the dialog.
Tom
Am 15.05.12 09:41, schrieb Rajesh KP:
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #872026 is a reply to message #871977] Tue, 15 May 2012 06:37 Go to previous messageGo to next message
1) I had done 'Add required plugins'
2) OSGi ss o/p is as below -
WARNING: This console is connected to the current running instance of Eclipse!osgi> ss
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.8.0.v20120312-2035
1 ACTIVE org.eclipse.equinox.simpleconfigurator_1.0.300.v20110815-1744
2 RESOLVED ch.qos.logback.classic_1.0.0.v20111214-2030
3 RESOLVED ch.qos.logback.core_1.0.0.v20111214-2030
4 RESOLVED ch.qos.logback.slf4j_1.0.0.v20120123-1500
Master=800
5 ACTIVE com.collabnet.subversion.merge_2.2.4
6 ACTIVE com.ibm.icu_4.4.2.v20110823
7 RESOLVED com.jcraft.jsch_0.1.44.v201101211721
8 RESOLVED com.lowagie.text_2.1.7.v201004222200
9 RESOLVED com.sun.el_2.2.0.v201108011116
10 STARTING com.sun.jna_3.2.7
11 RESOLVED com.sun.syndication_0.9.0.v200803061811
12 RESOLVED java_cup.runtime_0.10.0.v201005080400
13 RESOLVED javax.activation_1.1.0.v201105071233
14 RESOLVED javax.annotation_1.0.0.v20101115-0725
15 RESOLVED javax.el_2.2.0.v201108011116
16 RESOLVED javax.inject_1.0.0.v20091030
17 RESOLVED javax.jws_2.0.0.v201005080400
18 RESOLVED javax.mail_1.4.0.v201005080615
19 RESOLVED javax.persistence_2.0.3.v201010191057
20 RESOLVED javax.servlet_3.0.0.v201112011016
21 RESOLVED javax.servlet.jsp_2.2.0.v201112011158
22 RESOLVED javax.wsdl_1.5.1.v201012040544
23 RESOLVED javax.wsdl_1.6.2.v201012040545
24 RESOLVED javax.xml_1.3.4.v201005080400
25 RESOLVED javax.xml.bind_2.1.9.v201005080401
26 RESOLVED javax.xml.rpc_1.1.0.v201005080400
27 RESOLVED javax.xml.soap_1.2.0.v201005080501
28 RESOLVED javax.xml.stream_1.0.1.v201004272200
29 RESOLVED javax.xml.ws_2.1.0.v200902101523
30 RESOLVED net.java.dev.jna_3.4.0.t20120117_1605
31 RESOLVED net.sourceforge.lpg.lpgjavaruntime_1.1.0.v201004271650
32 RESOLVED org.apache.ant_1.8.2.v20120109-1030
33 RESOLVED org.apache.axis_1.4.0.v201005080400
34 INSTALLED org.apache.batik.bridge_1.6.0.v200912221622
35 RESOLVED org.apache.batik.bridge_1.6.0.v201011041432
36 RESOLVED org.apache.batik.css_1.6.0.v201011041432
37 INSTALLED org.apache.batik.css_1.6.0.v200912221622
38 INSTALLED org.apache.batik.dom_1.6.0.v200912221622
39 RESOLVED org.apache.batik.dom_1.6.0.v201011041432
40 INSTALLED org.apache.batik.dom.svg_1.6.0.v200805290154
41 RESOLVED org.apache.batik.dom.svg_1.6.0.v201011041432
42 INSTALLED org.apache.batik.ext.awt_1.6.0.v200805290154
43 RESOLVED org.apache.batik.ext.awt_1.6.0.v201011041432
44 INSTALLED org.apache.batik.parser_1.6.0.v200805290154
45 RESOLVED org.apache.batik.parser_1.6.0.v201011041432
46 RESOLVED org.apache.batik.pdf_1.6.0.v200806031500
47 RESOLVED org.apache.batik.pdf_1.6.0.v201105071520
48 INSTALLED org.apache.batik.svggen_1.6.0.v200805290154
49 RESOLVED org.apache.batik.svggen_1.6.0.v201011041432
50 INSTALLED org.apache.batik.transcoder_1.6.0.v200805290154
51 RESOLVED org.apache.batik.transcoder_1.6.0.v201011041432
52 RESOLVED org.apache.batik.util_1.6.0.v201011041432
53 INSTALLED org.apache.batik.util_1.6.0.v200805290154
54 RESOLVED org.apache.batik.util.gui_1.6.0.v201011041432
55 RESOLVED org.apache.batik.util.gui_1.6.0.v200805290154
56 INSTALLED org.apache.batik.xml_1.6.0.v200805290154
57 RESOLVED org.apache.batik.xml_1.6.0.v201011041432
58 RESOLVED org.apache.bcel_5.2.0.v201005080400
59 RESOLVED org.apache.commons.codec_1.3.0.v201101211617
60 RESOLVED org.apache.commons.collections_3.2.0.v201005080500
61 RESOLVED org.apache.commons.discovery_0.2.0.v201004190315
62 RESOLVED org.apache.commons.httpclient_3.1.0.v201012070820
63 RESOLVED org.apache.commons.lang_2.1.0.v201005080500
64 RESOLVED org.apache.commons.lang_2.4.0.v201005080502
65 RESOLVED org.apache.commons.logging_1.0.4.v201101211617
66 STARTING org.apache.derby.core_10.5.1.1_v20120213
67 ACTIVE org.apache.felix.gogo.command_0.8.0.v201108120515
68 ACTIVE org.apache.felix.gogo.runtime_0.8.0.v201108120515
69 ACTIVE org.apache.felix.gogo.shell_0.8.0.v201110170705
70 RESOLVED org.apache.jasper.glassfish_2.2.2.v201112011158
71 RESOLVED org.apache.log4j_1.2.15.v201012070815
72 RESOLVED org.apache.lucene_2.9.1.v201101211721
73 RESOLVED org.apache.lucene_1.9.1.v201101211617
74 RESOLVED org.apache.lucene.analysis_2.9.1.v201101211721
75 RESOLVED org.apache.lucene.core_2.9.1.v201101211721
76 RESOLVED org.apache.oro_2.0.8.v201005080400
77 RESOLVED org.apache.velocity_1.5.0.v200905192330
78 RESOLVED org.apache.wsil4j_1.0.0.v200901211807
79 RESOLVED org.apache.xalan_2.7.1.v201005080400
80 RESOLVED org.apache.xerces_2.9.0.v201005080400
81 RESOLVED org.apache.xerces_2.9.0.v201101211617
82 RESOLVED org.apache.xml.resolver_1.2.0.v201005080400
83 RESOLVED org.apache.xml.serializer_2.7.1.v201005080400
84 STARTING org.eclipse.ant.core_3.2.400.v20120110-1653
85 STARTING org.eclipse.ant.launching_1.0.100.v20120110-1653
86 STARTING org.eclipse.ant.ui_3.5.300.v20120227-1938
87 RESOLVED org.eclipse.birt_3.7.2.v20120213
88 RESOLVED org.eclipse.birt.chart_3.7.2.v20120213
89 STARTING org.eclipse.birt.chart.cshelp_3.7.2.v20120213
90 STARTING org.eclipse.birt.chart.device.extension_3.7.2.v20120213
91 STARTING org.eclipse.birt.chart.device.pdf_3.7.2.v20120213
92 STARTING org.eclipse.birt.chart.device.svg_3.7.2.v20120213
93 STARTING org.eclipse.birt.chart.device.swt_3.7.2.v20120213
94 STARTING org.eclipse.birt.chart.engine_3.7.2.v20120213
95 STARTING org.eclipse.birt.chart.engine.extension_3.7.2.v20120213
96 STARTING org.eclipse.birt.chart.examples_3.7.2.v20120213
97 STARTING org.eclipse.birt.chart.examples.core_3.7.2.v20120213
98 STARTING org.eclipse.birt.chart.reportitem_3.7.2.v20120213
99 STARTING org.eclipse.birt.chart.reportitem.ui_3.7.2.v20120213
100 STARTING org.eclipse.birt.chart.ui_3.7.2.v20120213
101 STARTING org.eclipse.birt.chart.ui.extension_3.7.2.v20120213
102 STARTING org.eclipse.birt.core_3.7.2.v20120213
103 STARTING org.eclipse.birt.core.script.function_3.7.2.v20120213
104 STARTING org.eclipse.birt.core.ui_3.7.2.v20120213
105 STARTING org.eclipse.birt.cshelp_3.7.2.v20120213
106 STARTING org.eclipse.birt.data_3.7.2.v20120213
107 STARTING org.eclipse.birt.data.aggregation_3.7.2.v20120213
108 STARTING org.eclipse.birt.doc_3.7.2.v20120213
109 RESOLVED org.eclipse.birt.example_3.7.2.v20120213
110 STARTING org.eclipse.birt.report.data.adapter_3.7.2.v20120213
111 STARTING org.eclipse.birt.report.data.bidi.utils_3.7.2.v20120213
112 STARTING org.eclipse.birt.report.data.bidi.utils.ui_3.7.2.v20120213
113 STARTING org.eclipse.birt.report.data.oda.hive_3.7.2.v20120213
114 STARTING org.eclipse.birt.report.data.oda.hive.ui_3.7.2.v20120213
115 STARTING org.eclipse.birt.report.data.oda.jdbc_3.7.2.v20120213
116 STARTING org.eclipse.birt.report.data.oda.jdbc.dbprofile_3.7.2.v20120213
117 STARTING org.eclipse.birt.report.data.oda.jdbc.dbprofile.sampledb_3.7.2.v20120213
118 STARTING org.eclipse.birt.report.data.oda.jdbc.dbprofile.sampledb.ui_3.7.2.v20120213
119 STARTING org.eclipse.birt.report.data.oda.jdbc.dbprofile.ui_3.7.2.v20120213
120 STARTING org.eclipse.birt.report.data.oda.jdbc.ui_3.7.2.v20120213
121 STARTING org.eclipse.birt.report.data.oda.sampledb_3.7.2.v20120213
122 STARTING org.eclipse.birt.report.data.oda.sampledb.ui_3.7.2.v20120213
123 STARTING org.eclipse.birt.report.data.oda.xml_3.7.2.v20120213
124 STARTING org.eclipse.birt.report.data.oda.xml.ui_3.7.2.v20120213
125 RESOLVED org.eclipse.birt.report.debug.core_3.7.2.v20120213
126 STARTING org.eclipse.birt.report.debug.ui_3.7.2.v20120213
127 STARTING org.eclipse.birt.report.designer.core_3.7.2.v20120213
128 STARTING org.eclipse.birt.report.designer.samplereports_3.7.2.v20120213
129 STARTING org.eclipse.birt.report.designer.ui_3.7.2.v20120213
130 STARTING org.eclipse.birt.report.designer.ui.cubebuilder_3.7.2.v20120213
131 STARTING org.eclipse.birt.report.designer.ui.data_3.7.2.v20120213
132 STARTING org.eclipse.birt.report.designer.ui.editor.script_3.7.2.v20120213
133 STARTING org.eclipse.birt.report.designer.ui.editor.xml.wtp_3.7.2.v20120213
134 STARTING org.eclipse.birt.report.designer.ui.editors_3.7.2.v20120213
135 STARTING org.eclipse.birt.report.designer.ui.editors.schematic_3.7.2.v20120213
136 STARTING org.eclipse.birt.report.designer.ui.ide_3.7.2.v20120213
137 STARTING org.eclipse.birt.report.designer.ui.lib_3.7.2.v20120213
138 STARTING org.eclipse.birt.report.designer.ui.lib.explorer_3.7.2.v20120213
139 STARTING org.eclipse.birt.report.designer.ui.preview.web_3.7.2.v20120213
140 STARTING org.eclipse.birt.report.designer.ui.samples.ide_3.7.2.v20120213
141 STARTING org.eclipse.birt.report.designer.ui.samplesview_3.7.2.v20120213
142 STARTING org.eclipse.birt.report.designer.ui.views_3.7.2.v20120213
143 STARTING org.eclipse.birt.report.engine_3.7.2.v20120213
144 STARTING org.eclipse.birt.report.engine.dataextraction_3.7.2.v20120213
145 STARTING org.eclipse.birt.report.engine.dataextraction.csv_3.7.2.v20120213
146 STARTING org.eclipse.birt.report.engine.emitter.config_3.7.2.v20120213
147 STARTING org.eclipse.birt.report.engine.emitter.config.excel_3.7.2.v20120213
148 STARTING org.eclipse.birt.report.engine.emitter.config.html_3.7.2.v20120213
149 STARTING org.eclipse.birt.report.engine.emitter.config.odp_3.7.2.v20120213
150 STARTING org.eclipse.birt.report.engine.emitter.config.ods_3.7.2.v20120213
151 STARTING org.eclipse.birt.report.engine.emitter.config.odt_3.7.2.v20120213
152 STARTING org.eclipse.birt.report.engine.emitter.config.pdf_3.7.2.v20120213
153 STARTING org.eclipse.birt.report.engine.emitter.config.postscript_3.7.2.v20120213
154 STARTING org.eclipse.birt.report.engine.emitter.config.ppt_3.7.2.v20120213
155 STARTING org.eclipse.birt.report.engine.emitter.config.wpml_3.7.2.v20120213
156 STARTING org.eclipse.birt.report.engine.emitter.html_3.7.2.v20120213
157 STARTING org.eclipse.birt.report.engine.emitter.odp_3.7.2.v20120213
158 STARTING org.eclipse.birt.report.engine.emitter.ods_3.7.2.v20120213
159 STARTING org.eclipse.birt.report.engine.emitter.odt_3.7.2.v20120213
160 STARTING org.eclipse.birt.report.engine.emitter.pdf_3.7.2.v20120213
161 RESOLVED org.eclipse.birt.report.engine.emitter.postscript_3.7.2.v20120213
162 STARTING org.eclipse.birt.report.engine.emitter.ppt_3.7.2.v20120213
163 STARTING org.eclipse.birt.report.engine.emitter.prototype.excel_3.7.2.v20120213
164 STARTING org.eclipse.birt.report.engine.emitter.wpml_3.7.2.v20120213
165 RESOLVED org.eclipse.birt.report.engine.fonts_3.7.2.v20120213
166 STARTING org.eclipse.birt.report.engine.odf_3.7.2.v20120213
167 STARTING org.eclipse.birt.report.engine.script.javascript_3.7.2.v20120213
168 STARTING org.eclipse.birt.report.item.crosstab.core_3.7.2.v20120213
169 STARTING org.eclipse.birt.report.item.crosstab.ui_3.7.2.v20120213
170 STARTING org.eclipse.birt.report.model_3.7.2.v20120213
171 STARTING org.eclipse.birt.report.model.adapter.oda_3.7.2.v20120213
172 STARTING org.eclipse.birt.report.viewer_3.7.2.v20120213
173 RESOLVED org.eclipse.birt.resources_3.7.2.v20120213
174 ACTIVE org.eclipse.compare_3.5.300.v20120306-1149
175 ACTIVE org.eclipse.compare.core_3.5.200.v20120314-1627
176 RESOLVED org.eclipse.core.commands_3.6.0.v20111007-1312
177 ACTIVE org.eclipse.core.contenttype_3.4.100.v20110423-0524
178 STARTING org.eclipse.core.databinding_1.4.1.v20111007-1312
179 RESOLVED org.eclipse.core.databinding.beans_1.2.100.v20111007-1312
180 ACTIVE org.eclipse.core.databinding.observable_1.4.1.v20111007-1312
181 STARTING org.eclipse.core.databinding.property_1.4.0.v20111007-1312
182 ACTIVE org.eclipse.core.expressions_3.4.300.v20110228
183 STARTING org.eclipse.core.externaltools_1.0.100.v20111215-1438
184 ACTIVE org.eclipse.core.filebuffers_3.5.200.v20111215-1439
185 ACTIVE org.eclipse.core.filesystem_1.3.200.v20120306-1226
Fragments=186
186 RESOLVED org.eclipse.core.filesystem.linux.x86_1.4.0.v20110423-0524
Master=185
187 ACTIVE org.eclipse.core.jobs_3.5.200.v20120113-1913
188 ACTIVE org.eclipse.core.net_1.2.200.v20111202-1616
Fragments=189
189 RESOLVED org.eclipse.core.net.linux.x86_1.1.200.I20110419-0800
Master=188
190 ACTIVE org.eclipse.core.resources_3.8.0.v20120229-1128
191 ACTIVE org.eclipse.core.runtime_3.8.0.v20120308-2101
192 ACTIVE org.eclipse.core.runtime.compatibility_3.2.200.v20120308-2101
193 STARTING org.eclipse.core.runtime.compatibility.auth_3.2.200.v20120110-1626
194 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.5.0.v20110505
Master=427
195 ACTIVE org.eclipse.core.variables_3.2.600.v20111215-1438
196 STARTING org.eclipse.cvs_1.1.100.v201203141800
197 STARTING org.eclipse.datatools.common.doc.user_1.7.0.20090521092446
198 STARTING org.eclipse.datatools.connectivity_1.2.4.v201202041105
199 STARTING org.eclipse.datatools.connectivity.apache.derby_1.0.102.v201107221459
200 STARTING org.eclipse.datatools.connectivity.apache.derby.dbdefinition_1.0.2.v201107221459
201 STARTING org.eclipse.datatools.connectivity.apache.derby.ui_1.0.3.v201107221459
202 STARTING org.eclipse.datatools.connectivity.console.profile_1.0.10.v201109250955
203 STARTING org.eclipse.datatools.connectivity.db.generic_1.0.1.v201107221459
204 STARTING org.eclipse.datatools.connectivity.db.generic.ui_1.0.1.v201107221459
205 STARTING org.eclipse.datatools.connectivity.dbdefinition.genericJDBC_1.0.1.v201107221459
206 STARTING org.eclipse.datatools.connectivity.doc.user_1.7.0.20090521092446
207 STARTING org.eclipse.datatools.connectivity.doc.user.contexts_1.7.0.20090521092446
208 STARTING org.eclipse.datatools.connectivity.oda_3.3.3.v201110130935
209 STARTING org.eclipse.datatools.connectivity.oda.consumer_3.2.5.v201109151100
210 STARTING org.eclipse.datatools.connectivity.oda.design_3.3.4.v201109211529
211 STARTING org.eclipse.datatools.connectivity.oda.design.ui_3.2.6.v201112151316
212 STARTING org.eclipse.datatools.connectivity.oda.flatfile_3.1.2.v201112081200
213 STARTING org.eclipse.datatools.connectivity.oda.flatfile.ui_3.1.2.v201201101437
214 STARTING org.eclipse.datatools.connectivity.oda.profile_3.2.7.v201112290953
215 STARTING org.eclipse.datatools.connectivity.oda.template.ui_3.2.3.v201201121156
216 STARTING org.eclipse.datatools.connectivity.sqm.core_1.2.4.v201201131116
217 STARTING org.eclipse.datatools.connectivity.sqm.core.ui_1.2.1.v20110926045
218 STARTING org.eclipse.datatools.connectivity.sqm.server.ui_1.1.100.v201107221459
219 STARTING org.eclipse.datatools.connectivity.ui_1.2.2.v201111190813
220 STARTING org.eclipse.datatools.connectivity.ui.dse_1.1.4.v201107221459
221 STARTING org.eclipse.datatools.doc.user_1.7.0.20090521092446
222 STARTING org.eclipse.datatools.enablement.finfo_1.5.1.v200906161800
223 STARTING org.eclipse.datatools.enablement.hsqldb_1.0.0.v201107221502
224 STARTING org.eclipse.datatools.enablement.hsqldb.dbdefinition_1.0.0.v201107221502
225 STARTING org.eclipse.datatools.enablement.hsqldb.ui_1.0.0.v201108120600
226 STARTING org.eclipse.datatools.enablement.ibm.db2.iseries_1.0.2.v201107221502
227 STARTING org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinition_1.0.3.v201107221502
228 STARTING org.eclipse.datatools.enablement.ibm.db2.iseries.ui_1.0.1.v201108130630
229 STARTING org.eclipse.datatools.enablement.ibm.db2.luw_1.0.2.v201107221502
230 STARTING org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition_1.0.4.v201107221502
231 STARTING org.eclipse.datatools.enablement.ibm.db2.luw.ui_1.0.2.v201108130630
232 STARTING org.eclipse.datatools.enablement.ibm.db2.zseries_1.0.2.v201107221502
233 STARTING org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinition_1.0.4.v201107221502
234 STARTING org.eclipse.datatools.enablement.ibm.db2.zseries.ui_1.0.1.v201108130630
235 STARTING org.eclipse.datatools.enablement.ibm.informix_1.0.1.v201107221502
236 STARTING org.eclipse.datatools.enablement.ibm.informix.dbdefinition_1.0.4.v201107221502
237 STARTING org.eclipse.datatools.enablement.ibm.informix.ui_1.0.2.v201108130630
238 STARTING org.eclipse.datatools.enablement.ibm.ui_1.0.0.v201107221502
239 STARTING org.eclipse.datatools.enablement.ingres_1.0.0.v200906111150
240 STARTING org.eclipse.datatools.enablement.ingres.dbdefinition_1.0.0.v200906161800
241 STARTING org.eclipse.datatools.enablement.ingres.ui_1.0.0.v201105270214
242 STARTING org.eclipse.datatools.enablement.jdt.classpath_1.0.1.v201107221501
243 STARTING org.eclipse.datatools.enablement.msft.sqlserver_1.0.1.v201107221504
244 STARTING org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition_1.0.1.v201201240349
245 STARTING org.eclipse.datatools.enablement.msft.sqlserver.ui_1.0.2.v201201131118
246 STARTING org.eclipse.datatools.enablement.mysql_1.0.2.v201109022323
247 STARTING org.eclipse.datatools.enablement.mysql.dbdefinition_1.0.4.v201109022331
248 STARTING org.eclipse.datatools.enablement.mysql.ui_1.0.0.v201109022331
249 STARTING org.eclipse.datatools.enablement.oda.ws_1.2.3.v201112061438
250 STARTING org.eclipse.datatools.enablement.oda.ws.ui_1.2.3.v201112061438
251 STARTING org.eclipse.datatools.enablement.oda.xml_1.2.3.v201112061438
252 STARTING org.eclipse.datatools.enablement.oda.xml.ui_1.2.3.v201112071047
253 STARTING org.eclipse.datatools.enablement.oracle_1.0.0.v201107221506
254 STARTING org.eclipse.datatools.enablement.oracle.dbdefinition_1.0.102.v201107221506
255 STARTING org.eclipse.datatools.enablement.oracle.ui_1.0.3.v201201131121
256 STARTING org.eclipse.datatools.enablement.postgresql_1.1.0.v201110070445
257 STARTING org.eclipse.datatools.enablement.postgresql.dbdefinition_1.0.2.v201110070445
258 STARTING org.eclipse.datatools.enablement.postgresql.ui_1.0.0.v201107221506
259 STARTING org.eclipse.datatools.enablement.sap.maxdb_1.0.0.v201107221507
260 STARTING org.eclipse.datatools.enablement.sap.maxdb.dbdefinition_1.0.0.v201107221507
261 STARTING org.eclipse.datatools.enablement.sap.maxdb.ui_1.0.0.v201107221507
262 STARTING org.eclipse.datatools.enablement.sqlite_1.0.0.v201002041100
263 STARTING org.eclipse.datatools.enablement.sqlite.dbdefinition_1.0.1.v201107221507
264 STARTING org.eclipse.datatools.enablement.sqlite.ui_1.0.0.v201107221507
265 STARTING org.eclipse.datatools.enablement.sybase_1.0.1.v201107221507
266 STARTING org.eclipse.datatools.enablement.sybase.asa_1.0.1.v201107221507
267 STARTING org.eclipse.datatools.enablement.sybase.asa.dbdefinition_1.0.0.v200906161800
268 STARTING org.eclipse.datatools.enablement.sybase.asa.models_1.0.0.v201107221507
269 STARTING org.eclipse.datatools.enablement.sybase.asa.schemaobjecteditor.examples_2.5.0.200810071
270 STARTING org.eclipse.datatools.enablement.sybase.asa.ui_1.0.1.v200906111204
271 STARTING org.eclipse.datatools.enablement.sybase.ase_1.0.2.v201201131122
272 STARTING org.eclipse.datatools.enablement.sybase.ase.dbdefinition_1.0.0.v201107221507
273 STARTING org.eclipse.datatools.enablement.sybase.ase.models_1.0.1.v201010140307
274 STARTING org.eclipse.datatools.enablement.sybase.ase.ui_1.0.1.v200906020900
275 STARTING org.eclipse.datatools.enablement.sybase.models_1.0.0.v201010140307
276 STARTING org.eclipse.datatools.enablement.sybase.ui_1.0.0.v200906090452
277 RESOLVED org.eclipse.datatools.help_1.5.0.v200906020553
278 RESOLVED org.eclipse.datatools.intro_1.7.0.v201005281800
279 STARTING org.eclipse.datatools.modelbase.dbdefinition_1.0.2.v201107221519
280 STARTING org.eclipse.datatools.modelbase.derby_1.0.0.v201107221519
281 STARTING org.eclipse.datatools.modelbase.sql_1.0.5.v201110151330
282 STARTING org.eclipse.datatools.modelbase.sql.edit_1.0.1.v201107221519
283 STARTING org.eclipse.datatools.modelbase.sql.query_1.1.2.v201110151315
284 STARTING org.eclipse.datatools.modelbase.sql.query.edit_1.0.1.v201110151245
285 STARTING org.eclipse.datatools.modelbase.sql.xml.query_1.0.2.v201201131123
286 STARTING org.eclipse.datatools.oda.cshelp_1.1.1.v201107221500
287 STARTING org.eclipse.datatools.sdk_1.7.0.v200906161850
288 STARTING org.eclipse.datatools.sqltools.common.ui_1.0.0.v201107221520
289 STARTING org.eclipse.datatools.sqltools.data.core_1.2.1.v201110050500
290 STARTING org.eclipse.datatools.sqltools.data.ui_1.2.1.v201010270945
291 STARTING org.eclipse.datatools.sqltools.db.derby_1.0.0.v201107221520
292 STARTING org.eclipse.datatools.sqltools.db.derby.ui_1.0.0.v200906020900
293 STARTING org.eclipse.datatools.sqltools.db.generic_1.0.0.v201107221520
294 STARTING org.eclipse.datatools.sqltools.db.generic.ui_1.0.0.v200906020900
295 STARTING org.eclipse.datatools.sqltools.ddlgen.ui_1.0.2.v201201131129
296 STARTING org.eclipse.datatools.sqltools.debugger.core_1.0.1.v201107221520
297 STARTING org.eclipse.datatools.sqltools.debugger.core.ui_1.0.0.v201003161000
298 STARTING org.eclipse.datatools.sqltools.doc.user_1.7.0.20090521092446
299 STARTING org.eclipse.datatools.sqltools.doc.user.contexts_1.7.0.20090521092446
300 STARTING org.eclipse.datatools.sqltools.editor.core_1.0.1.v201201131129
301 STARTING org.eclipse.datatools.sqltools.editor.core.ui_1.0.0.v201001150815
302 STARTING org.eclipse.datatools.sqltools.parsers.sql_1.0.2.v201107221520
303 STARTING org.eclipse.datatools.sqltools.parsers.sql.lexer_1.0.1.v201107221520
304 STARTING org.eclipse.datatools.sqltools.parsers.sql.query_1.2.1.v201201250505
305 STARTING org.eclipse.datatools.sqltools.parsers.sql.xml.query_1.0.0.v201107221520
306 STARTING org.eclipse.datatools.sqltools.plan_1.0.0.v201107221520
307 STARTING org.eclipse.datatools.sqltools.result_1.1.2.v201201131129
308 STARTING org.eclipse.datatools.sqltools.result.ui_1.1.2.v201110010535
309 STARTING org.eclipse.datatools.sqltools.routineeditor_1.0.0.v201107221520
310 STARTING org.eclipse.datatools.sqltools.routineeditor.ui_1.0.2.v201111230714
311 STARTING org.eclipse.datatools.sqltools.schemaobjecteditor_1.1.0.v200906022302
312 STARTING org.eclipse.datatools.sqltools.schemaobjecteditor.ui_1.1.1.200810071
313 STARTING org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages_1.1.0.200810071
314 STARTING org.eclipse.datatools.sqltools.sql_1.0.1.v201110050515
315 STARTING org.eclipse.datatools.sqltools.sql.ui_1.0.1.v201201270743
316 STARTING org.eclipse.datatools.sqltools.sqlbuilder_1.0.3.v201107221520
317 STARTING org.eclipse.datatools.sqltools.sqleditor_1.0.2.v201107221520
318 STARTING org.eclipse.datatools.sqltools.sqlscrapbook_1.0.1.v201107221520
319 STARTING org.eclipse.datatools.sqltools.tabledataeditor_1.0.1.v201005250945
320 ACTIVE org.eclipse.debug.core_3.7.100.v20120229-2138
321 ACTIVE org.eclipse.debug.ui_3.8.0.v20120314-1459
322 STARTING org.eclipse.draw2d_3.7.2.v20111017-2020
323 STARTING org.eclipse.draw2d.doc.isv_3.5.0.v20111106-2020
324 ACTIVE org.eclipse.e4.core.commands_0.10.0.v20120209-1845
325 ACTIVE org.eclipse.e4.core.contexts_1.0.0.v20120224-1633
326 ACTIVE org.eclipse.e4.core.di_1.1.0.v20120223-2025
327 ACTIVE org.eclipse.e4.core.di.extensions_0.10.0.v20120201-1503
328 ACTIVE org.eclipse.e4.core.services_1.0.0.v20120118-2149
329 ACTIVE org.eclipse.e4.ui.bindings_0.10.0.v20120313-1928
330 RESOLVED org.eclipse.e4.ui.css.core_0.10.0.v20120312-1146
331 ACTIVE org.eclipse.e4.ui.css.swt_0.10.0.v20120314-1644
332 ACTIVE org.eclipse.e4.ui.css.swt.theme_0.9.1.v20120315-1637
333 ACTIVE org.eclipse.e4.ui.di_0.10.0.v20120217-1935
334 ACTIVE org.eclipse.e4.ui.model.workbench_0.10.0.v20120221-1958
335 ACTIVE org.eclipse.e4.ui.services_0.10.0.v20120209-1845
336 RESOLVED org.eclipse.e4.ui.widgets_0.11.0.v20120312-0401
337 ACTIVE org.eclipse.e4.ui.workbench_0.10.1.v20120314-1316
338 ACTIVE org.eclipse.e4.ui.workbench.addons.swt_0.10.0.v20120314-2016
339 ACTIVE org.eclipse.e4.ui.workbench.renderers.swt_0.10.0.v20120314-1758
340 ACTIVE org.eclipse.e4.ui.workbench.swt_0.10.0.v20120224-1612
341 RESOLVED org.eclipse.e4.ui.workbench3_0.12.0.v20120215-1332
342 STARTING org.eclipse.ecf_3.1.300.v20111230-0120
Fragments=349
343 ACTIVE org.eclipse.ecf.filetransfer_5.0.0.v20111230-0120
344 STARTING org.eclipse.ecf.identity_3.1.200.v20111230-0120
345 STARTING org.eclipse.ecf.provider.filetransfer_3.2.0.v20111230-0120
Fragments=348
346 STARTING org.eclipse.ecf.provider.filetransfer.httpclient_4.0.1.v20111230-0120
Fragments=347
347 RESOLVED org.eclipse.ecf.provider.filetransfer.httpclient.ssl_1.0.0.v20111230-0120
Master=346
348 RESOLVED org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20111230-0120
Master=345
349 RESOLVED org.eclipse.ecf.ssl_1.0.100.v20111230-0120
Master=342
350 STARTING org.eclipse.emf_2.6.0.v20120130-0943
351 STARTING org.eclipse.emf.ant_2.7.0.v20120130-0943
352 STARTING org.eclipse.emf.codegen_2.6.0.v20120130-0943
353 STARTING org.eclipse.emf.codegen.ecore_2.7.0.v20120130-0943
354 STARTING org.eclipse.emf.codegen.ecore.ui_2.7.0.v20120130-0943
355 STARTING org.eclipse.emf.codegen.ui_2.6.0.v20120130-0943
356 ACTIVE org.eclipse.emf.common_2.7.0.v20120127-1122
357 STARTING org.eclipse.emf.common.ui_2.7.0.v20120130-0943
358 STARTING org.eclipse.emf.converter_2.5.0.v20120130-0943
359 STARTING org.eclipse.emf.databinding_1.2.0.v20120130-0943
360 STARTING org.eclipse.emf.databinding.edit_1.2.0.v20120130-0943
361 ACTIVE org.eclipse.emf.ecore_2.7.0.v20120127-1122
362 ACTIVE org.eclipse.emf.ecore.change_2.7.1.v20120127-1122
363 STARTING org.eclipse.emf.ecore.change.edit_2.5.0.v20120130-0943
364 STARTING org.eclipse.emf.ecore.edit_2.7.1.v20120130-0943
365 STARTING org.eclipse.emf.ecore.editor_2.7.0.v20120130-0943
366 ACTIVE org.eclipse.emf.ecore.xmi_2.7.0.v20120127-1122
367 STARTING org.eclipse.emf.edit_2.7.2.v20120130-0943
368 STARTING org.eclipse.emf.edit.ui_2.7.0.v20120130-0943
369 STARTING org.eclipse.emf.exporter_2.6.0.v20120130-0943
370 STARTING org.eclipse.emf.importer_2.6.0.v20120130-0943
371 STARTING org.eclipse.emf.importer.ecore_2.6.0.v20120130-0943
372 STARTING org.eclipse.emf.importer.java_2.6.0.v20120130-0943
373 STARTING org.eclipse.emf.importer.rose_2.6.0.v20120130-0943
374 STARTING org.eclipse.emf.mapping_2.7.0.v20120130-0943
375 STARTING org.eclipse.emf.mapping.ecore_2.6.0.v20120130-0943
376 STARTING org.eclipse.emf.mapping.ecore.editor_2.6.0.v20120130-0943
377 STARTING org.eclipse.emf.mapping.ecore2ecore_2.7.0.v20120130-0943
378 STARTING org.eclipse.emf.mapping.ecore2ecore.editor_2.5.0.v20120130-0943
379 STARTING org.eclipse.emf.mapping.ecore2xml_2.7.0.v20120130-0943
380 STARTING org.eclipse.emf.mapping.ecore2xml.ui_2.6.0.v20120130-0943
381 STARTING org.eclipse.emf.mapping.ui_2.6.0.v20120130-0943
382 ACTIVE org.eclipse.equinox.app_1.3.100.v20111010-1614
383 STARTING org.eclipse.equinox.bidi_0.9.0.v20111215-1958
384 ACTIVE org.eclipse.equinox.common_3.6.100.v20120209-1951
385 STARTING org.eclipse.equinox.concurrent_1.0.200.v20111010-1614
386 ACTIVE org.eclipse.equinox.console_1.0.0.v20111215-1210
387 ACTIVE org.eclipse.equinox.ds_1.4.0.v20120112-1400
388 ACTIVE org.eclipse.equinox.event_1.2.100.v20111010-1614
389 ACTIVE org.eclipse.equinox.frameworkadmin_2.0.0.v20110808-1657
390 STARTING org.eclipse.equinox.frameworkadmin.equinox_1.0.400.v20110905-2042
391 STARTING org.eclipse.equinox.http.jetty_3.0.0.v20120216-2249
392 RESOLVED org.eclipse.equinox.http.registry_1.1.100.v20111010-1614
393 STARTING org.eclipse.equinox.http.servlet_1.1.300.v20111202-1521
394 STARTING org.eclipse.equinox.jsp.jasper_1.0.300.v20111202-1521
395 STARTING org.eclipse.equinox.jsp.jasper.registry_1.0.200.v20111010-1614
396 RESOLVED org.eclipse.equinox.launcher_1.3.0.v20120308-1358
Fragments=397
397 RESOLVED org.eclipse.equinox.launcher.gtk.linux.x86_1.1.200.v20120305-1541
Master=396
398 ACTIVE org.eclipse.equinox.p2.artifact.repository_1.1.200.v20120209-1054
399 STARTING org.eclipse.equinox.p2.console_1.0.300.v20110808-1657
400 ACTIVE org.eclipse.equinox.p2.core_2.2.0.v20120301-0711
401 ACTIVE org.eclipse.equinox.p2.director_2.2.0.v20120301-2203
402 STARTING org.eclipse.equinox.p2.director.app_1.0.300.v20111212-1216
403 ACTIVE org.eclipse.equinox.p2.directorywatcher_1.0.300.v20110808-1657
404 ACTIVE org.eclipse.equinox.p2.engine_2.2.0.v20120301-0711
405 ACTIVE org.eclipse.equinox.p2.extensionlocation_1.2.100.v20110808-1657
406 ACTIVE org.eclipse.equinox.p2.garbagecollector_1.0.200.v20110808-1657
407 RESOLVED org.eclipse.equinox.p2.jarprocessor_1.0.200.v20110808-1657
408 ACTIVE org.eclipse.equinox.p2.metadata_2.1.0.v20120227-1533
409 ACTIVE org.eclipse.equinox.p2.metadata.repository_1.2.0.v20110808-1657
410 ACTIVE org.eclipse.equinox.p2.operations_2.2.0.v20111122-1412
411 ACTIVE org.eclipse.equinox.p2.publisher_1.2.0.v20120309-0029
412 ACTIVE org.eclipse.equinox.p2.publisher.eclipse_1.1.0.v20120309-1937
413 STARTING org.eclipse.equinox.p2.ql_2.0.100.v20110808-1657
414 ACTIVE org.eclipse.equinox.p2.reconciler.dropins_1.1.200.v20120301-2145
415 ACTIVE org.eclipse.equinox.p2.repository_2.1.100.v20120301-0711
416 STARTING org.eclipse.equinox.p2.repository.tools_2.0.100.v20120117-0330
417 ACTIVE org.eclipse.equinox.p2.touchpoint.eclipse_2.1.100.v20120117-0330
418 STARTING org.eclipse.equinox.p2.touchpoint.natives_1.0.300.v20120117-0330
419 ACTIVE org.eclipse.equinox.p2.transport.ecf_1.0.100.v20120305-0333
420 STARTING org.eclipse.equinox.p2.ui_2.2.0.v20120109-1423
421 STARTING org.eclipse.equinox.p2.ui.importexport_1.0.1.v20110818-1344
422 STARTING org.eclipse.equinox.p2.ui.sdk_1.0.200.v20110815-1744
423 ACTIVE org.eclipse.equinox.p2.ui.sdk.scheduler_1.1.0.v20110815-1744
424 ACTIVE org.eclipse.equinox.p2.updatechecker_1.1.200.v20110808-1657
425 ACTIVE org.eclipse.equinox.p2.updatesite_1.0.300.v20110808-1657
426 ACTIVE org.eclipse.equinox.preferences_3.5.0.v20120120-1210
427 ACTIVE org.eclipse.equinox.registry_3.5.200.v20111010-1614
Fragments=194
428 ACTIVE org.eclipse.equinox.security_1.1.100.v20111010-1614
429 STARTING org.eclipse.equinox.security.ui_1.1.0.v20111010-1614
430 ACTIVE org.eclipse.equinox.simpleconfigurator.manipulator_2.0.0.v20110808-1657
431 ACTIVE org.eclipse.equinox.util_1.0.300.v20111010-1614
432 STARTING org.eclipse.gef_3.7.2.v20111106-2020
433 STARTING org.eclipse.gef.doc.isv_3.5.0.v20111106-2020
434 STARTING org.eclipse.gef.examples.flow_3.7.0.v20101201-2050
435 STARTING org.eclipse.gef.examples.logic_3.7.2.v20110928-2020
436 STARTING org.eclipse.gef.examples.shapes_3.7.0.v20101201-2050
437 STARTING org.eclipse.gef.examples.text_3.7.0.v20101201-2050
438 STARTING org.eclipse.gef.examples.ui.pde_3.7.2.v20110930-2020
439 STARTING org.eclipse.gmf_1.4.1.v20100720-0030
440 STARTING org.eclipse.gmf.doc_1.3.0.v20090729-2031
441 STARTING org.eclipse.gmf.examples.runtime.ui.pde_1.4.1.v20100720-0030
442 STARTING org.eclipse.gmf.runtime.common.core_1.4.0.v20100423-2359
443 STARTING org.eclipse.gmf.runtime.common.ui_1.4.0.v20100518-2230
444 STARTING org.eclipse.gmf.runtime.common.ui.action_1.2.0.v20090403-1720
445 STARTING org.eclipse.gmf.runtime.common.ui.action.ide_1.4.0.v20100223-2359
446 STARTING org.eclipse.gmf.runtime.common.ui.printing_1.4.0.v20100223-2359
Fragments=447
447 RESOLVED org.eclipse.gmf.runtime.common.ui.printing.win32_1.4.0.v20100223-2359
Master=446
448 STARTING org.eclipse.gmf.runtime.common.ui.services_1.3.0.v20100423-2359
449 STARTING org.eclipse.gmf.runtime.common.ui.services.action_1.4.0.v20100430-1518
450 STARTING org.eclipse.gmf.runtime.common.ui.services.dnd_1.4.0.v20100423-2359
451 STARTING org.eclipse.gmf.runtime.common.ui.services.dnd.ide_1.2.0.v20090403-1720
452 STARTING org.eclipse.gmf.runtime.common.ui.services.properties_1.3.0.v20100115-2350
453 STARTING org.eclipse.gmf.runtime.draw2d.ui_1.4.1.v20100909-1300
454 STARTING org.eclipse.gmf.runtime.draw2d.ui.render_1.4.1.v20100813-0030
455 STARTING org.eclipse.gmf.runtime.draw2d.ui.render.awt_1.4.1.v20100720-0030
456 STARTING org.eclipse.gmf.runtime.emf.clipboard.core_1.4.0.v20100430-1518
457 STARTING org.eclipse.gmf.runtime.gef.ui_1.4.0.v20100430-1518
458 STARTING org.eclipse.gmf.runtime.notation_1.4.1.v20100717-0059
459 STARTING org.eclipse.gmf.runtime.notation.edit_1.4.0.v20100512-1416
460 STARTING org.eclipse.gmf.runtime.sdk_1.4.1.v20100720-0030
461 STARTING org.eclipse.gmf.sdk_1.0.0.v20090615-0700
462 RESOLVED org.eclipse.gmf.templates.legacy_1.0.1.v20100831-1541
463 STARTING org.eclipse.gmf.tooling_2.1.0.v20090615-0700
464 ACTIVE org.eclipse.help_3.6.0.v20111021
465 STARTING org.eclipse.help.base_3.6.100.v201203141800
466 STARTING org.eclipse.help.ui_3.5.200.v20111129-2049
467 STARTING org.eclipse.help.webapp_3.6.100.v20120301-0843
468 RESOLVED org.eclipse.jdt_3.8.0.v201203141800
469 RESOLVED org.eclipse.jdt.annotation_1.0.0.v20120312-1601
470 STARTING org.eclipse.jdt.apt.core_3.3.500.v20111011-0800
471 STARTING org.eclipse.jdt.apt.pluggable.core_1.0.400.v20111011-0800
472 STARTING org.eclipse.jdt.apt.ui_3.3.300.v20111011-0800
473 RESOLVED org.eclipse.jdt.compiler.apt_1.0.500.v20111201-1324
Master=475
474 RESOLVED org.eclipse.jdt.compiler.tool_1.0.101.v20120222-0935
Master=475
475 ACTIVE org.eclipse.jdt.core_3.8.1.v20120314-0818
Fragments=473, 474
476 ACTIVE org.eclipse.jdt.core.manipulation_1.5.0.v20111215-1434
477 ACTIVE org.eclipse.jdt.debug_3.7.100.v20120307-1526
478 ACTIVE org.eclipse.jdt.debug.ui_3.6.100.v20120305-1601
479 RESOLVED org.eclipse.jdt.doc.isv_3.8.0.v20120314-0632
480 RESOLVED org.eclipse.jdt.doc.user_3.8.0.v20120314-0632
481 STARTING org.eclipse.jdt.junit_3.7.100.v20120309-1954
482 STARTING org.eclipse.jdt.junit.core_3.7.100.v20120306-1141
483 RESOLVED org.eclipse.jdt.junit.runtime_3.4.300.v20111215-1434
484 RESOLVED org.eclipse.jdt.junit4.runtime_1.1.200.v20111215-1434
485 ACTIVE org.eclipse.jdt.launching_3.6.100.v20120312-2024
486 ACTIVE org.eclipse.jdt.ui_3.8.0.v20120314-1731
487 STARTING org.eclipse.jem_2.0.501.v201111030500
488 STARTING org.eclipse.jem.beaninfo_2.0.300.v200905030615
489 RESOLVED org.eclipse.jem.beaninfo.vm_2.0.300.v201004110600
490 RESOLVED org.eclipse.jem.beaninfo.vm.common_2.0.300.v201004110600
491 STARTING org.eclipse.jem.proxy_2.0.400.v201101101900
492 STARTING org.eclipse.jem.util_2.1.100.v201103021400
493 STARTING org.eclipse.jem.workbench_2.0.400.v201104251400
494 RESOLVED org.eclipse.jetty.continuation_8.1.1.v20120215
495 RESOLVED org.eclipse.jetty.http_8.1.1.v20120215
496 RESOLVED org.eclipse.jetty.io_8.1.1.v20120215
497 RESOLVED org.eclipse.jetty.jmx_8.1.2.v20120308
498 RESOLVED org.eclipse.jetty.security_8.1.1.v20120215
499 RESOLVED org.eclipse.jetty.server_8.1.1.v20120215
500 RESOLVED org.eclipse.jetty.servlet_8.1.1.v20120215
501 RESOLVED org.eclipse.jetty.util_8.1.1.v20120215
502 ACTIVE org.eclipse.jface_3.8.0.v20120301-1821
503 RESOLVED org.eclipse.jface.databinding_1.6.0.v20111007-1312
504 RESOLVED org.eclipse.jface.text_3.8.0.v20120314-1011
505 RESOLVED org.eclipse.jpt.common.branding_1.0.0.v201104050000
506 ACTIVE org.eclipse.jpt.common.core_1.0.2.v201111103010
507 RESOLVED org.eclipse.jpt.common.eclipselink.branding_1.0.0.v201104050000
508 STARTING org.eclipse.jpt.common.eclipselink.core_1.0.1.v201108080010
509 STARTING org.eclipse.jpt.common.ui_1.0.1.v201201260000
510 RESOLVED org.eclipse.jpt.common.utility_2.0.1.v201111103010
511 RESOLVED org.eclipse.jpt.dbws.eclipselink.branding_1.0.0.v201103020003
512 RESOLVED org.eclipse.jpt.dbws.eclipselink.core.gen_1.0.0.v201104110000
513 STARTING org.eclipse.jpt.dbws.eclipselink.ui_1.0.0.v201104110000
514 STARTING org.eclipse.jpt.doc.isv_2.0.0.v201106030000
515 RESOLVED org.eclipse.jpt.doc.user_1.4.1.v201105190000
516 RESOLVED org.eclipse.jpt.jaxb.branding_1.0.0.v201103020003
517 RESOLVED org.eclipse.jpt.jaxb.core.schemagen_1.0.100.v201104110000
518 RESOLVED org.eclipse.jpt.jaxb.eclipselink.branding_1.0.0.v201103080000
519 RESOLVED org.eclipse.jpt.jaxb.eclipselink.core.schemagen_1.1.0.v201104120000
520 RESOLVED org.eclipse.jpt.jpa.branding_3.0.2.v201110193010
521 ACTIVE org.eclipse.jpt.jpa.core_3.0.2.v201201243020
522 STARTING org.eclipse.jpt.jpa.db_2.0.0.v201105030000
523 RESOLVED org.eclipse.jpt.jpa.db.ui_2.0.0.v201104110000
524 RESOLVED org.eclipse.jpt.jpa.eclipselink.branding_2.4.0.v201103020003
525 STARTING org.eclipse.jpt.jpa.eclipselink.core_2.0.2.v201111103010
526 RESOLVED org.eclipse.jpt.jpa.eclipselink.core.ddlgen_2.0.1.v201201260000
527 STARTING org.eclipse.jpt.jpa.eclipselink.ui_2.0.1.v201108080010
528 RESOLVED org.eclipse.jpt.jpa.gen_2.0.1.v201201260000
529 STARTING org.eclipse.jpt.jpa.ui_3.0.2.v201201243020
530 RESOLVED org.eclipse.jpt.jpadiagrameditor.branding_1.0.0.v201103020000
531 RESOLVED org.eclipse.jpt.jpadiagrameditor.doc.user_1.0.1.v201108101326
532 STARTING org.eclipse.jsch.core_1.1.400.v20111202-1616
533 STARTING org.eclipse.jsch.ui_1.1.400.I20111011-0800
534 RESOLVED org.eclipse.jsf.branding_3.2.0.v20100522
535 RESOLVED org.eclipse.jst.common.annotations.controller_1.1.300.v200908252030
536 RESOLVED org.eclipse.jst.common.annotations.core_1.1.300.v201004141630
537 STARTING org.eclipse.jst.common.annotations.ui_1.1.300.v201002081900
538 STARTING org.eclipse.jst.common.fproj.enablement.jdt.sdk_1.4.200.v201008101723
539 STARTING org.eclipse.jst.common.frameworks_1.1.501.v201201190400
540 ACTIVE org.eclipse.jst.common.project.facet.core_1.4.200.v201103170302
541 STARTING org.eclipse.jst.common.project.facet.ui_1.4.200.v201008182133
542 STARTING org.eclipse.jst.common.ui_1.0.101.v201201262000
543 STARTING org.eclipse.jst.ejb.doc.user_1.1.301.v201105130956
544 STARTING org.eclipse.jst.ejb.ui_1.1.601.v201201261600
545 STARTING org.eclipse.jst.ejb.ui.infopop_1.0.300.v2010022311013
546 STARTING org.eclipse.jst.j2ee_1.1.503.v201202090300
547 STARTING org.eclipse.jst.j2ee.core_1.2.102.v201202090300
548 RESOLVED org.eclipse.jst.j2ee.doc.user_1.1.400.v201008122303
549 STARTING org.eclipse.jst.j2ee.ejb_1.1.505.v201202020200
550 STARTING org.eclipse.jst.j2ee.ejb.annotation.model_1.1.300.v201003112036
551 STARTING org.eclipse.jst.j2ee.ejb.annotations.emitter_1.1.200.v200909290826
552 STARTING org.eclipse.jst.j2ee.ejb.annotations.ui_1.1.200.v201004290730
553 STARTING org.eclipse.jst.j2ee.ejb.annotations.xdoclet_1.2.200.v201103302125
554 RESOLVED org.eclipse.jst.j2ee.infopop_1.0.300.v200805140415
555 STARTING org.eclipse.jst.j2ee.jca_1.1.501.v201111030500
556 STARTING org.eclipse.jst.j2ee.jca.ui_1.1.400.v201004150700
557 STARTING org.eclipse.jst.j2ee.navigator.ui_1.1.501.v201107261503
558 STARTING org.eclipse.jst.j2ee.ui_1.1.503.v201201190400
559 STARTING org.eclipse.jst.j2ee.web_1.1.502.v201202090300
560 STARTING org.eclipse.jst.j2ee.xdoclet.runtime_1.1.300.v201004280700
561 STARTING org.eclipse.jst.jee_1.0.402.v201202021530
562 STARTING org.eclipse.jst.jee.ejb_1.0.301.v201007070821
563 STARTING org.eclipse.jst.jee.ui_1.0.401.v201202011107
564 STARTING org.eclipse.jst.jee.web_1.0.301.v201007070907
565 STARTING org.eclipse.jst.jsf.common.runtime_1.1.0.v20100510
566 RESOLVED org.eclipse.jst.jsf.doc.dev_1.2.0.v20100604
567 STARTING org.eclipse.jst.jsf.doc.user_1.2.1.v20100827
568 STARTING org.eclipse.jst.jsf.facesconfig_1.2.2.v201105031140
569 RESOLVED org.eclipse.jst.jsp.ui.infopop_1.0.200.v201004150328
570 STARTING org.eclipse.jst.server.core_1.2.202.v20110419
571 STARTING org.eclipse.jst.server.generic.core_1.0.700.v20101219
572 STARTING org.eclipse.jst.server.generic.jboss_1.6.1.v200904151730
573 STARTING org.eclipse.jst.server.generic.jonas_1.5.205.v200805140145
574 STARTING org.eclipse.jst.server.generic.oc4j_1.5.206.v20090812
575 STARTING org.eclipse.jst.server.generic.ui_1.0.505.v20100428
576 STARTING org.eclipse.jst.server.preview.adapter_1.1.100.v20100308
577 STARTING org.eclipse.jst.server.tomcat.core_1.1.301.v20111010_1242
578 STARTING org.eclipse.jst.server.tomcat.ui_1.1.200.v20100418
579 STARTING org.eclipse.jst.server.ui_1.1.202.v20110419
580 STARTING org.eclipse.jst.server.ui.doc.user_1.0.500.v201005192218
581 RESOLVED org.eclipse.jst.server.ui.infopop_1.0.400.v200805140145
582 STARTING org.eclipse.jst.server.websphere.core_1.0.302.v20080620
583 STARTING org.eclipse.jst.servlet.ui_1.1.502.v201202011054
584 STARTING org.eclipse.jst.servlet.ui.infopop_1.0.500.v201105122000
585 RESOLVED org.eclipse.jst.standard.schemas_1.2.0.v201101142102
586 STARTING org.eclipse.jst.ws.annotations.core_1.1.0.v201104031139
587 STARTING org.eclipse.jst.ws.axis.infopop_1.0.300.v200805140230
588 RESOLVED org.eclipse.jst.ws.axis.ui.doc.user_1.1.100.v201005192217
589 RESOLVED org.eclipse.jst.ws.axis2.ui.doc.user_1.0.100.v201005192217
590 RESOLVED org.eclipse.jst.ws.consumption.infopop_1.0.300.v200805140230
591 STARTING org.eclipse.jst.ws.consumption.ui.doc.user_1.0.600.v201005192217
592 RESOLVED org.eclipse.jst.ws.cxf.doc.user_1.0.100.v201009051717
593 RESOLVED org.eclipse.jst.ws.doc.user_1.0.600.v201005192217
594 RESOLVED org.eclipse.jst.ws.infopop_1.0.300.v200805140230
595 STARTING org.eclipse.jst.ws.jaxb.core_1.0.100.v201104031139
596 ACTIVE org.eclipse.jst.ws.jaxrs.core_1.0.301.v201108240656
597 STARTING org.eclipse.jst.ws.jaxrs.ui_1.0.401.v201108230518
598 STARTING org.eclipse.jst.ws.jaxws.core_1.0.100.v201104031139
599 RESOLVED org.eclipse.jst.ws.jaxws.doc.isv_1.1.0.v201104031551
600 RESOLVED org.eclipse.jst.ws.jaxws.doc.user_1.0.100.v201009051717
601 RESOLVED org.eclipse.jst.ws.jaxws.dom.doc.isv_1.0.0.v201004171919
602 STARTING org.eclipse.jst.ws.jaxws.dom.integration_1.0.101.v201201031437
603 RESOLVED org.eclipse.jst.ws.jaxws.dom.runtime_1.0.101.v201201031437
604 STARTING org.eclipse.jst.ws.jaxws.dom.ui_1.0.0.v201004171919
605 STARTING org.eclipse.jst.ws.jaxws.ui_1.0.100.v201104032053
606 ACTIVE org.eclipse.jst.ws.jaxws.utils_1.0.100.v201201031437
607 ACTIVE org.eclipse.ltk.core.refactoring_3.6.0.v20111215-1434
608 STARTING org.eclipse.ltk.ui.refactoring_3.7.0.v20111215-1434
609 ACTIVE org.eclipse.mylyn.commons.core_3.7.0.v20120319-0200
610 STARTING org.eclipse.mylyn.commons.identity.core_0.9.0.v20120319-0200
611 ACTIVE org.eclipse.mylyn.commons.net_3.7.0.v20120319-0200
612 ACTIVE org.eclipse.mylyn.commons.notifications.core_0.9.0.v20120319-0200
613 ACTIVE org.eclipse.mylyn.commons.notifications.feed_0.9.0.v20120319-0200
614 STARTING org.eclipse.mylyn.commons.notifications.ui_0.9.0.v20120319-0200
615 RESOLVED org.eclipse.mylyn.commons.repositories.core_0.9.0.v20120319-0200
616 STARTING org.eclipse.mylyn.commons.repositories.ui_0.9.0.v20120319-0200
617 RESOLVED org.eclipse.mylyn.commons.screenshots_3.7.0.v20120319-0200
618 ACTIVE org.eclipse.mylyn.commons.ui_3.7.0.v20120319-0200
619 ACTIVE org.eclipse.mylyn.commons.workbench_3.7.0.v20120319-0200
620 ACTIVE org.eclipse.mylyn.context.core_3.7.0.v20120319-0200
621 STARTING org.eclipse.mylyn.context.ui_3.7.0.v20120319-0200
622 RESOLVED org.eclipse.mylyn.discovery.core_3.7.0.v20120319-0200
623 RESOLVED org.eclipse.mylyn.discovery.ui_3.7.0.v20120319-0200
624 RESOLVED org.eclipse.mylyn.monitor.core_3.7.0.v20120319-0200
625 ACTIVE org.eclipse.mylyn.monitor.ui_3.7.0.v20120319-0200
626 STARTING org.eclipse.mylyn.resources.ui_3.7.0.v20120319-0200
627 RESOLVED org.eclipse.mylyn.tasks.core_3.7.0.v20120319-0200
628 ACTIVE org.eclipse.mylyn.tasks.ui_3.7.0.v20120319-0200
629 ACTIVE org.eclipse.mylyn.team.ui_3.7.0.v20120319-0200
630 RESOLVED org.eclipse.osgi.services_3.3.0.v20120307-2102
631 RESOLVED org.eclipse.osgi.util_3.2.200.v20120307-2102
632 ACTIVE org.eclipse.pde_3.6.100.v201203141800
633 ACTIVE org.eclipse.pde.api.tools_1.0.400.v20120301-1544
634 STARTING org.eclipse.pde.api.tools.ui_1.0.400.v20120309-1817
635 STARTING org.eclipse.pde.build_3.8.0.v20120119-1950
636 ACTIVE org.eclipse.pde.core_3.8.0.v20120309-1648
637 RESOLVED org.eclipse.pde.doc.user_3.8.0.v20120125-1750
638 STARTING org.eclipse.pde.ds.core_1.0.100.v20120117-2252
639 STARTING org.eclipse.pde.ds.ui_1.0.100.v20120117-2252
640 RESOLVED org.eclipse.pde.junit.runtime_3.4.100.v20120117-2252
641 ACTIVE org.eclipse.pde.launching_3.6.100.v20120309-1554
642 STARTING org.eclipse.pde.runtime_3.4.300.v20120117-2252
643 STARTING org.eclipse.pde.ua.core_1.0.100.v20120117-2252
644 STARTING org.eclipse.pde.ua.ui_1.0.200.v20120117-2252
645 ACTIVE org.eclipse.pde.ui_3.7.0.v20120314-2125
646 STARTING org.eclipse.pde.ui.templates_3.4.500.v20120123-1149
647 RESOLVED org.eclipse.persistence.antlr_2.3.2.v20111125-r10461
648 RESOLVED org.eclipse.persistence.asm_2.3.2.v20111125-r10461
649 RESOLVED org.eclipse.persistence.core_2.3.2.v20111125-r10461
650 RESOLVED org.eclipse.persistence.dbws_2.3.2.v20111125-r10461
651 RESOLVED org.eclipse.persistence.dbws.builder_2.3.2.v20111125-r10461
652 RESOLVED org.eclipse.persistence.jpa_2.3.2.v20111125-r10461
653 RESOLVED org.eclipse.persistence.jpa.jpql_1.0.1.v20111125-r10461
654 RESOLVED org.eclipse.persistence.moxy_2.3.2.v20111125-r10461
655 RESOLVED org.eclipse.platform_4.2.0.v20120315-1300
656 RESOLVED org.eclipse.platform.doc.isv_4.2.0.v20120308-2147
657 RESOLVED org.eclipse.platform.doc.user_4.2.0.v20120215-1818
658 STARTING org.eclipse.rcp_4.1.0.v20120315-1300
659 STARTING org.eclipse.sdk_4.2.0.v20120315-1300
660 ACTIVE org.eclipse.search_3.8.0.v20120127-1415
661 STARTING org.eclipse.servertools.doc.isv_1.0.100.v20090414
662 RESOLVED org.eclipse.swt_3.8.0.v3823a
Fragments=663
663 RESOLVED org.eclipse.swt.gtk.linux.x86_3.8.0.v3823a
Master=662
664 ACTIVE org.eclipse.team.core_3.6.100.v20111228-1339
665 STARTING org.eclipse.team.cvs.core_3.3.500.v20111223-0944
666 STARTING org.eclipse.team.cvs.ssh2_3.2.300.I20111011-0800
667 STARTING org.eclipse.team.cvs.ui_3.3.500.v20120313-1351
668 ACTIVE org.eclipse.team.ui_3.6.200.v20120228-1441
669 RESOLVED org.eclipse.text_3.5.200.v20120312-1446
670 ACTIVE org.eclipse.ui_3.103.0.v20120222-1413
671 STARTING org.eclipse.ui.browser_3.4.0.v20120208-1917
672 STARTING org.eclipse.ui.cheatsheets_3.4.200.v20111004-1656
673 ACTIVE org.eclipse.ui.console_3.5.100.v20111215-1438
674 ACTIVE org.eclipse.ui.editors_3.8.0.v20120130-1449
675 STARTING org.eclipse.ui.externaltools_3.2.100.v20111215-1438
676 ACTIVE org.eclipse.ui.forms_3.5.200.v20111215-1440
677 ACTIVE org.eclipse.ui.ide_3.8.0.v20120228-1703
678 RESOLVED org.eclipse.ui.ide.application_1.0.300.v20111215-1440
679 STARTING org.eclipse.ui.intro_3.4.200.v20111129-1749
680 STARTING org.eclipse.ui.intro.universal_3.2.600.v20111004-1656
681 STARTING org.eclipse.ui.navigator_3.5.101.v20120109-1223
682 STARTING org.eclipse.ui.navigator.resources_3.4.300.v20111215-1440
683 ACTIVE org.eclipse.ui.net_1.2.100.I20111011-0800
684 STARTING org.eclipse.ui.presentations.r21_3.2.100.I20080512-2000
685 ACTIVE org.eclipse.ui.trace_1.0.0.v20120217-1437
686 ACTIVE org.eclipse.ui.views_3.6.100.v20111215-1440
687 ACTIVE org.eclipse.ui.views.log_1.0.200.v20120117-2252
688 STARTING org.eclipse.ui.views.properties.tabbed_3.5.200.v20111215-1440
689 ACTIVE org.eclipse.ui.workbench_3.103.0.v20120314-2129
690 ACTIVE org.eclipse.ui.workbench.texteditor_3.8.0.v20120305-1350
691 ACTIVE org.eclipse.update.configurator_3.3.100.v20100512
692 STARTING org.eclipse.update.core_3.2.202.R34x_v20081128
Fragments=693
693 RESOLVED org.eclipse.update.core.linux_3.2.1.R34x_v20081024
Master=692
694 STARTING org.eclipse.wst.command.env_1.0.409.v201004211805
695 RESOLVED org.eclipse.wst.command.env.core_1.0.205.v201004211805
696 STARTING org.eclipse.wst.command.env.doc.user_1.5.300.v201005192225
697 STARTING org.eclipse.wst.command.env.infopop_1.0.100.v200805301544
698 STARTING org.eclipse.wst.command.env.ui_1.1.103.v201102260635
699 STARTING org.eclipse.wst.common.api.doc_1.0.1.v200807181737
700 STARTING org.eclipse.wst.common.core_1.2.0.v200908252030
701 ACTIVE org.eclipse.wst.common.emf_1.2.100.v201101101900
702 STARTING org.eclipse.wst.common.emfworkbench.integration_1.2.101.v201107140600
703 STARTING org.eclipse.wst.common.environment_1.0.400.v200912181832
704 STARTING org.eclipse.wst.common.fproj.sdk_1.4.200.v201008101723
705 STARTING org.eclipse.wst.common.frameworks_1.2.102.v201201190400
706 STARTING org.eclipse.wst.common.frameworks.ui_1.2.100.v201105122000
707 STARTING org.eclipse.wst.common.infopop_1.0.300.v201004280700
708 STARTING org.eclipse.wst.common.modulecore_1.2.103.v201201190400
709 STARTING org.eclipse.wst.common.modulecore.ui_1.0.102.v201201262000
710 ACTIVE org.eclipse.wst.common.project.facet.core_1.4.201.v201201101553
711 RESOLVED org.eclipse.wst.common.project.facet.doc.api_1.4.200.v201008101723
712 STARTING org.eclipse.wst.common.project.facet.ui_1.4.201.v201201101553
713 STARTING org.eclipse.wst.common.snippets_1.2.100.v201103281740
714 STARTING org.eclipse.wst.common.ui_1.1.500.v200911190730
715 STARTING org.eclipse.wst.common.uriresolver_1.1.401.v201004280700
716 STARTING org.eclipse.wst.css.core_1.1.501.v201111292150
717 STARTING org.eclipse.wst.css.ui_1.0.601.v201201101544
718 STARTING org.eclipse.wst.doc.user_1.2.0.v200806052254
719 STARTING org.eclipse.wst.dtd.core_1.1.501.v201107252021
720 STARTING org.eclipse.wst.dtd.ui_1.0.600.v201103171359
721 RESOLVED org.eclipse.wst.dtd.ui.infopop_1.0.400.v201008112018
722 RESOLVED org.eclipse.wst.dtdeditor.doc.user_1.0.700.v201008112018
723 STARTING org.eclipse.wst.html.core_1.1.502.v201202091936
724 STARTING org.eclipse.wst.html.ui_1.0.602.v201202091936
725 RESOLVED org.eclipse.wst.html.ui.infopop_1.0.200.v201004150328
726 STARTING org.eclipse.wst.internet.cache_1.0.400.v201004280700
727 STARTING org.eclipse.wst.internet.monitor.core_1.0.505.v20110419
728 STARTING org.eclipse.wst.internet.monitor.ui_1.0.507.v20110817_1651
729 ACTIVE org.eclipse.wst.jsdt.core_1.1.102.v201111090634
730 STARTING org.eclipse.wst.jsdt.debug.core_2.0.101.v201201112313
731 STARTING org.eclipse.wst.jsdt.debug.crossfire_1.0.150.v201201112259
732 STARTING org.eclipse.wst.jsdt.debug.rhino_1.0.101.v201201112313
733 RESOLVED org.eclipse.wst.jsdt.debug.rhino.debugger_1.0.201.v201201112313
734 STARTING org.eclipse.wst.jsdt.debug.rhino.ui_1.0.1.v201201112313
735 RESOLVED org.eclipse.wst.jsdt.debug.transport_1.0.1.v201201112313
736 STARTING org.eclipse.wst.jsdt.debug.ui_1.0.101.v201201112313
737 RESOLVED org.eclipse.wst.jsdt.doc_1.0.401.v201201311821
738 STARTING org.eclipse.wst.jsdt.manipulation_1.0.300.v201104272153
739 STARTING org.eclipse.wst.jsdt.support.firefox_1.0.400.v201008112000
740 RESOLVED org.eclipse.wst.jsdt.support.ie_1.0.400.v201008112000
741 STARTING org.eclipse.wst.jsdt.ui_1.1.102.v201201131900
742 STARTING org.eclipse.wst.jsdt.web.core_1.0.401.v201108152113
743 STARTING org.eclipse.wst.jsdt.web.ui_1.0.401.v201108152113
744 STARTING org.eclipse.wst.server.core_1.1.304.v20120208_1420
745 STARTING org.eclipse.wst.server.discovery_1.0.200.v20110518
746 STARTING org.eclipse.wst.server.http.core_1.0.200.v20090429
747 STARTING org.eclipse.wst.server.http.ui_1.0.200.v20090113
748 STARTING org.eclipse.wst.server.preview.adapter_1.1.0.v20090311b
749 STARTING org.eclipse.wst.server.ui_1.3.0.v20120210_1439
750 STARTING org.eclipse.wst.server.ui.doc.user_1.1.400.v201104111553
751 RESOLVED org.eclipse.wst.server.ui.infopop_1.1.100.v201005192130
752 ACTIVE org.eclipse.wst.sse.core_1.1.602.v201112071516
753 RESOLVED org.eclipse.wst.sse.doc.user_1.1.100.v201005192212
754 ACTIVE org.eclipse.wst.sse.ui_1.3.2.v201201041522
755 RESOLVED org.eclipse.wst.sse.ui.infopop_1.0.300.v201004150328
756 RESOLVED org.eclipse.wst.standard.schemas_1.0.401.v201108151912
757 STARTING org.eclipse.wst.validation_1.2.303.v201202090300
758 RESOLVED org.eclipse.wst.validation.doc.isv_1.2.200.v201004280700
759 RESOLVED org.eclipse.wst.validation.infopop_1.0.300.v200806041506
760 STARTING org.eclipse.wst.validation.ui_1.2.300.v201201050300
761 STARTING org.eclipse.wst.web_1.1.501.v201201190400
762 STARTING org.eclipse.wst.web.ui_1.1.500.v201111030500
763 STARTING org.eclipse.wst.web.ui.infopop_1.0.300.v200805140415
764 STARTING org.eclipse.wst.webtools.doc.user_1.0.500.v201005192212
765 STARTING org.eclipse.wst.ws.api.doc_1.0.2.v201004211732
766 STARTING org.eclipse.wst.ws.infopop_1.0.300.v200805140230
767 STARTING org.eclipse.wst.ws.service.policy_1.0.303.v201009221810
768 STARTING org.eclipse.wst.ws.service.policy.ui_1.0.300.v201108240515
769 STARTING org.eclipse.wst.wsdl.doc.isv_1.0.200.v201004201506
770 STARTING org.eclipse.wst.wsdl.ui.doc.user_1.0.800.v201008122303
771 STARTING org.eclipse.wst.wsdl.validation_1.1.502.v201104071820
772 RESOLVED org.eclipse.wst.wsi.ui.doc.user_1.0.700.v201008122303
773 STARTING org.eclipse.wst.xml.core_1.1.602.v201201091944
774 STARTING org.eclipse.wst.xml.ui_1.1.202.v201112071516
775 RESOLVED org.eclipse.wst.xml.ui.infopop_1.0.400.v201004292007
776 RESOLVED org.eclipse.wst.xml.xpath2_1.1.0.v200910101444
777 RESOLVED org.eclipse.wst.xml.xpath2.processor_2.0.0.v201105120439
778 RESOLVED org.eclipse.wst.xml.xpath2.processor.doc.user_2.0.0.v201105190326
779 RESOLVED org.eclipse.wst.xmleditor.doc.user_1.0.700.v201005192212
780 RESOLVED org.eclipse.wst.xsdeditor.doc.user_1.0.800.v201005192212
781 RESOLVED org.eclipse.wst.xsl_1.2.0.v201009121641
782 RESOLVED org.eclipse.wst.xsl.doc_1.0.100.v201004292007
783 STARTING org.eclipse.wst.xsl.exslt.core_1.0.0.v201005240426
784 RESOLVED org.eclipse.wst.xsl.jaxp.debug_1.0.200.v201103081922
785 RESOLVED org.eclipse.wst.xsl.saxon_1.0.200.v201103081922
786 STARTING org.eclipse.wst.xsl.sdk.documentation_1.0.100.v201006012005
787 RESOLVED org.eclipse.wst.xsl.xalan_1.0.100.v201103081922
788 RESOLVED org.eclipse.zest.core_1.3.0.v20110221-2050
789 RESOLVED org.eclipse.zest.layouts_1.1.0.v20110425-2050
790 STARTING org.hamcrest.core_1.1.0.v20090501071000
791 RESOLVED org.jdom_1.0.0.v201005080400
792 RESOLVED org.junit_3.8.2.v3_8_2_v20100427-1100
793 RESOLVED org.junit_4.8.2.v4_8_2_v20110321-1705
794 RESOLVED org.junit4_4.8.1.v20111115-0800
795 RESOLVED org.mortbay.jetty.util_6.1.23.v201012071420
796 RESOLVED org.mozilla.javascript_1.7.2.v201005080400
797 RESOLVED org.objectweb.asm_3.3.1.v201105211655
798 RESOLVED org.sat4j.core_2.3.0.v20110329
799 RESOLVED org.sat4j.pb_2.3.0.v20110329
800 RESOLVED org.slf4j.api_1.6.4.v20120130-2120
Fragments=4
801 ACTIVE org.tigris.subversion.clientadapter_1.6.12
802 ACTIVE org.tigris.subversion.clientadapter.javahl_1.6.17
803 ACTIVE org.tigris.subversion.clientadapter.svnkit_1.6.15
804 ACTIVE org.tigris.subversion.subclipse.core_1.6.18
805 RESOLVED org.tigris.subversion.subclipse.doc_1.3.0
806 STARTING org.tigris.subversion.subclipse.graph_1.0.9
807 ACTIVE org.tigris.subversion.subclipse.mylyn_3.0.0
808 ACTIVE org.tigris.subversion.subclipse.tools.usage_1.0.1
809 ACTIVE org.tigris.subversion.subclipse.ui_1.6.18
810 STARTING org.tmatesoft.svnkit_1.3.5.7406
811 RESOLVED org.uddi4j_2.0.5.v200805270300
812 RESOLVED org.w3c.css.sac_1.3.1.v200903091627
813 RESOLVED org.w3c.css.sac_1.3.0.v200805290154
814 RESOLVED org.w3c.dom.events_3.0.0.draft20060413_v200905140418
815 RESOLVED org.w3c.dom.smil_1.0.0.v200806040011
816 RESOLVED org.w3c.dom.smil_1.0.1.v200903091627
817 RESOLVED org.w3c.dom.svg_1.1.0.v201011041433
818 INSTALLED org.w3c.dom.svg_1.1.0.v200806040011
819 RESOLVED org.w3c.sac_1.3.0.v20120213
osgi>
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #872030 is a reply to message #872026] Tue, 15 May 2012 06:41 Go to previous messageGo to next message
This is the ss of your Host Eclipse not? I want to see the one from your
RCP launch.
Tom
Am 15.05.12 12:38, schrieb Rajesh KP:
> Eclipse!osgi> ss
> id State Bundle
> 1 ACTIVE
> Master=800
> 112 STARTING
> 116 STARTING
> 117 STARTING
> 118 STARTING
> 119 STARTING
> 121 STARTING
> 122 STARTING
> 128 STARTING
> 130 STARTING
> 132 STARTING
> 133 STARTING
> 134 STARTING
> 135 STARTING
> 138 STARTING
> 139 STARTING
> 140 STARTING
> 141 STARTING
> 142 STARTING
> 144 STARTING
> 145 STARTING
> 146 STARTING
> 147 STARTING
> 148 STARTING
> 149 STARTING
> 150 STARTING
> 151 STARTING
> 152 STARTING
> 153 STARTING
> 154 STARTING
> 155 STARTING
> 156 STARTING
> 157 STARTING
> 158 STARTING
> 159 STARTING
> 160 STARTING
> 161 RESOLVED
> 162 STARTING
> 163 STARTING
> 164 STARTING
> 167 STARTING
> 168 STARTING
> 171 STARTING
> 179 RESOLVED
> 180 ACTIVE
> 181 STARTING
> Fragments=186
> 186 RESOLVED
> Master=185
> Fragments=189
> Master=188
> 192 ACTIVE
> 193 STARTING
> 194 RESOLVED
> Master=427
> 197 STARTING
> 199 STARTING
> 200 STARTING
> 201 STARTING
> 202 STARTING
> 203 STARTING
> 204 STARTING
> 205 STARTING
> 206 STARTING
> 207 STARTING
> 208 STARTING
> 209 STARTING
> 210 STARTING
> 211 STARTING
> 212 STARTING
> 213 STARTING
> 214 STARTING
> 215 STARTING
> 216 STARTING
> 217 STARTING
> 218 STARTING
> 219 STARTING
> 220 STARTING
> 222 STARTING
> 223 STARTING
> 224 STARTING
> 225 STARTING
> 226 STARTING
> 227 STARTING
> 228 STARTING
> 229 STARTING
> 230 STARTING
> 231 STARTING
> 232 STARTING
> 233 STARTING
> 234 STARTING
> 235 STARTING
> 236 STARTING
> 237 STARTING
> 238 STARTING
> 239 STARTING
> 240 STARTING
> 241 STARTING
> 242 STARTING
> 243 STARTING
> 244 STARTING
> 245 STARTING
> 246 STARTING
> 247 STARTING
> 248 STARTING
> 249 STARTING
> 250 STARTING
> 251 STARTING
> 252 STARTING
> 253 STARTING
> 254 STARTING
> 255 STARTING
> 256 STARTING
> 257 STARTING
> 258 STARTING
> 259 STARTING
> 260 STARTING
> 261 STARTING
> 262 STARTING
> 263 STARTING
> 264 STARTING
> 265 STARTING
> 266 STARTING
> 267 STARTING
> 268 STARTING
> 269 STARTING
> 270 STARTING
> 271 STARTING
> 272 STARTING
> 273 STARTING
> 274 STARTING
> 275 STARTING
> 276 STARTING
> 279 STARTING
> 280 STARTING
> 282 STARTING
> 283 STARTING
> 284 STARTING
> 285 STARTING
> 288 STARTING
> 289 STARTING
> 290 STARTING
> 291 STARTING
> 292 STARTING
> 293 STARTING
> 294 STARTING
> 295 STARTING
> 296 STARTING
> 297 STARTING
> 298 STARTING
> 299 STARTING
> 300 STARTING
> 301 STARTING
> 302 STARTING
> 303 STARTING
> 304 STARTING
> 305 STARTING
> 307 STARTING
> 308 STARTING
> 309 STARTING
> 310 STARTING
> 311 STARTING
> 312 STARTING
> 313 STARTING
> 315 STARTING
> 316 STARTING
> 317 STARTING
> 318 STARTING
> 319 STARTING
> 338 ACTIVE
> 339 ACTIVE
> Fragments=349
> 345 STARTING
> Fragments=348
> 346 STARTING
> Fragments=347
> 347 RESOLVED
> Master=346
> 348 RESOLVED
> Master=345
> Master=342
> 376 STARTING
> 378 STARTING
> 380 STARTING
> 390 STARTING
> 395 STARTING
> Fragments=397
> 397 RESOLVED
> Master=396
> 398 ACTIVE
> 402 STARTING
> 403 ACTIVE
> 405 ACTIVE
> 406 ACTIVE
> 407 RESOLVED
> 409 ACTIVE
> 412 ACTIVE
> 414 ACTIVE
> 416 STARTING
> 417 ACTIVE
> 418 STARTING
> 419 ACTIVE
> 421 STARTING
> 423 ACTIVE
> 424 ACTIVE
> Fragments=194
> 430 ACTIVE
> 441 STARTING
> 444 STARTING
> 445 STARTING
> 446 STARTING
> Fragments=447
> 447 RESOLVED
> Master=446
> 448 STARTING
> 449 STARTING
> 450 STARTING
> 451 STARTING
> 452 STARTING
> 454 STARTING
> 455 STARTING
> 456 STARTING
> 459 STARTING
> 471 STARTING
> Master=475
> Master=475
> Fragments=473, 474
> 507 RESOLVED
> 508 STARTING
> 511 RESOLVED
> 512 RESOLVED
> 517 RESOLVED
> 518 RESOLVED
> 519 RESOLVED
> 524 RESOLVED
> 526 RESOLVED
> 530 RESOLVED
> 531 RESOLVED
> 535 RESOLVED
> 536 RESOLVED
> 537 STARTING
> 538 STARTING
> 540 ACTIVE
> 541 STARTING
> 550 STARTING
> 551 STARTING
> 552 STARTING
> 553 STARTING
> 560 STARTING
> 573 STARTING
> 577 STARTING
> 588 RESOLVED
> 589 RESOLVED
> 590 RESOLVED
> 591 STARTING
> 602 STARTING
> 603 RESOLVED
> 610 STARTING
> 612 ACTIVE
> 613 ACTIVE
> 614 STARTING
> 615 RESOLVED
> 616 STARTING
> 617 RESOLVED
> 651 RESOLVED
> Fragments=663
> Master=662
> 682 STARTING
> 688 STARTING
> Fragments=693
> Master=692
> 696 STARTING
> 697 STARTING
> 702 STARTING
> 706 STARTING
> 709 STARTING
> 710 ACTIVE
> 711 RESOLVED
> 712 STARTING
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #872044 is a reply to message #872030] Tue, 15 May 2012 07:13 Go to previous messageGo to next message
Hey Tom... Did you really need to quote his full set of 720 line??? :-/
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #872068 is a reply to message #872044] Tue, 15 May 2012 08:07 Go to previous messageGo to next message
My application crashed as it starts so not sure how to access to the OSGi console. But I managed to get the ss o/p before the application crashed. Below is the o/p -
Also please let me know if there is better way to get the console access of the application.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.8.0.v20120430-1750
1 ACTIVE org.eclipse.equinox.common_3.6.100.v20120209-1951
2 ACTIVE org.eclipse.update.configurator_3.3.200.v20120405-1314
3 ACTIVE org.eclipse.core.runtime_3.8.0.v20120308-2101
4 RESOLVED org.apache.batik.css_1.6.0.v201011041432
5 STARTING org.eclipse.equinox.simpleconfigurator.manipulator_2.0.0.v20110808-1657
6 STARTING org.eclipse.team.ui_3.6.200.v20120417-1540
7 RESOLVED org.w3c.css.sac_1.3.1.v200903091627
8 STARTING org.eclipse.e4.ui.workbench.addons.swt_0.10.0.v20120502-1520
9 RESOLVED org.eclipse.jetty.continuation_8.1.3.v20120416
10 STARTING org.eclipse.ecf_3.1.300.v20120319-0616
Fragments=221
11 RESOLVED org.eclipse.core.commands_3.6.1.v20120426-1411
12 STARTING org.eclipse.equinox.util_1.0.300.v20111010-1614
13 STARTING org.eclipse.wst.common.emfworkbench.integration_1.2.101.v201107140600
14 RESOLVED org.eclipse.equinox.p2.jarprocessor_1.0.200.v20110808-1657
15 STARTING org.eclipse.equinox.security_1.1.100.v20120424-1439
16 STARTING org.eclipse.emf.ecore_2.7.0.v20120127-1122
17 STARTING org.eclipse.e4.ui.model.workbench_0.10.0.v20120416-1607
18 STARTING org.eclipse.equinox.p2.core_2.2.0.v20120430-0525
19 STARTING org.eclipse.debug.ui_3.8.0.v20120501-1711
20 STARTING org.eclipse.wst.common.frameworks_1.2.102.v201201190400
21 STARTING org.eclipse.ui.navigator_3.5.101.v20120423-0910
22 RESOLVED ch.qos.logback.classic_1.0.0.v20111214-2030
23 STARTING org.eclipse.update.core_3.2.202.R34x_v20081128
Fragments=198
24 RESOLVED javax.servlet.jsp_2.2.0.v201112011158
25 STARTING org.eclipse.ui.workbench_3.103.0.v20120503-2003
26 STARTING org.eclipse.equinox.event_1.2.100.v20111010-1614
27 STARTING org.eclipse.jdt.core_3.8.1.v20120502-0834
Fragments=99, 167
28 STARTING org.eclipse.wst.html.core_1.1.502.v201202091936
29 STARTING org.eclipse.emf.common_2.7.0.v20120127-1122
30 RESOLVED org.apache.xerces_2.9.0.v201101211617
31 RESOLVED org.eclipse.core.filesystem.linux.x86_1.4.0.v20110423-0524
Master=148
32 RESOLVED javax.annotation_1.0.0.v20101115-0725
33 RESOLVED org.apache.commons.logging_1.0.4.v201101211617
34 STARTING org.eclipse.core.filebuffers_3.5.200.v20120424-1340
35 STARTING org.eclipse.e4.ui.services_0.10.0.v20120503-1715
36 RESOLVED org.eclipse.platform_4.2.0.v20120503-1817
37 STARTING org.eclipse.wst.sse.ui_1.3.2.v201201041522
38 STARTING org.eclipse.help_3.6.0.v20111021
39 STARTING org.eclipse.wst.validation_1.2.303.v201202090300
40 ACTIVE org.eclipse.equinox.preferences_3.5.0.v20120410-1344
41 ACTIVE org.eclipse.equinox.registry_3.5.200.v20120427-1430
Fragments=135
42 STARTING org.eclipse.wst.css.core_1.1.501.v201111292150
43 RESOLVED org.eclipse.swt_3.100.0.v4229f
Fragments=176
44 STARTING org.eclipse.ui.console_3.5.100.v20120412-1718
45 STARTING org.eclipse.ui.views.log_1.0.200.v20120117-2252
46 RESOLVED org.apache.lucene.core_2.9.1.v201101211721
47 STARTING org.eclipse.help.base_3.6.100.v20120503-1817
48 RESOLVED org.eclipse.equinox.ds_1.4.0.v20120112-1400
49 STARTING org.eclipse.equinox.frameworkadmin.equinox_1.0.400.v20120428-0117
50 RESOLVED org.eclipse.jdt_3.8.0.v20120503-1817
51 RESOLVED org.eclipse.osgi.util_3.2.200.v20120307-2102
52 STARTING org.hamcrest.core_1.1.0.v20090501071000
53 RESOLVED org.sat4j.pb_2.3.0.v20110329
54 STARTING org.eclipse.wst.validation.ui_1.2.300.v201201050300
55 STARTING org.eclipse.equinox.p2.artifact.repository_1.1.200.v20120430-1959
56 STARTING org.eclipse.core.databinding.property_1.4.0.v20111007-1320
57 STARTING org.eclipse.core.databinding_1.4.1.v20111109-0626
58 STARTING org.eclipse.wst.common.ui_1.1.500.v200911190730
59 STARTING org.eclipse.equinox.concurrent_1.0.200.v20111010-1614
60 STARTING org.eclipse.ui.navigator.resources_3.4.300.v20111007-1320
61 STARTING org.eclipse.wst.common.core_1.2.0.v200908252030
62 STARTING org.eclipse.equinox.http.servlet_1.1.300.v20111202-1521
63 RESOLVED javax.servlet_3.0.0.v201112011016
64 ACTIVE org.eclipse.jface_3.8.0.v20120429-1603
65 STARTING org.eclipse.e4.ui.workbench.swt_0.10.0.v20120430-1619
66 STARTING org.eclipse.wst.xml.ui_1.1.202.v201112071516
67 RESOLVED org.apache.jasper.glassfish_2.2.2.v201112011158
68 STARTING org.eclipse.equinox.p2.updatesite_1.0.400.v20120412-1615
69 RESOLVED org.eclipse.jface.databinding_1.6.0.v20111109-0627
70 RESOLVED org.eclipse.jetty.server_8.1.3.v20120416
71 STARTING org.eclipse.emf.edit_2.7.2.v20120130-0943
72 STARTING org.eclipse.ui.browser_3.4.0.v20120207-1824
73 STARTING org.eclipse.ui_3.103.0.v20120424-1749
74 STARTING org.eclipse.e4.ui.bindings_0.10.0.v20120502-2004
75 STARTING org.eclipse.e4.core.di.extensions_0.10.0.v20120201-1503
76 STARTING org.eclipse.e4.core.contexts_1.0.0.v20120502-1817
77 RESOLVED org.eclipse.core.databinding.beans_1.2.100.v20111007-1320
78 STARTING org.eclipse.search_3.8.0.v20120427-1130
79 RESOLVED javax.mail_1.4.0.v201005080615
80 STARTING org.eclipse.jdt.debug_3.7.100.v20120412-1617
81 STARTING org.eclipse.emf.common.ui_2.7.0.v20120130-0943
82 STARTING org.eclipse.e4.ui.css.swt.theme_0.9.1.v20120429-2156
83 STARTING org.eclipse.equinox.jsp.jasper.registry_1.0.200.v20111010-1614
84 RESOLVED org.eclipse.ui.ide.application_1.0.300.v20120503-1731
85 STARTING org.eclipse.equinox.p2.metadata_2.1.0.v20120430-2001
86 STARTING org.eclipse.e4.ui.di_0.10.0.v20120217-1935
87 ACTIVE org.eclipse.core.contenttype_3.4.100.v20110423-0524
88 STARTING org.eclipse.core.resources_3.8.0.v20120501-2009
89 STARTING org.eclipse.wst.common.project.facet.core_1.4.201.v201201101553
90 STARTING org.eclipse.pde.launching_3.6.100.v20120323-1614
91 RESOLVED org.apache.xml.resolver_1.2.0.v201005080400
92 STARTING org.eclipse.e4.core.di_1.1.0.v20120323-1437
93 STARTING org.eclipse.ui.externaltools_3.2.100.v20120412-1718
94 STARTING org.eclipse.gef_3.8.0.201205041431
95 STARTING org.eclipse.equinox.p2.repository_2.2.0.v20120501-1446
96 STARTING org.eclipse.pde.ui_3.7.0.v20120427-1610
97 STARTING org.eclipse.core.databinding.observable_1.4.1.v20111109-0641
98 STARTING org.eclipse.ui.editors_3.8.0.v20120418-1702
99 RESOLVED org.eclipse.jdt.compiler.tool_1.0.101.v20120222-0935
Master=27
100 STARTING org.eclipse.rcp_4.2.0.v20120503-1817
101 STARTING org.eclipse.ui.presentations.r21_3.2.100.I20080512-2000
102 STARTING org.eclipse.pde.runtime_3.4.300.v20120412-1931
103 ACTIVE org.eclipse.core.jobs_3.5.200.v20120113-1913
104 STARTING org.eclipse.equinox.security.ui_1.1.0.v20111010-1614
105 RESOLVED org.eclipse.jetty.jmx_8.1.3.v20120416
107 STARTING org.eclipse.equinox.http.jetty_3.0.0.v20120216-2249
108 STARTING org.eclipse.equinox.p2.publisher.eclipse_1.1.0.v20120428-1751
109 ACTIVE org.apache.felix.gogo.runtime_0.8.0.v201108120515
110 RESOLVED org.apache.lucene.analysis_2.9.1.v201101211721
111 STARTING org.eclipse.emf.ecore.xmi_2.7.0.v20120127-1122
112 STARTING org.eclipse.ui.views_3.6.100.v20111117-1456
113 RESOLVED org.slf4j.api_1.6.4.v20120130-2120
Fragments=206
115 RESOLVED org.apache.lucene_2.9.1.v201101211721
116 RESOLVED ch.qos.logback.core_1.0.0.v20111214-2030
117 STARTING org.eclipse.ecf.identity_3.1.200.v20120319-0616
118 STARTING org.eclipse.ui.workbench.texteditor_3.8.0.v20120403-1234
119 STARTING org.eclipse.equinox.p2.ui_2.2.0.v20120430-2044
120 STARTING org.eclipse.ui.trace_1.0.0.v20120217-1437
121 STARTING org.eclipse.wst.common.uriresolver_1.1.401.v201004280700
122 STARTING org.eclipse.wst.dtd.core_1.1.501.v201107252021
123 STARTING org.eclipse.core.runtime.compatibility.auth_3.2.200.v20110110
124 STARTING org.eclipse.ltk.core.refactoring_3.6.0.v20120320-1159
125 STARTING org.eclipse.ant.core_3.2.400.v20120405-1314
126 RESOLVED org.apache.batik.util.gui_1.6.0.v201011041432
127 STARTING org.eclipse.ant.launching_1.0.100.v20120405-1314
128 RESOLVED org.eclipse.e4.ui.workbench3_0.12.0.v20120215-1332
129 STARTING org.eclipse.e4.core.commands_0.10.0.v20120503-1715
130 STARTING org.eclipse.draw2d_3.8.0.201205041431
131 STARTING org.eclipse.wst.common.modulecore_1.2.103.v201201190400
132 STARTING org.eclipse.pde.core_3.8.0.v20120427-2041
133 ACTIVE org.apache.felix.gogo.shell_0.8.0.v201110170705
134 STARTING org.eclipse.pde.build_3.8.0.v20120428-0109
135 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.5.100.v20120502-1323
Master=41
136 STARTING org.eclipse.wst.common.emf_1.2.100.v201101101900
137 RESOLVED javax.inject_1.0.0.v20091030
138 STARTING org.eclipse.emf.ecore.edit_2.7.1.v20120130-0943
139 STARTING org.eclipse.ltk.ui.refactoring_3.7.0.v20120328-0956
140 RESOLVED org.eclipse.jface.text_3.8.0.v20120429-0625
142 STARTING org.eclipse.jdt.ui_3.8.0.v20120502-1904
143 STARTING org.eclipse.compare_3.5.300.v20120417-1515
144 STARTING org.eclipse.wst.css.ui_1.0.601.v201201101544
145 STARTING org.eclipse.ui.forms_3.5.200.v20111007-1320
146 RESOLVED org.mortbay.jetty.util_6.1.23.v201012071420
147 STARTING org.eclipse.equinox.p2.director_2.2.0.v20120301-2203
148 STARTING org.eclipse.core.filesystem_1.3.200.v20120306-1226
Fragments=31
149 RESOLVED org.eclipse.jdt.junit.runtime_3.4.300.v20111215-1434
150 STARTING org.eclipse.jdt.junit.core_3.7.100.v20120306-1141
151 STARTING org.eclipse.core.variables_3.2.600.v20120412-1718
152 RESOLVED org.eclipse.platform.doc.user_4.2.0.v20120322
153 RESOLVED org.eclipse.jetty.util_8.1.3.v20120416
154 RESOLVED org.w3c.dom.svg_1.1.0.v201011041433
155 STARTING org.eclipse.equinox.p2.operations_2.2.0.v20120430-2044
156 STARTING org.eclipse.core.externaltools_1.0.100.v20120412-1718
157 STARTING org.eclipse.equinox.simpleconfigurator_1.0.300.v20110815-1744
158 RESOLVED org.eclipse.jetty.io_8.1.3.v20120416
159 STARTING org.eclipse.equinox.p2.touchpoint.eclipse_2.1.100.v20120428-0117
160 RESOLVED org.eclipse.jetty.http_8.1.3.v20120416
161 STARTING org.eclipse.equinox.p2.metadata.repository_1.2.0.v20110808-1657
162 RESOLVED org.apache.batik.util_1.6.0.v201011041432
163 STARTING org.eclipse.wst.xml.core_1.1.602.v201201091944
164 STARTING org.eclipse.emf.edit.ui_2.7.0.v20120130-0943
165 RESOLVED org.apache.xml.serializer_2.7.1.v201005080400
166 RESOLVED org.eclipse.text_3.5.200.v20120312-1446
167 RESOLVED org.eclipse.jdt.compiler.apt_1.0.500.v20120423-0553
Master=27
168 STARTING org.eclipse.equinox.p2.director.app_1.0.300.v20120428-0517
169 ACTIVE org.eclipse.equinox.console_1.0.0.v20120430-1356
170 STARTING org.eclipse.jdt.debug.ui_3.6.100.v20120502-0150
171 RESOLVED org.eclipse.jetty.security_8.1.3.v20120416
172 STARTING org.eclipse.equinox.p2.repository.tools_2.0.100.v20120501-1314
173 STARTING org.eclipse.ui.ide_3.8.0.v20120502-0926
174 STARTING org.eclipse.equinox.p2.garbagecollector_1.0.200.v20110808-1657
175 STARTING org.eclipse.wst.sse.core_1.1.602.v201112071516
176 RESOLVED org.eclipse.swt.gtk.linux.x86_3.100.0.v4229f
Master=43
177 STARTING org.eclipse.equinox.p2.engine_2.2.0.v20120501-1502
178 STARTING org.eclipse.wst.html.ui_1.0.602.v201202091936
179 RESOLVED org.apache.ant_1.8.3.v20120321-1730
180 STARTING org.eclipse.jdt.junit_3.7.100.v20120316-1715
181 STARTING org.eclipse.ecf.filetransfer_5.0.0.v20120319-0616
182 STARTING org.eclipse.core.net_1.2.200.v20111202-1616
Fragments=205
183 STARTING org.eclipse.equinox.jsp.jasper_1.0.300.v20111202-1521
184 RESOLVED org.eclipse.jetty.servlet_8.1.3.v20120416
185 STARTING org.eclipse.emf_2.6.0.v20120130-0943
186 RESOLVED org.eclipse.equinox.http.registry_1.1.100.v20111010-1614
187 STARTING org.eclipse.e4.ui.css.swt_0.10.0.v20120429-2158
188 STARTING org.eclipse.emf.ecore.change_2.7.1.v20120127-1122
189 RESOLVED org.junit_4.10.0.v4_10_0_v20120426-0900
190 RESOLVED org.eclipse.equinox.launcher_1.3.0.v20120308-1358
Fragments=196
191 STARTING org.eclipse.jdt.launching_3.6.100.v20120430-2105
192 STARTING org.eclipse.core.expressions_3.4.300.v20120417-1825
193 STARTING org.eclipse.ui.intro_3.4.200.v20111129-1749
194 STARTING org.eclipse.team.core_3.6.100.v20120406-1150
195 STARTING org.eclipse.wst.common.frameworks.ui_1.2.100.v201105122000
196 RESOLVED org.eclipse.equinox.launcher.gtk.linux.x86_1.1.200.v20120426-1529
Master=190
197 RESOLVED org.eclipse.osgi.services_3.3.0.v20120307-2102
198 RESOLVED org.eclipse.update.core.linux_3.2.1.R34x_v20081024
Master=23
199 RESOLVED org.eclipse.pde_3.6.100.v20120503-1817
200 STARTING org.eclipse.ui.views.properties.tabbed_3.5.200.v20111007-1320
201 ACTIVE org.eclipse.core.runtime.compatibility_3.2.200.v20120308-2101
202 STARTING org.eclipse.ant.ui_3.5.300.v20120405-1314
203 STARTING org.eclipse.wst.common.environment_1.0.400.v200912181832
204 STARTING org.eclipse.help.webapp_3.6.100.v20120404-0944
205 RESOLVED org.eclipse.core.net.linux.x86_1.1.200.I20110419-0800
Master=182
206 RESOLVED ch.qos.logback.slf4j_1.0.0.v20120123-1500
Master=113
207 RESOLVED org.sat4j.core_2.3.0.v20110329
208 RESOLVED org.eclipse.e4.ui.widgets_0.11.0.v20120428-0140
209 STARTING org.eclipse.debug.core_3.7.100.v20120412-1718
210 STARTING org.eclipse.jdt.core.manipulation_1.5.0.v20111215-1434
211 RESOLVED javax.el_2.2.0.v201108011116
212 STARTING org.eclipse.equinox.bidi_0.9.0.v20111215-1958
213 RESOLVED org.w3c.dom.smil_1.0.0.v200806040011
215 STARTING org.eclipse.equinox.frameworkadmin_2.0.0.v20110808-1657
216 RESOLVED javax.xml_1.3.4.v201005080400
217 STARTING org.eclipse.e4.ui.workbench_0.10.1.v20120503-2003
218 STARTING org.eclipse.compare.core_3.5.200.v20120314-1627
219 RESOLVED javax.activation_1.1.0.v201105071233
220 RESOLVED org.eclipse.e4.ui.css.core_0.10.0.v20120429-2158
221 RESOLVED org.eclipse.ecf.ssl_1.0.100.v20120319-0616
Master=10
222 STARTING org.eclipse.e4.core.services_1.0.0.v20120118-2149
223 STARTING org.eclipse.ui.cheatsheets_3.4.200.v20111004-1656
224 STARTING com.ibm.icu_4.4.2.v20110823
225 ACTIVE org.eclipse.equinox.app_1.3.100.v20111010-1614
226 STARTING org.eclipse.ui.net_1.2.100.I20111011-0800
227 STARTING org.eclipse.equinox.p2.publisher_1.2.0.v20120428-0117
228 ACTIVE org.apache.felix.gogo.command_0.8.0.v201108120515
229 STARTING org.eclipse.e4.ui.workbench.renderers.swt_0.10.0.v20120502-1324
230 STARTING org.eclipse.jem.util_2.1.100.v201103021400
231 STARTING com.novell.idm.branding_4.0.0.qualifier
232 STARTING com.novell.core.checker_4.0.0.qualifier
233 STARTING com.novell.designer_4.0.0.qualifier
234 STARTING org.eclipse.help.ui_3.3.200.qualifier
235 STARTING com.novell.core.ecmaexprbuilder_4.0.0.qualifier
236 STARTING com.novell.idm.edit_4.0.0.qualifier
237 RESOLVED xdebug_4.0.0.qualifier
238 STARTING org.eclipse.enhancements_4.0.0.qualifier
239 STARTING com.novell.core.driverconfig_4.0.0.qualifier
240 STARTING com.novell.idm.policybuilder_4.0.0.qualifier
241 STARTING com.novell.designer.model_4.0.0.qualifier
242 STARTING com.novell.idm.docgen.editor_4.0.0.qualifier
243 STARTING com.novell.idm.policy_4.0.0.qualifier
244 STARTING com.novell.idm.entitlements_4.0.0.qualifier
245 STARTING com.novell.designer.localhistory_4.0.0.qualifier
246 STARTING com.novell.idm.docgen_4.0.0.qualifier
247 STARTING net.sourceforge.ehep_4.0.0.qualifier
248 STARTING com.novell.idm.datafloweditor_4.0.0.qualifier
249 STARTING com.novell.designer.model.edit_4.0.0.qualifier
250 STARTING com.novell.idm.jobeditor_4.0.0.qualifier
251 STARTING com.novell.idm.filter_4.0.0.qualifier
252 STARTING com.novell.idm.checker_4.0.0.qualifier
253 STARTING com.novell.idm.ecmascripteditor_4.0.0.qualifier
254 STARTING com.novell.core.dirmanager_4.0.0.qualifier
255 STARTING com.novell.idm.oldpolicybuilder_4.0.0.qualifier
256 STARTING com.novell.core.dstraceviewer_4.0.0.qualifier
257 STARTING com.novell.idm.modeler_4.0.0.qualifier
258 STARTING com.novell.designer.versioncontrolprovider_4.0.0.qualifier
259 STARTING com.novell.idm_4.0.0.qualifier
260 STARTING com.novell.idm.policybase_4.0.0.qualifier
261 STARTING com.novell.idm.deploy_4.0.0.qualifier
262 STARTING com.novell.core.scriptengineshell_4.0.0.qualifier
263 STARTING tightvnc_3.5.0.qualifier
264 STARTING com.novell.idm.perspective_4.0.0.qualifier
265 STARTING com.novell.idm.notificationtemplates_4.0.0.qualifier
266 ACTIVE com.novell.idm.rcp_4.0.0.qualifier
267 STARTING com.novell.core.ids_4.0.0.qualifier
268 STARTING com.novell.idm.projectview_4.0.0.qualifier
269 STARTING com.novell.idm.config_4.0.0.qualifier
270 STARTING com.novell.idm.rbe_4.0.0.qualifier
271 STARTING com.novell.idm.docgen.processor_4.0.0.qualifier
272 STARTING com.novell.core.webtools_4.0.0.qualifier
273 STARTING com.novell.idm.globaltable_4.0.0.qualifier
274 STARTING com.novell.core.datatools_4.0.0.qualifier
275 STARTING com.novell.idm.resourceeditor_4.0.0.qualifier
276 STARTING com.novell.idm.docgen.edit_4.0.0.qualifier
277 STARTING com.novell.idm.modelerbase_4.0.0.qualifier
278 STARTING com.novell.idm.schemamap_4.0.0.qualifier
279 STARTING com.novell.idm.versioncontrolprovider_4.0.0.qualifier
280 STARTING org.eclipse.ui.intro.universal_3.3.100.qualifier
281 STARTING com.novell.idm.dataflowview_4.0.0.qualifier
282 STARTING com.novell.core.iconeditor_4.0.0.qualifier
283 STARTING com.novell.idm.packagemanager_4.0.0.qualifier
284 STARTING com.novell.core_4.0.0.qualifier
285 STARTING com.novell.idm.simulation_4.0.0.qualifier
286 RESOLVED com.novell.core.xds_4.0.0.qualifier
287 STARTING com.novell.core.versioncontrol_4.0.0.qualifier
288 STARTING com.novell.core.jars_4.0.0.qualifier
289 STARTING com.novell.core.ecmascript.editorbase_4.0.0.qualifier
290 STARTING org.eclipse.wst.javascript.ui_1.0.200.v200805160650
291 STARTING org.eclipse.wst.javascript.core_1.0.200.v200805140200
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #872074 is a reply to message #872068] Tue, 15 May 2012 08:14 Go to previous messageGo to next message
Rajesh KP wrote on Tue, 15 May 2012 15:07
http://www.eclipse.org/forums/index.php/t/31369/
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #872083 is a reply to message #872068] Tue, 15 May 2012 08:20 Go to previous messageGo to next message
So this looks wrong. It should be ACTIVE! Do you have a custom
config.ini or configured something special in your .product-File?
What does org.eclipse.equinox.ds show in your launch config. It has to
be: Start Level 1, Auto-Start true.
If you launch with the -noexit parameter equinox will not terminate.
Tom
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #872095 is a reply to message #872083] Tue, 15 May 2012 08:55 Go to previous messageGo to next message
Bingo!
My custom config.ini was the cause! Once I set to generate default, my application launched successfully.
I've primarly have the below entries in my custom config.ini. Is that the cause? And how should it be corrected? Some code fix!?
osgi.bundles=org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
eclipse.product=com.novell.idm.rcp.Designer
eclipse.application=com.novell.idm.rcp.Designer
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #872105 is a reply to message #872095] Tue, 15 May 2012 09:23 Go to previous messageGo to next message
I guess there is no other fix than to remove it. When I build some OSGi DS for my RCP I initially had the problem, that my app wasn't starting the right bundles ath the correct time, so I needed to react to it. But I read somewhere, that it is best practice to avoid it, if possible.
Daniel
Re: Eclipse 3.x RCP application on Compatibility Layer - Exceptions [message #872967 is a reply to message #872105] Thu, 17 May 2012 03:40 Go to previous message
Ok, thank you.
Previous Topic:Using favicons as title image for MPart in a Stack
Next Topic:Eclipse 3.x RCP Editor throws exceptions on e4
Current Time: Sat Nov 08 14:03:19 EST 2025
Powered by FUDForum. Page generated in 0.34911 seconds
