Re: Report max generation time [message #871076 is a reply to message #870935] |
Thu, 10 May 2012 17:34   |
You could always spawn a thread to cancel the report after a certain
amount of time. Look at this example, (While it is not exactly what you
want it should get you close).
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
public class RunAndRenderTaskCancel {
public void runReport() throws EngineException
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setBIRTHome("C:\\birt\\birt-runtime-2_6_1\\birt-runtime-2_6_1\\ReportEngine");
config.setLogConfig("c:/temp/test", Level.FINEST);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
IReportRunnable design = null;
//Open the report design
design = engine.openReportDesign("Reports/TopNPercent.rptdesign");
//Create task to run and render the report,
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFileName("output/resample/TopNPercent.html");
options.setOutputFormat("html");
task.setRenderOption(options);
CancelReport cancelThread = new CancelReport( "cancelReport", task);
cancelThread.start();
long beginTime = System.currentTimeMillis();
task.run();
long endTime = System.currentTimeMillis();
long timeSpan = endTime - beginTime;
System.out.println("Report Runtime: " + timeSpan);
int teststatus = task.getStatus();
if( teststatus == 4){
System.out.println("Report was cancelled");
task.close();
engine.destroy();
}catch( Exception ex){
ex.printStackTrace();
finally
Platform.shutdown( );
System.out.println("Finished");
* @param args
try
RunAndRenderTaskCancel ex = new RunAndRenderTaskCancel( );
ex.runReport();
catch ( Exception e )
e.printStackTrace();
private class CancelReport extends Thread
private IRunAndRenderTask rTask;
private int msecs=0;
public CancelReport( String threadName, IRunAndRenderTask task){
super(threadName);
rTask = task;
public void run()
try{
while( msecs < 50 ){
Thread.currentThread().sleep( 200 );
rTask.cancel();
System.out.println(rTask.getStatus());
msecs++;
catch(Exception e)
Jason
On 5/10/2012 5:54 AM, donino donino wrote:
> I wonder if it is possible, using the Report Engine API, to specify a
> report max generation time? May be a value to set to the report engine,
> or for each IRunTask?
> Thanks!
Re: Report max generation time [message #871260 is a reply to message #871170] |
Fri, 11 May 2012 16:39  |
Just a typo, you should only have to cancel it once.
Jason
On 5/11/2012 5:10 AM, donino donino wrote:
> Thank you Jason,
> This is very helpful i think i will be able to manage this max
> generation time with something close to your example. However could you
> please clarify why the rtask.cancel() is wrapped in a loop? Invoke it
> one time may not be sufficient?
> thanks
FUDForum. Page generated in 0.02204 seconds
