Home » Modeling » TMF (Xtext) » Linker does not check type
Linker does not check type [message #870533] Tue, 08 May 2012 10:57 Go to next message
Hi all,
assume I have the following simple Java-like grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "www.xtext.org/example/mydsl/MyDsl"
Lib:
	(classes+=Class)*;
Class:
	'class' name=ID '{'
	(member+=Member)*
Member:
	Field | Method;
Field:
	type=Type name=ID;
Method:
	type=Type name=ID '(' ')' '{'
	(statements+=Statement)*
Type:
	'int';
Statement:
	(VariableDeclaration | Selection) ';';
Selection:
	object=[VariableDeclaration] '.' (member=[Field] | member=[Method] '(' ')');
VariableDeclaration:
	type=[Class] name=ID;
Then I generate, run the target platform and test the editor for the grammar with following snippet:
class A {
 int afield
 int aMethod() {
 int test () {
  A var1;
  var1.afield;
  var1.aMethod;
  var1.afield();
  var1.aMethod();
There is no error marker shown. However, the grammar clearly requires a method to be called with parenthesis and fields without.
The linker simply resolved the references to the members "aMethod" and "afield" by name, ignoring the contraint in the grammar:
Of cause both, "Field" and "Method" inherit from the same EMF class "Member", thus the linker can set those "wrong" cross references.
The problem here happens in DefaultLinkingService.getLinkedObjects()
	public List<EObject> getLinkedObjects(EObject context, EReference ref, INode node)
			throws IllegalNodeException {
		final EClass requiredType = ref.getEReferenceType();
		if (requiredType == null)
			return Collections.<EObject> emptyList();
		final String crossRefString = getCrossRefNodeAsString(node);
		if (crossRefString != null && !crossRefString.equals("")) {
			if (logger.isDebugEnabled()) {
				logger.debug("before getLinkedObjects: node: '" + crossRefString + "'");
			final IScope scope = getScope(context, ref);
			QualifiedName qualifiedLinkName =  qualifiedNameConverter.toQualifiedName(crossRefString);
			IEObjectDescription eObjectDescription = scope.getSingleElement(qualifiedLinkName);
				logger.debug("after getLinkedObjects: node: '" + crossRefString + "' result: " + eObjectDescription);
			if (eObjectDescription != null)
				return Collections.singletonList(eObjectDescription.getEObjectOrProxy());
		return Collections.emptyList();
In the first line it only checks the required type from the ref's target type - which is in our case "Member".
Additionally it should also check the type that is given my the grammar, similar like the following pseudo-code:
 if (node instanceof LeafNode) {
  LeafNode memberLeafNode = (LeafNode) node;
  EObject grammarElement = memberLeafNode.getGrammarElement();
  if (grammarElement instanceof CrossReference) {
    CrossReference xref = (CrossReference) grammarElement;
    EClassifier classifier = xref.getType().getClassifier();
    // TODO: Check if resolved EObject is instance of this classifier
I did a similar thing in a custom validator, but this was quire ugly, as the LeafNode is not directly accessable. And I think that Xtext could do this automatically. What do you think?
Reiner.
Re: Linker does not check type [message #870537 is a reply to message #870533] Tue, 08 May 2012 11:18 Go to previous messageGo to next message
Hi Reiner,
it could be solved much easier:
Lib:
(classes+=Class)*;
Class:
'class' name=ID '{'
(member+=Member)*
Member:
Field | Method;
Field:
type=Type name=ID;
Method:
type=Type name=MethodDecl '{'
Type:
'int';
Statement:
Selection:
member=[Method|MethodDecl]);
MethodDecl:
ID '(' ')'
Holger
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Re: Linker does not check type [message #870544 is a reply to message #870537] Tue, 08 May 2012 11:51 Go to previous messageGo to next message
Thanks Holger,
using this crosslink terminal feature is indeed something that I didn't really know - and that is really cool.
If I want to add parameters, is the right way to go like this?:
Method:
	type=Type name=MethodDecl (params+=VariableDeclaration)* ')' '{'
Type:
	'int';
Statement:
Selection:
	member=[Method|MethodDecl] (args+=ID)* ')');
MethodDecl:
	ID '(' ;
Anyway: Is the propsosed check in the linker valid?
Re: Linker does not check type [message #870705 is a reply to message #870544] Wed, 09 May 2012 08:01 Go to previous messageGo to next message
With this grammar it should work. But nor you'll need a typesyteme. You
may have a look at xbase where all this is already solved in a common
way. BTW: You check is not valid in the case that the stuff with the
braches is solved.
Lib:
(classes+=Class)*;
Class:
'class' name=ID '{'
(member+=Member)*
Member:
Field | Method;
Field:
type=Type name=ID;
Method:
type=Type name=ID '{'
Type:
'int';
Statement:
Selection:
object=[VariableDeclaration] '.' call=FeatureCall;
FeatureCall:
FieldCall | MethodCall
FieldCall:
field=[Field]
MethodCall:
method=[Method] => '('( args+=ID ("," args+=ID)*)? ')'
Re: Linker does not check type [message #871344 is a reply to message #870533] Sat, 12 May 2012 04:47 Go to previous message
Hi Reiner
your grammar looks similar to the Featherweight Java I implemented in
Xtext, (the implementation is now an example in Xsemantics DSL,
http://xsemantics.sourceforge.net/xsemantics-documentation/FJ-example.html#FJ)
hope this helps
Lorenzo
On 05/08/2012 04:58 PM, Reiner Hille wrote:
> Hi all,
> Lib:
> (classes+=Class)*;
> Class:
> 'class' name=ID '{'
> (member+=Member)*
> Member:
> Field | Method;
> Field:
> type=Type name=ID;
> Method:
> Type:
> 'int';
> Statement:
> Selection:
> class A {
> int afield
> int aMethod() {
> int test () {
> A var1;
> var1.afield;
> var1.aMethod;
> var1.afield();
> var1.aMethod();
> "Member", thus the linker can set those "wrong" cross references. The
> INode node)
> if (eObjectDescription != null) return
> EClassifier classifier = xref.getType().getClassifier(); // TODO: Check
> Reiner.
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Previous Topic:dangling reference error in XBlockExpression when accessing properties
Next Topic:Eclipse Juno + XTEXT 2.3 = SWT Error
Current Time: Thu Sep 25 17:24:34 EDT 2025
Powered by FUDForum. Page generated in 0.05430 seconds
