Home » Newcomers » Newcomers » Eclipse crash opening workspace(Eclipse crashes trying to open workspace with several errors)
Eclipse crash opening workspace [message #870200] Mon, 07 May 2012 05:08
Eclipse Indigo IDE version 3.7
I had been using the IDE without problems for the past 5 months. Now when I try to open a particular workspace, the IDE crashes. There are several error messages in the log file. I can open the IDE with other workspaces. I have then tried to switch the workspace to this particular workspace, but it crashes again. Would anyone know a solution to the problem? I need to open this workspace in Eclipse.
Error messages from log files follow:
!SESSION 2012-05-07 10:47:34.649 -----------------------------------------------
eclipse.buildId=I20110613-1736
java.version=1.6.0_30
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.core.resources 2 10035 2012-05-07 10:47:37.696
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.team.core 4 0 2012-05-07 10:47:38.212
!MESSAGE Could not instantiate provider org.tigris.subversion.subclipse.core.svnnature for project hybernate.
!STACK 1
org.eclipse.team.core.TeamException: Could not instantiate provider org.tigris.subversion.subclipse.core.svnnature for project hybernate.
at org.eclipse.team.core.RepositoryProvider.mapNewProvider(RepositoryProvider.java:165)
at org.eclipse.team.core.RepositoryProvider.mapExistingProvider(RepositoryProvider.java:235)
at org.eclipse.team.core.RepositoryProvider.getProvider(RepositoryProvider.java:507)
at org.eclipse.team.internal.core.TeamHookDispatcher.getProvider(TeamHookDispatcher.java:97)
at org.eclipse.team.internal.core.TeamHookDispatcher.getRuleFactory(TeamHookDispatcher.java:105)
at org.eclipse.core.internal.resources.Rules.factoryFor(Rules.java:93)
at org.eclipse.core.internal.resources.Rules.refreshRule(Rules.java:166)
at org.eclipse.core.internal.resources.Resource.refreshLocal(Resource.java:1647)
at org.eclipse.core.internal.refresh.RefreshJob.runInWorkspace(RefreshJob.java:167)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!SUBENTRY 1 org.eclipse.team.core 4 0 2012-05-07 10:47:38.212
!ENTRY org.eclipse.team.core 4 0 2012-05-07 10:47:38.227
!MESSAGE Could not instantiate provider org.tigris.subversion.subclipse.core.svnnature for project SomeFramework.
!STACK 1
org.eclipse.team.core.TeamException: Could not instantiate provider org.tigris.subversion.subclipse.core.svnnature for project SomeFramework.
!SUBENTRY 1 org.eclipse.team.core 4 0 2012-05-07 10:47:38.243
!ENTRY org.eclipse.mylyn.tasks.ui 4 0 2012-05-07 10:47:39.352
!MESSAGE Could not load repository template extension contributed by org.jboss.tools.common.mylyn with connectorKind jira
!ENTRY org.eclipse.osgi 4 0 2012-05-07 10:47:49.243
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4308)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.internal.ImageList.copyWithAlpha(ImageList.java:179)
at org.eclipse.swt.internal.ImageList.set(ImageList.java:409)
at org.eclipse.swt.internal.ImageList.add(ImageList.java:70)
at org.eclipse.swt.widgets.ToolItem.updateImages(ToolItem.java:942)
at org.eclipse.swt.widgets.ToolItem.setImage(ToolItem.java:708)
at org.eclipse.jface.action.ActionContributionItem.updateImages(ActionContributionItem.java:1045)
at org.eclipse.jface.action.ActionContributionItem.update(ActionContributionItem.java:783)
at org.eclipse.jface.action.ActionContributionItem.fill(ActionContributionItem.java:342)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
at org.eclipse.jface.action.ToolBarManager.createControl(ToolBarManager.java:111)
at org.eclipse.jface.action.ToolBarContributionItem.fill(ToolBarContributionItem.java:192)
at org.eclipse.jface.action.CoolBarManager.update(CoolBarManager.java:930)
at org.eclipse.ui.internal.WorkbenchWindow.updateActionBars(WorkbenchWindow.java:3217)
at org.eclipse.ui.internal.WorkbenchWindow.updateActionSets(WorkbenchWindow.java:3296)
at org.eclipse.ui.internal.WorkbenchWindow$27.run(WorkbenchWindow.java:3043)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:3004)
at org.eclipse.ui.internal.WorkbenchWindow$20.runWithException(WorkbenchWindow.java:2290)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
!ENTRY org.jboss.ide.eclipse.as.core 4 0 2012-05-07 10:47:49.477
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.jboss.ide.eclipse.as.core.JBossServerCorePlugin.stop() of bundle org.jboss.ide.eclipse.as.core.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:791)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:510)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:565)
at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1160)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:595)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:257)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:284)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:690)
at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:597)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:390)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:198)
Caused by: java.lang.NullPointerException
at org.eclipse.wst.server.core.internal.ResourceManager.loadRuntimesList(ResourceManager.java:627)
at org.eclipse.wst.server.core.internal.ResourceManager.init(ResourceManager.java:242)
at org.eclipse.wst.server.core.internal.ResourceManager.getServers(ResourceManager.java:795)
at org.eclipse.wst.server.core.ServerCore.getServers(ServerCore.java:316)
at org.jboss.ide.eclipse.as.core.server.UnitedServerListenerManager.<init>(UnitedServerListenerManager.java:49)
at org.jboss.ide.eclipse.as.core.server.UnitedServerListenerManager.getDefault(UnitedServerListenerManager.java:41)
at org.jboss.ide.eclipse.as.core.JBossServerCorePlugin.stop(JBossServerCorePlugin.java:106)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:771)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:764)
... 18 more
Root exception:
!ENTRY org.eclipse.core.jobs 2 2 2012-05-07 10:47:50.852
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.ide.IDEWorkbenchActivityHelper$4
Previous Topic:Cp1252 in windows and reading it in Linux
Next Topic:Eclipse Skin
Current Time: Wed Oct 29 17:26:09 EDT 2025
Powered by FUDForum. Page generated in 0.07001 seconds
