Home » Language IDEs » C / C++ IDE (CDT) » Included namespace's content not recognized
Included namespace's content not recognized [message #869815] Fri, 04 May 2012 07:53 Go to next message
I include in a .cpp a .h with angle branckets.
This .h contain a class definition within a two levels namespace.
In my cpp, when I type the first level namespace, the autocompletion does work; it completes with the name of the second level namespace as soon as I type :: (there isn't ay other second level namespace for now). But the completion doesn't propose me the class defined in the .h. When I type myslef the class name, Codan tells me that the type cnanot be resolved.
There isn't any other included file with the namespaces. And if I comment the class definition inclusion, Codan doesn't know anymore these namespaces. So why doesn't it see the class definition ?
I have no problem when compiling (I don't compile in Eclipse).
Re: Included namespace's content not recognized [message #869823 is a reply to message #869815] Fri, 04 May 2012 08:08 Go to previous messageGo to next message
Apparently, the problem comes from a macro at the definition class :
class YUNI_DECL MyClass
Where YUNI_DECL is defined as :
# ifdef YUNI_DYNAMIC_LIBRARY
#	ifdef YUNI_OS_MSVC
#		ifdef YUNI_DYNAMIC_LIBRARY_EXPORT
#			define YUNI_DECL             __declspec(dllexport)
#			define YUNI_EXPIMP_TEMPLATE
#		else
#			define YUNI_DECL             __declspec(dllimport)
#			define YUNI_EXPIMP_TEMPLATE  extern
#		endif
#	endif
# endif
/* Fallback to empty */
# ifndef YUNI_DECL
#	define YUNI_DECL
# endif
# ifndef YUNI_EXPIMP_TEMPLATE
# endif
If I remove YUNI_DECL, the indexer has no problem.
Re: Included namespace's content not recognized [message #869824 is a reply to message #869823] Fri, 04 May 2012 08:15 Go to previous messageGo to next message
I had to include in the project properties (but not in my source file) the directory where is defined the macro.
Re: Included namespace's content not recognized [message #869828 is a reply to message #869824] Fri, 04 May 2012 08:42 Go to previous messageGo to next message
Harry Houdini wrote on Fri, 04 May 2012 14:15
How do you include this header in your build process? Do you add it directly to the gcc command line with the -include option and is this header outside of your workspace?
Re: Included namespace's content not recognized [message #869835 is a reply to message #869828] Fri, 04 May 2012 09:10 Go to previous messageGo to next message
What header are you talking about ?
The one where is defined the class using the macro, or the one defining the macro ?
Re: Included namespace's content not recognized [message #869837 is a reply to message #869835] Fri, 04 May 2012 09:21 Go to previous messageGo to next message
The one defining the macro.
Re: Included namespace's content not recognized [message #869850 is a reply to message #869837] Fri, 04 May 2012 09:53 Go to previous message
The makefile was created with a cascade of CMake files. I didn't do them, and I hardly undestand them.
But the CMake configuration for my project inherits from a CMake configuration of an other project where is located the definition of the macro.
I suppose make reflects that, because I have no problem when compiling.
[Updated on: Fri, 04 May 2012 10:02] by Moderator
Previous Topic:Unresolved includes (not standard include)
Next Topic:How to make CDT/Eclipse work with C++11 threads?
Current Time: Sun Sep 21 23:01:11 EDT 2025
Powered by FUDForum. Page generated in 0.06582 seconds
