Re: Problems loading ApplicatioContext file in a WAB [message #867397 is a reply to message #867349] |
Tue, 01 May 2012 09:18 |
taher mosbah Messages: 17 Registered: April 2012 |
Thank you for your quick reply,
This link at spring source repository states that spring web is part of spring library : springsource.com/repository/app/library/version/detail?name=org.springframework.spring&version=3.0.5.RELEASE
sorry for the formatting because I can't post links
anyway, I tried to add the import explicitly but I always get the same error...
I'm really out of ideas.
[Updated on: Tue, 01 May 2012 09:18] Report message to a moderator
Re: Problems loading ApplicatioContext file in a WAB [message #867486 is a reply to message #867462] |
Tue, 01 May 2012 10:18 |
Actually with a fresh web application bundle with just spring config files and on controller, I'm getting this:
[2012-05-01 12:14:12.154] TRACE TCP Connection(2)-127.0.0.1 o.e.v.kernel.deployer.core.internal.PipelinedApplicationDeployer < private void org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.uninstallArtifact(org.eclipse.virgo.kernel.install.artifact.InstallArtifact)
[2012-05-01 12:14:12.157] DEBUG TCP Connection(2)-127.0.0.1 o.e.v.kernel.deployer.core.internal.PipelinedApplicationDeployer < public org.eclipse.virgo.kernel.deployer.core.DeploymentIdentity org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(java.net.URI, org.eclipse.virgo.kernel.deployer.core.DeploymentOptions) org.eclipse.virgo.kernel.deployer.core.DeploymentException: IOException parsing XML document from OSGi resource[/applicationContext.xml|bnd.id=137|bnd.sym=BizTouch.webTest]; nested exception is java.io.FileNotFoundException: OSGi resource[/applicationContext.xml|bnd.id=137|bnd.sym=BizTouch.webTest] cannot be resolved to URL because it does not exist
at org.eclipse.virgo.kernel.deployer.core.internal.BlockingSignal.awaitCompletion(BlockingSignal.java:87)
at org.eclipse.virgo.kernel.deployer.core.internal.BlockingAbortableSignal.awaitCompletion(BlockingAbortableSignal.java:63)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.start(PipelinedApplicationDeployer.java:303)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:208)
at org.eclipse.virgo.kernel.deployer.management.StandardDeployer.deploy(StandardDeployer.java:52)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenReturn(ConvertingMethod.java:167)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:96)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:33)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:208)
at com.sun.jmx.mbeanserver.PerInterface.invoke(PerInterface.java:120)
at com.sun.jmx.mbeanserver.MBeanSupport.invoke(MBeanSupport.java:262)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:836)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:761)
at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1424)
at javax.management.remote.rmi.RMIConnectionImpl.access$200(RMIConnectionImpl.java:72)
at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1262)
at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1357)
at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConnectionImpl.java:786)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:305)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:885)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:907)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.io.FileNotFoundException: OSGi resource[/applicationContext.xml|bnd.id=137|bnd.sym=BizTouch.webTest] cannot be resolved to URL because it does not exist
you can find the test project as attachment:
[Updated on: Tue, 01 May 2012 10:21] Report message to a moderator
Re: Problems loading ApplicatioContext file in a WAB [message #869600 is a reply to message #869449] |
Thu, 03 May 2012 17:09 |
I actually identified the problem, wich is the listner in web.xml, here is my web.xml :
<display-name>TestWebBundle</display-name>
<context-param>
<param-name>contextClass</param-name>
<param-value>org.eclipse.virgo.web.dm.ServerOsgiBundleXmlWebApplicationContext</param-value>
</context-param>
<!-- <listener> -->
<!-- <listener-class>org.springframework.web.context.ContextLoaderListener</listener-class> -->
<!-- </listener> -->
<servlet>
<servlet-name>dispatcher</servlet-name>
<servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>/</url-pattern>
</servlet-mapping>
</web-app>
The bundle deployes successfully but I got this exception on runtime :
org.springframework.beans.FatalBeanException: Class [org.springframework.context.config.ContextNamespaceHandler] for namespace [springframework.org/schema/context] does not implement the [org.springframework.beans.factory.xml.NamespaceHandler] interface
org.springframework.beans.factory.xml.DefaultNamespaceHandlerResolver.resolve(DefaultNamespaceHandlerResolver.java:126)
org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1330)
org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1325)
org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.parseBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:135)
org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.registerBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:93)
org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:493)
org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:390)
org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:334)
org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:302)
org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:143)
org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:178)
org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:149)
org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:124)
org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:93)
org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:130)
org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:467)
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:397)
org.springframework.web.servlet.FrameworkServlet.createWebApplicationContext(FrameworkServlet.java:442)
org.springframework.web.servlet.FrameworkServlet.createWebApplicationContext(FrameworkServlet.java:458)
org.springframework.web.servlet.FrameworkServlet.initWebApplicationContext(FrameworkServlet.java:339)
org.springframework.web.servlet.FrameworkServlet.initServletBean(FrameworkServlet.java:306)
org.springframework.web.servlet.HttpServletBean.init(HttpServletBean.java:127)
javax.servlet.GenericServlet.init(GenericServlet.java:244)
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
org.eclipse.virgo.web.tomcat.support.ApplicationNameTrackingValve.invoke(ApplicationNameTrackingValve.java:33)
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:987)
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579)
org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:309)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
java.lang.Thread.run(Thread.java:680)
if I uncomment the listner on web.xml, my bundle fails to start giving the following :
[2012-05-03 18:02:35.519] ERROR start-signalling-4 o.a.c.core.ContainerBase.[Catalina].[localhost].[/TestWebBundle] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener java.lang.NoClassDefFoundError: org.eclipse.virgo.web.dm.ServerOsgiBundleXmlWebApplicationContext not found from bundle [TestWebBundle_1.0.0 [133]]
at org.eclipse.gemini.web.tomcat.internal.loading.BundleDelegatingClassLoader.findClass(BundleDelegatingClassLoader.java:107)
at org.eclipse.gemini.web.tomcat.internal.loading.BundleDelegatingClassLoader.loadClass(BundleDelegatingClassLoader.java:139)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at org.eclipse.gemini.web.tomcat.internal.loading.ChainedClassLoader.doLoadClass(ChainedClassLoader.java:173)
at org.eclipse.gemini.web.tomcat.internal.loading.ChainedClassLoader.loadClass(ChainedClassLoader.java:163)
at org.eclipse.gemini.web.tomcat.internal.loading.BundleWebappClassLoader.loadClass(BundleWebappClassLoader.java:293)
at org.springframework.util.ClassUtils.forName(ClassUtils.java:257)
at org.springframework.web.context.ContextLoader.determineContextClass(ContextLoader.java:292)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:245)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:47)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4779)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5273)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:895)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:871)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:615)
at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:124)
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:95)
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:122)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:271)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:319)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:316)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:252)
at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:140)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:680)
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedNoClassDefFoundError: org/eclipse/gemini/blueprint/context/support/OsgiBundleXmlApplicationContext in KernelBundleClassLoader: [bundle=TestWebBundle_1.0.0] in KernelBundleClassLoader: [bundle=TestWebBundle_1.0.0]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:140)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.gemini.web.tomcat.internal.loading.BundleDelegatingClassLoader.findClass(BundleDelegatingClassLoader.java:91)
... 28 common frames omitted
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.defineClass(KernelBundleClassLoader.java:242)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:601)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:567)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:490)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(ClasspathManager.java:478)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:458)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:134)
... 33 common frames omitted
Caused by: java.lang.NoClassDefFoundError: org/eclipse/gemini/blueprint/context/support/OsgiBundleXmlApplicationContext
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.defineClass(KernelBundleClassLoader.java:238)
... 45 common frames omitted
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext in KernelBundleClassLoader: [bundle=TestWebBundle_1.0.0]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:138)
... 50 common frames omitted
Caused by: java.lang.ClassNotFoundException: org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
... 51 common frames omitted
As an attachement you can find my test project,(sorry file size is too big)
Sincerly.
[Updated on: Thu, 03 May 2012 17:15] Report message to a moderator
FUDForum. Page generated in 0.04149 seconds
