Home » Archived » Test and Performance Tools Platform (TPTP) » Problem with automatic gui recording
Problem with automatic gui recording [message #113292] Wed, 26 September 2007 08:29 Go to next message
Originally posted by: jojy.sv.gmail.com
Hi all,
I am using TPTP 4.4.0.2 and I am trying to record and play back an eclipse
plugin implementation.
In the plugin I have a wizard in which I can select a file from local file
system
I have placed two buttons for opening the file selection dialog and I set
the text for buttons as "Select File2" and "Select File".
Now I am able to record to select two files using two buttons and playback
the operation perfectly fine.
Now I have made some changes and I removed the text for both buttons
instead I am using the same image for both the buttons.
Now I am able to record the same scenario but the playback fails at the
selection event for the first button itself
Any idea why is it so?
George S
Re: Problem with automatic gui recording [message #113346 is a reply to message #113292] Thu, 27 September 2007 03:05 Go to previous messageGo to next message
George,
I think this is due to a known problem
https://bugs.eclipse.org/bugs/show_bug.cgi?id=171083 , But i see that you
dont have any text associated with the widget which is actually creating the
problem. Maybe you could try using a widget resolver
( http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-0.html#2.4.1)
to see if that helps in any way.
I also suggest that you track the defect i mentioned and maybe add comments
on your situation. I think this is something that needs to be addressed by
that defect.
Rohit Shetty
"George S" <jojy.sv@gmail.com> wrote in message
news:c1815ee230011705a30b33c7218e9648$1@www.eclipse.org...
> Hi all,
> system
> Regards
> George S
Re: Problem with automatic gui recording [message #113426 is a reply to message #113346] Thu, 27 September 2007 10:09 Go to previous messageGo to next message
I was also wondering if you could use position based recording just for
these buttons? Might be an option you could try (a workaround maybe).
See
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI.html
for details.
Rohit Shetty
"Rohit Shetty" <rohit.shetty@in.ibm.com> wrote in message
news:fdfko0$o3j$1@build.eclipse.org...
> George,
> the problem. Maybe you could try using a widget resolver
> comments on your situation. I think this is something that needs to be
> addressed by that defect.
> Regards
> Rohit Shetty
>> Hi all,
>> eclipse plugin implementation.
>> file system
>> playback the operation perfectly fine.
>> Regards
>> George S
Re: Problem with automatic gui recording [message #113694 is a reply to message #113292] Mon, 01 October 2007 07:55 Go to previous message
Hi George,
The default widget revolver mechanism uses the text property of the
widget. Since your widgets do not have a text property, the AGR cannot
distinguish between the widgets. You will have to:
-Add a text property to your widgets.
-or-
Create a custom widget revolver
( http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI.html#2.4).
Paul
> Hi all,
> system
> Regards
> George S
Previous Topic:AGR Playback Problem
Next Topic:TPTP report template
Current Time: Thu Nov 06 17:59:10 EST 2025
Powered by FUDForum. Page generated in 0.03005 seconds
