Added JTable to JFrame... now can't add other components [message #113261] |
Thu, 15 December 2005 03:40 |
Originally posted by: stjohnsoftware.yahoo.com
Using the Visual Editor, I added a JTable to a JFrame. I added it to the
"Center". However, after doing this, I cannot add any other components to
the JFrame.
Is this due to something I'm doing wrong or a misunderstanding on my part of
how JTables & JFrames work?
Re: Added JTable to JFrame... now can't add other components [message #113304 is a reply to message #113261] |
Thu, 15 December 2005 04:06 |
I found the problem.
It looks like the generated code was setting the content pane
(JFrame::setContentPane()) to the JScrollPane instance rather than adding it
(JFrame::add())
Sorry, obviously a newbie here -- to both Swing & VE
"sjs" <stjohnsoftware@yahoo.com> wrote in message
news:dnqoo5$7br$1@news.eclipse.org...
> the JFrame.
> of how JTables & JFrames work?
Re: Added JTable to JFrame... now can't add other components [message #113328 is a reply to message #113304] |
Thu, 15 December 2005 14:34 |
You do not add to the JFrame itself. That is invalid. You must add only
to the content pane. If it doesn't already have a content pane you
should use the context menu on the JFrame and select the create content
pane menu item. then you can drop on the content pane.
> (JFrame::add())
Rich Kulp
Re: Added JTable to JFrame... now can't add other components [message #611612 is a reply to message #113261] |
(JFrame::add())
> the JFrame.
Re: Added JTable to JFrame... now can't add other components [message #611617 is a reply to message #113304] |
> (JFrame::add())
Rich Kulp
FUDForum. Page generated in 0.03256 seconds
