DateSpinner with date only [message #112900] |
Sat, 10 December 2005 01:08 |
Originally posted by: milnfalcon4163.yahoo.com
I am using eclipse 3.1.1 and the ve plugin. I am using the swing JSpinner
and the spinnerDateModel beans from J2SE 1.4.2 to create a date spinner.
Unfortunately, I am having a problem with eliminating the time in the
date. I want a non-time date only. Someone told me to use a string date
format property or method. I could not find it in the ve bean for
JSpinner. Can someone help me please?
Re: DateSpinner with date only [message #112953 is a reply to message #112940] |
Sat, 10 December 2005 23:38 |
It worked. It really worked! Thanks a trillion. It is a shame that the
bean does not all properties of JSpinner. Otherwise, the ve would be more
rebust.
Re: DateSpinner with date only [message #113574 is a reply to message #112953] |
Sat, 17 December 2005 17:21 |
Why the VE implementors have not made all properties of the swing
components accessible in the VE beans? VE would be very robust and you
could it is RAD or Rapid Application Development if they did that.
Re: DateSpinner with date only [message #113587 is a reply to message #113574] |
Sat, 17 December 2005 22:10 |
Have you tried the Show Advanced Properties button in the tool bar of
the Properties view?
Re: DateSpinner with date only [message #113600 is a reply to message #113587] |
Sun, 18 December 2005 01:47 |
Yes. I did. for some strange reason it replaced my JSpinner.DateEditor
instance and the setEditor statements and placed them in the getDateEditor
method. I tried reproduced that effect on another date spinner and I could
not do it.
Re: DateSpinner with date only [message #113624 is a reply to message #113613] |
Sun, 18 December 2005 14:44 |
Thanks. I will enter the reguest. In fact, I meke it into the habit of
using eclipse bugzilla database when I when See some thing missing, having
problems or want an enhancement,.., etc. I will do anything to support my
visual or RAD programming. Thanks
Re: DateSpinner with date only [message #611661 is a reply to message #113574] |
FUDForum. Page generated in 0.04406 seconds
