Home » Archived » Visual Editor (VE) » How to close the previes
How to close the previes [message #112811] Fri, 09 December 2005 07:48 Go to next message
Originally posted by: jiangshachina.163.com
When I new a Visual Class, a preview is built automaticly. Can the preview be closed? What I must do?
Re: How to close the previes [message #112836 is a reply to message #112811] Fri, 09 December 2005 10:17 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
What do you mean by preview? Do you mean the window that shows up on the
task bar and when selected looks like what you are editing? In that
case, no because it is not a preview. It is the real thing. We use that
to screen-scrape the image to put on the VE editing surface. Without it
we can't get the image. It typically is moved way off screen so that you
don't see it, but some window managers keep moving it back on to the
screen even though we don't want it to do that.
Rich Kulp
Re: How to close the previes [message #112915 is a reply to message #112836] Sat, 10 December 2005 06:02 Go to previous messageGo to next message
Rich Kulp wrote:
> Do you mean the window that shows up on the task bar and when selected looks like what you are editing? In that case, no because it is not a preview. It is the real thing.
But the window always exists unless the visual class closed. It may consume some system resource. Can it be closed? I think it's better that the window should appear or disappear with my "order".
Additionally, I had a mistake. The subject should be "How to close the preview", but "How to close the previes". I'm so sorry that.
Sha Jiang
Re: How to close the previes [message #112983 is a reply to message #112915] Mon, 12 December 2005 09:59 Go to previous messageGo to next message
No it can't be closed. We need it for everytime you make a change then
we have to get a new image. It doesn't consume much in the way of
resources, even memory is not a problem. When not used the memory is
simply swapped out to disk.
Rich Kulp
Re: How to close the previes [message #113062 is a reply to message #112983] Mon, 12 December 2005 20:55 Go to previous message
Thanks!
Sha Jiang
Re: How to close the previes [message #611518 is a reply to message #112811] Fri, 09 December 2005 10:17 Go to previous message
Rich Kulp
Re: How to close the previes [message #611524 is a reply to message #112836] Sat, 10 December 2005 06:02 Go to previous message
Sha Jiang
Re: How to close the previes [message #611529 is a reply to message #112915] Mon, 12 December 2005 09:59 Go to previous message
Rich Kulp
Re: How to close the previes [message #611535 is a reply to message #112983] Mon, 12 December 2005 20:55 Go to previous message
Thanks!
Sha Jiang
Previous Topic:Non-java or non-swing/swt VE example
Next Topic:VE and native libs
Current Time: Thu Aug 07 22:57:39 EDT 2025
Powered by FUDForum. Page generated in 0.08874 seconds
