Re: [Teneo] Solution for XMLGregorianCalendar problems [message #112682 is a reply to message #112668] |
Wed, 20 February 2008 15:41 |
Hi Jason,
Have you tried using a hibernate usertype for handling the gregoriancalendar? Or would combining a
specific usertype with some of your changes result in less changes?
btw, I am interested to solve this. So if you can open a bugzilla then we can discuss in the
bugzilla how to solve this in the best (least invasive and most intuitive, etc.) way.
gr. Martin
jason henriksen wrote:
> Hi Martin,
> I really dislike XMLGregorianCalendar (XGC). It's constantly giving me
> ClassCastExceptions and my environment has the IBM, Apache and Sun
> versions of these things running around.
> I so strongly dislike this class that I wrote and eclipe tool which
> automatically refactors any EMF generated objects to switch from using
> XMLGregorianCalendar into using the objects from Joda Time
> (http://joda-time.sourceforge.net/)
> So the refactoring works nicely. My Joda Time methods call wrap the
> original EMF getters and setters so that my users never see XGC and EMF
> continues to use the objects it expects internally.
> Unfortunately, Teneo is pretty much hard coded to use XGC, the same way
> EMF is. But it seems like I could make a new property and get this
> working by modifying these classes:
> AbstractMapper: Switch the defaults based on an option
> ECoreDataTypes: Add some methods
> XSDDateTime: control behavior by option
> XSDDate: control behavior by option
> If I have even a hope of you accepting a change like this I'll write it
> up and submit it. If you're completely disinterested I'll be forced to
> make my wrapper methods @transient, the XGC methods @depricated and then
> have my users work via the transient stuff while Teneo works via the
> deprecated stuff. I think I can make that work, but it's certainly not
> as nice as building the support into Teneo.
> I would write the mod as a plug-in so that you wouldn't have to directly
> depend on the Joda Time code. Basically, you'd set the option and point
> to a 'DateTimeProvider' class that would implement inside the objects
> shown above. Then I could offer a JodaDateTimeProvider that would do
> what I need.
> Let me know what you think. As long as you aren't completely against
> the idea I'll write it up and submit it.
> Jason
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Solution for XMLGregorianCalendar problems [message #615518 is a reply to message #112668] |
Hi Jason,
gr. Martin
> Hi Martin,
> what I need.
> Jason
The Netherlands
FUDForum. Page generated in 0.04294 seconds
