Equinox p2 Repository Mirroring [message #112584] |
Thu, 26 June 2008 11:44  |
Hi All,
I was just experimenting with the mirroring functionality as documented
here:
http://wiki.eclipse.org/Equinox_p2_Repository_Mirroring
In the Getting the Mirroring Tools section it says:
"The mirroring application is part of the p2 Agent download available in
the provisioning section for a specific build in the Equinox downloads
site."
So I downloaded the following file:
http://ganymede-mirror2.eclipse.org/eclipse/equinox/drops/R- 3.4-200806172000/download.php?dropFile=equinox-p2-agent-3.4- win32.zip
I unzipped this and ran the eclipse.exe with the args, as documented, to
mirror Ganymede, just as a test.
eclipse.exe -application org.eclipse.equinox.p2.tools.MirrorApplication
-source http://download.eclipse.org/releases/ganymede/
-destination C:\tmp\ganymede
-ius all
-artifacts all
-verbose
I got this error:
java.lang.RuntimeException: Application
"org.eclipse.equinox.p2.tools.mirrorApplication" could not be found in the
registry. The applications available are:
org.eclipse.equinox.app.error,
org.eclipse.equinox.p2.artifact.repository.mirrorApplication ,
org.eclipse.equinox.p2.metadata.generator.EclipseGenerator,
org.eclipse.equinox.p2.metadata.repository.mirrorApplication ,
org.eclipse.equinox.p2.reconciler.application,
org.eclipse.equinox.p2.ui.admin.rcp.application.
Can you tell me what's wrong here?
Miles
Re: Equinox p2 Repository Mirroring [message #113229 is a reply to message #112987] |
Thu, 03 July 2008 11:48  |
Originally posted by: eclipseng.arthorne.com
That wiki page is for a new mirroring application that is not fully
completed. There is a bug report for adding this new mirroring app to
one of the downloads: https://bugs.eclipse.org/bugs/show_bug.cgi?id=237100.
Miles Daffin wrote:
>> I advise you to use the "Mirroring repositories with p2" help page
>> (search for "mirroring") procedure:
>> <eclipseInstall>eclipse.exe
>> -application
>> -destination file:d:/artifactLocalRepository/
> This is fine but does not seem to be as flexible as the elusive
> org.eclipse.equinox.p2.tools.MirrorApplication documented here:
> This has arguments that allow one to control which IUs and artifacts get
> mirrored. Does anyone know if there are other, undocumented ways of
> narrowing the scope of a mirror op using these other tools?
> Miles
FUDForum. Page generated in 0.04135 seconds
