Home » Eclipse Projects » Remote Application Platform (RAP) » ParameterizedCommand.generateCommand
ParameterizedCommand.generateCommand [message #112314] Wed, 12 November 2008 11:14 Go to next message
Hello group.
I was trying to use the ParameterizedCommand.generateCommand(Command
command, Map parameters) method to create a ParameterizedCommand using my
import file command and a Map containing one entry
(ISources.ACTIVE_WORKBENCH_WINDOW_NAME,
partRef.getPage().getWorkbenchWindow()).
However, the generateCommand function returns null. I inspected the
generateCommand code which I will include at the bottom of this post. At
lines 306 through 313 of ParameterizedCommand.java, I observed that this
method iterates over the keys of the parameter map, and checks for the
value in the command itself. If the parameter is not already in the
command, null is returned.
I would expect this method to use the parameter in the passed in Map and
apply it to the Command. I think that I am misunderstanding how this
method should work. Would someone please help clarify the proper use of
the generateCommand method.
Thanks very much for your help -- Mark
P.S. - I work around this by creating an EvaluationContext, adding my
variables, creating an ExecutionEvent, then calling
command.executeWithChecks(executionEvent).
* Take a command and a map of parameter IDs to values, and generate the
* appropriate parameterized command.
* @param command
* The command object. Must not be <code>null</code>.
* @param parameters
* A map of String parameter ids to objects. May be
* <code>null</code>.
* @return the parameterized command, or <code>null</code> if it could not
* be generated
* @since 3.4
public static final ParameterizedCommand generateCommand(Command command,
Map parameters) {
// no parameters
if (parameters == null || parameters.isEmpty()) {
return new ParameterizedCommand(command, null);
try {
ArrayList parms = new ArrayList();
Iterator i = parameters.keySet().iterator();
// iterate over given parameters
while (i.hasNext()) {
String key = (String) i.next();
IParameter parameter = null;
// get the parameter from the command
parameter = command.getParameter(key);
// if the parameter is defined add it to the parameter list
if (parameter == null) {
return null;
ParameterType parameterType = command.getParameterType(key);
if (parameterType == null) {
parms.add(new Parameterization(parameter,
(String) parameters.get(key)));
} else {
AbstractParameterValueConverter valueConverter = parameterType
.getValueConverter();
if (valueConverter != null) {
String val = valueConverter.convertToString(parameters
.get(key));
parms.add(new Parameterization(parameter, val));
} else {
// convert the parameters to an Parameterization array and create
// the command
return new ParameterizedCommand(command, (Parameterization[]) parms
.toArray(new Parameterization[parms.size()]));
} catch (NotDefinedException e) {
} catch (ParameterValueConversionException e) {
return null;
Re: ParameterizedCommand.generateCommand [message #113146 is a reply to message #112314] Sun, 23 November 2008 13:55 Go to previous message
Originally posted by: rherrmann.innoopract.com
Mark,
from a glance at the code, I would assume that the command you pass
in does not define a matching parameter.
Did you try the same with RCP? If it works there, feel free to file
a bugzilla.
HTH
Rüdiger
Mark Freiheit wrote:
> Hello group.
> my import file command and a Map containing one entry
> At lines 306 through 313 of ParameterizedCommand.java, I observed that
> this method iterates over the keys of the parameter map, and checks for
> the value in the command itself. If the parameter is not already in the
> the
> * * @param command
> * @param parameters
> could not
> * be generated
> * @since 3.4
> command,
> Map parameters) {
> // no parameters
> try {
> return null;
> } else {
> parameterType
> String val =
> .get(key));
> } else {
> create
> // the command
> return null;
Previous Topic:BUG in CVS Head: Highlighting in List widget doesn't work
Next Topic:Misplaced drop down menu in a toolbar drop-down item when working with ActionCon
Current Time: Sun Nov 09 12:34:18 EST 2025
Powered by FUDForum. Page generated in 0.03100 seconds
