how to provide a name at the bottom of the icon?? [message #112070] |
Thu, 15 March 2007 04:59 |
Originally posted by: imrannawaz.softtrans.net
Hi all,
I have small doubt, could u plz solve this....
I want to provide a name at the bottom of the icon, i mean the name should
be part of the icon but it should be seperated from the icon.
so that the name cannot be reflect the size of an icon and should not be on
the icon.
Imran
Re: how to provide a name at the bottom of the icon?? [message #112164 is a reply to message #112070] |
Thu, 15 March 2007 11:03 |
Originally posted by: pramsohl.in.tum.de
Hi Imran,
Let me see if i understand that right...
You've got a class XXX with Attribute "name";
gmfgraph:
You can define your graphical representation without Label Child
(XXXFigure).
Create a new Label Figure in your Figure Gallery root (and Diagram Label
in the Canvas - XXXLabel). Set the Label's Affixed Parent Side to the
Node-Side where you want your Label.
gmfmap:
Node reference with Figure XXXFigure and Child Label Mapping to XXXLabel.
Now the label sould be attached to his figure.
greets
Thomas
imran wrote:
> Hi all,
> the icon.
> Thanks
> Imran
Re: how to provide a name at the bottom of the icon?? [message #112325 is a reply to message #112164] |
Fri, 16 March 2007 04:38 |
Hi Thomas,
Thanks for ur reply.
But my problem is,
When I drag an icon from the palette to the diagram surface, It will ask for
name(label).
It is on the icon's body but I want the name should be at the bottom and
also it is separated from the icon.
Imran
"Thomas" <pramsohl@in.tum.de> wrote in message
news:etb95s$n9a$1@utils.eclipse.org...
> Hi Imran,
> gmfgraph:
> (XXXFigure).
> gmfmap:
> greets
> Thomas
> imran wrote:
>> Hi all,
>> should
>> on
>> the icon.
>> Thanks
>> Imran
Re: how to provide a name at the bottom of the icon?? [message #112593 is a reply to message #112325] |
Fri, 16 March 2007 22:29 |
Hmm
if you do it like i explained - than you get something like that:
* FIGURE *
LABEL
If you drag the figure the label moves with the figure.
greets
Thomas
imran schrieb:
> Hi Thomas,
> But my problem is,
> name(label).
> Thanks
> Imran
>> Hi Imran,
>> gmfgraph:
>> (XXXFigure).
>> gmfmap:
>> greets
>> Thomas
>> imran wrote:
>>> Hi all,
>>> should
>>> on
>>> the icon.
>>> Thanks
>>> Imran
Re: how to provide a name at the bottom of the icon?? [message #112632 is a reply to message #112593] |
Sat, 17 March 2007 13:55 |
Originally posted by: Jonathan.simulistics.com
Thomas' instructions worked for me. When I moved the label from being a
child of the figure representing the node to being a sibling and after
setting everything else as Thomas wrote the label is out side the figure
representing the node.
Thanks Thomas.
Jonathan
Thomas wrote:
> Hmm
> * FIGURE *
> LABEL
> greets
> Thomas
Re: how to provide a name at the bottom of the icon?? [message #113322 is a reply to message #112593] |
Wed, 21 March 2007 05:24 |
Thanks Thomas,
I got the solution. what i want
Thanks again,
With Regards
imran
news:etf5l7$c3m$1@utils.eclipse.org...
> Hmm
> * FIGURE *
> LABEL
> greets
> Thomas
> imran schrieb:
>> Hi Thomas,
>> But my problem is,
>> for name(label).
>> Thanks
>> Imran
>>> Hi Imran,
>>> gmfgraph:
>>> (XXXFigure).
>>> gmfmap:
>>> XXXLabel.
>>> greets
>>> Thomas
>>> imran wrote:
>>>> Hi all,
>>>> should
>>>> be on
>>>> the icon.
>>>> Thanks
>>>> Imran
Re: how to provide a name at the bottom of the icon?? [message #735312 is a reply to message #113322] |
Tue, 11 October 2011 14:15 |
Iban Ayestaran Messages: 58 Registered: September 2011 |
Member |
I am trying to repeat this steps but I don't get what I want. I want to display the name of a block called "Module" outside it, on the top.
In the gmfgraph, I have:
- Label ModuleNameFigure
- Figure Descriptor ModuleFigure
____- Rectangle ModuleFigure
________- ...
____- Child Access getFigureModuleNameFigure
________(properties=> accessor:getFigureModuleNameFigure, Figure:Label ModuleNameFigure)
- Diagram Label ModuleName
____(properties=> accessor: getFigureModuleNameFigure, affixed parent side: NORTH, Figure: Figure Descriptor ModuleFigure, ...)
In the gmfmap, I have:
- Top Node Reference <module:module/module>
____- Node Mapping <module/module>
________- Label Mapping false
____________(properties=> Diagram Label: Diagram Label NormalModeName, ...)
What am I missing?
[Updated on: Tue, 11 October 2011 14:18] Report message to a moderator
FUDForum. Page generated in 0.03834 seconds
