Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Retrieving the teneo version at runtime
[Teneo] Retrieving the teneo version at runtime [message #111713] |
Sun, 03 February 2008 18:31 |
Originally posted by: Olaf.Groeger.gmx.de
is it possible to determine the teneo version at runtime? I want to show the
versions of the used components of my program. The version of my own
program is trivial, the version of Hibernate is accessible with
Environment.VERSION, but how can this be done for teneo?
Olaf
Re: [Teneo] Retrieving the teneo version at runtime [message #111731 is a reply to message #111719] |
Mon, 04 February 2008 06:32 |
Hello Martin,
thanks for your response. I searched the code once more and i'm fairly sure
that the number can only be found in the manifest and in the jar name, as
you proposed.
Olaf
> Hi Olaf,
> I am not sure how to do that. The version should be somewhere in the
> plugin and also the jar is named using the build id.
> Nick, do you know if it is possible to read the plugin version from
> somewhere at runtime or is the build number stored in another file by the
> build process?
> gr. Martin
> Olaf Groeger wrote:
>> Hi,
>> the versions of the used components of my program. The version of my own
>> Olaf
Re: [Teneo] Retrieving the teneo version at runtime [message #111744 is a reply to message #111731] |
Mon, 04 February 2008 12:30 |
Hi, Martin, Olaf,
If you are running in an OSGi instance, the OSGi API can tell you what you
need to know.
From a Bundle (in Eclipse, this can be retrieved by ID (a.k.a. symbolic
name) from the Platform::getBundle() method), you can get all of its
manifest headers:
Bundle::getHeaders()
One of these is the Bundle-Version.
HTH,
Christian
Olaf Groeger wrote:
> Hello Martin,
> sure that the number can only be found in the manifest and in the jar
> name, as you proposed.
> Thanks
> Olaf
>> Hi Olaf,
>> build process?
>> gr. Martin
>> Olaf Groeger wrote:
>>> Hi,
>>> Olaf
Re: [Teneo] Retrieving the teneo version at runtime [message #111774 is a reply to message #111744] |
Mon, 04 February 2008 20:57 |
Hello Christian,
thanks for your tip. Actually i have a "usual" java application. But it
would be easy to migrate to OSGI. It is more or less a technical study and
will never go productive. Thus it is a interesting idea.
Olaf
> Hi, Martin, Olaf,
> need to know.
> manifest headers:
> HTH,
> Christian
> Olaf Groeger wrote:
>> Hello Martin,
>> Thanks
>> Olaf
>>> Hi Olaf,
>>> the build process?
>>> gr. Martin
>>> Olaf Groeger wrote:
>>>> Hi,
>>>> show the versions of the used components of my program. The version of
>>>> my own program is trivial, the version of Hibernate is accessible with
>>>> Olaf
Re: [Teneo] Retrieving the teneo version at runtime [message #111820 is a reply to message #111774] |
Tue, 05 February 2008 19:30 |
Hi Olaf,
Here is some related info I received from Nick Boldt:
Plugin version, including qualifier, is stored in each feature's
feature.xml and each plugin's MANIFEST.MF. It should be possible to
retrieve that using one of the following methods:
a) parse feature.xml using DOM tree or text/regexp-searching for
"version="..."
b) parse MANIFEST.MF using some API from OSGi, or just
text/regexp-searching for "Bundle-Version: ..."
gr. Martin
Olaf Groeger wrote:
> Hello Christian,
> Thanks
> Olaf
>> Hi, Martin, Olaf,
>> need to know.
>> manifest headers:
>> HTH,
>> Christian
>> Olaf Groeger wrote:
>>> Hello Martin,
>>> Thanks
>>> Olaf
>>>> Hi Olaf,
>>>> the build process?
>>>> gr. Martin
>>>> Olaf Groeger wrote:
>>>>> Hi,
>>>>> Olaf
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Retrieving the teneo version at runtime [message #111868 is a reply to message #111820] |
Thu, 07 February 2008 06:37 |
Hello Martin,
thank you very much for the info. I finally chose to migrate my project to
OSGI and use its API. That works like acharm. As do teneo. I'm really
impressed about teneo. Using a database couldn't be easier anymore. Thank
you for your great work!
Olaf
> Hi Olaf,
> "version="..."
> gr. Martin
> Olaf Groeger wrote:
>> Hello Christian,
>> and will never go productive. Thus it is a interesting idea.
>> Thanks
>> Olaf
>>> Hi, Martin, Olaf,
>>> you need to know.
>>> manifest headers:
>>> HTH,
>>> Christian
>>> Olaf Groeger wrote:
>>>> Hello Martin,
>>>> Thanks
>>>> Olaf
>>>>> Hi Olaf,
>>>>> the build process?
>>>>> gr. Martin
>>>>> Olaf Groeger wrote:
>>>>>> Hi,
>>>>>> of my own program is trivial, the version of Hibernate is accessible
>>>>>> with Environment.VERSION, but how can this be done for teneo?
>>>>>> Olaf
Re: [Teneo] Retrieving the teneo version at runtime [message #615389 is a reply to message #111731] |
Hi, Martin, Olaf,
need to know.
manifest headers:
HTH,
Christian
Olaf Groeger wrote:
> Hello Martin,
> Thanks
> Olaf
>> Hi Olaf,
>> build process?
>> gr. Martin
>> Olaf Groeger wrote:
>>> Hi,
>>> Olaf
Re: [Teneo] Retrieving the teneo version at runtime [message #615395 is a reply to message #111744] |
Olaf Groeger Messages: 13 Registered: July 2009 |
Hello Christian,
Olaf
> Hi, Martin, Olaf,
> need to know.
> manifest headers:
> HTH,
> Christian
> Olaf Groeger wrote:
>> Hello Martin,
>> Thanks
>> Olaf
>>> Hi Olaf,
>>> the build process?
>>> gr. Martin
>>> Olaf Groeger wrote:
>>>> Hi,
>>>> Olaf
Re: [Teneo] Retrieving the teneo version at runtime [message #615403 is a reply to message #111774] |
Hi Olaf,
"version="..."
gr. Martin
Olaf Groeger wrote:
> Hello Christian,
> Thanks
> Olaf
>> Hi, Martin, Olaf,
>> need to know.
>> manifest headers:
>> HTH,
>> Christian
>> Olaf Groeger wrote:
>>> Hello Martin,
>>> Thanks
>>> Olaf
>>>> Hi Olaf,
>>>> the build process?
>>>> gr. Martin
>>>> Olaf Groeger wrote:
>>>>> Hi,
>>>>> Olaf
The Netherlands
Re: [Teneo] Retrieving the teneo version at runtime [message #615418 is a reply to message #111820] |
Hello Martin,
Olaf
> Hi Olaf,
> "version="..."
> gr. Martin
> Olaf Groeger wrote:
>> Hello Christian,
>> Thanks
>> Olaf
>>> Hi, Martin, Olaf,
>>> you need to know.
>>> manifest headers:
>>> HTH,
>>> Christian
>>> Olaf Groeger wrote:
>>>> Hello Martin,
>>>> Thanks
>>>> Olaf
>>>>> Hi Olaf,
>>>>> the build process?
>>>>> gr. Martin
>>>>> Olaf Groeger wrote:
>>>>>> Hi,
>>>>>> Olaf
Current Time: Fri Apr 26 16:35:28 GMT 2024
Powered by FUDForum. Page generated in 0.04982 seconds
