Re: Error using CVS. [message #111771 is a reply to message #111607] |
Wed, 29 October 2003 20:06 |
Originally posted by: info.oti.com
Vinod Manalar wrote:
> I am unable to view the "diff" between my local file and the one in the
> CVS repository. Eclipse always shows that the whole file has been
> modified locally. I found an exception in the .log file. (see below).
> From the stack trace it seems Eclipse is running the update command
> with the -C option. But the CVS Repository version in use here is
> 1.10.5, which I believe does not allow this option.
I think you're out of luck with this. From the Eclipse FAQ:
< http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -vcm-home/docs/online/cvs_features2.0/cvs-faq.html#server_1>
1.What server versions of CVS are supported by Eclipse?
In 3.0, Eclipse supports CVS version 1.11.1p1 or higher, running
on a Linux or UNIX server. Eclipse 2.1.2 and before does not work with
CVS versions
greater than 1.11.6 (see next point). Eclipse does not officially
support running CVSNT on a Windows server, but varied degrees of success
have been
achieved. In this case, CVSNT version 1.11.1.1 or higher must be
used. There have also been some problems reported with HPUX and Solaris
version
(see above).
Andrew Jr.
IBM Phoenix Labs (OTI)
11811 North Tatum Boulevard, Suite 2400
Phoenix, Arizona, USA 85028-1614
FUDForum. Page generated in 0.03021 seconds
