lowercase HTML preference ignored [message #111076] |
Tue, 14 June 2005 00:25 |
Originally posted by: relaxedrob.remove.optusnet.com.au
Hi All,
Window | Preferences | Web and XML | HTML Files | HTML Source
"Preferred markup case for content assist, and code generation": "Tag names"
and "Attribute names" are both set to "Lowercase".
However, when I am in a JSP file and type <t ... and let the autocomplete
enter a <table> tag I get it as:
<TABLE></TABLE>
i.e. my lowercase preference is ignored..
What is even stranger is that in the templates:
Window | Preferences | Web and XML | HTML Files | HTML Templates
this is the table template:
<table>
<tr>
<th>Column 1 Heading</th>
<th>Column 2 Heading</th>
</tr>
<tr>
<td>Row 1: Col 1</td>
<td>Row 1: Col 2</td>
</tr>
</table>
Does anyone know what is happening? Is there a 'hidden' template somewhere?
Rob
http://phd.netcomp.monash.edu.au/RobertMarkBram/default.asp
Re: lowercase HTML preference ignored [message #111365 is a reply to message #111076] |
Wed, 15 June 2005 17:02 |
David Williams Messages: 722 Registered: July 2009 |
On Mon, 13 Jun 2005 20:25:05 -0400, Robert Mark Bram <relaxedrob@remove.optusnet.com.au> wrote:
No hidden tempates, those templates are to be insered "as is" into text
if used from content assist.
The case/preference problem has been a recurring one (opened, closed, reopened, etc).
I'm not sure which build you are using, but seems fixed in current build, so if
you see after this week's final I-build, be sure to let us know.
FUDForum. Page generated in 0.02619 seconds
