Re: VE 1.1 requires VE 2.1? [message #110657 is a reply to message #110645] |
Tue, 08 November 2005 14:42 |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
This is bug in the Update Manager. It often uses "VE" when it is
actually talking about a pre-reqed feature. If it is 2.1, then it is
looking for EMF 2.1. Try adding the Add all prereq's button. It may find
it for you.
George van den Driessche wrote:
> Hello,
> I tried to install VE on Eclipse 3.1.0. But when I select either
> component in the "Find and Install" wizard, it says that VE version 1.1
> requires VE version 2.1! Moreover, version 2.1 isn't available to be
> installed. I know that VE isn't technically supported on OS X (which is
> my host OS), but I wanted to try it anyway just to see how much really
> doesn't work.
> Can anybody explain this strange problem, and how it might be resolved?
> Alternatively, can anyone suggest a different plug-in that provides a
> PropertySheet-like editor? (At this stage, I only want VE because it has
> a UI for manipulating Beans.)
> George
Rich Kulp
Re: VE 1.1 requires VE 2.1? [message #611303 is a reply to message #110645] |
it for you.
> Hello,
> doesn't work.
> George
Rich Kulp
FUDForum. Page generated in 0.03324 seconds
