| MoreSwingComponents fails 3.2M2 [message #110610] |
Sun, 06 November 2005 11:31  |
Originally posted by: blas.puertareal.com
Hello
I'm trying to migrate a application to VE. After some problems with
tables & scrollpanes in 1.1.0.1 I try with 1.2.
I found that the MoreSwingComponents example fails in 1.2
My eclipse configuration is: 3.2M2 SDK, emf-sdo 2.2.0M2, GEF 3.2M2 and
VE I20051103.
The Table and JList appears outside the form and if one of the
scrollpanes were selected in the view, then the following error appears:
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicGet(Basi cEObjectImpl.java:497)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:488)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:483)
org.eclipse.ve.internal.jfc.core.JScrollPaneGraphicalEditPar t.getModelChildren(JScrollPaneGraphicalEditPart.java:115)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:716)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:684)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
org.eclipse.ve.internal.cde.core.CDEAbstractGraphicalEditPar t.refresh(CDEAbstractGraphicalEditPart.java:337)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:232)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:195)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:734)
Blas Rodriguez Somoza
| Re: MoreSwingComponents fails 3.2M2 [message #110692 is a reply to message #110619] |
Tue, 08 November 2005 18:43  |
Rich Kulp wrote:
> This often means there is a cache problem. Try this first and see if it
> clears it up:
> 1) Open a VE and just close it. Make sure there are now no open VE's.
> 2) Do Project->Clean...->Clean all projects
> 3) Wait for build to complete.
> 4) Try opening the VE again, see if it works now.
Excuse me.
I was sure I clean the project, but I didn't
| Re: MoreSwingComponents fails 3.2M2 [message #611300 is a reply to message #110610] |
Mon, 07 November 2005 09:22  |
clears it up:
Rich Kulp
| Re: MoreSwingComponents fails 3.2M2 [message #611306 is a reply to message #110619] |
> clears it up:
Excuse me.
FUDForum. Page generated in 0.16292 seconds
