Re: Is possible to re-use the header and footer [message #857679 is a reply to message #857648] |
Thu, 26 April 2012 19:10 |
You should be able to create a master page and put it in a library
component. Then all your reports should include the library. Your
template could even include the library. Then if you need to change the
header and footer, you only need to change the library and all
referenced reports will pickup the change.
Jason
On 4/26/2012 2:43 PM, zubin Mising name wrote:
> Is that possible to create re-use header and footer for all the report.
> some thing like include report in another report(like we can do include
> html page in another page).
> Currently what I can do is to create template and use this template as
> base to create new report. the issue of this approach is once you need
> to make change, you need to modify all the existing reports.
FUDForum. Page generated in 0.04842 seconds
