Home » Archived » Visual Editor (VE) » VE install
VE install [message #110355] Sun, 30 October 2005 08:01 Go to next message
I have installed VE and it is in the plugins window under help, I have also
ran eclipse.exe - clean, however, there is no option to create a new Visual
Project.
Any Ideas?
Oliver
Re: VE install [message #110380 is a reply to message #110355] Mon, 31 October 2005 12:40 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
There is no concept of a visual project. You can have visual classes in
any Java project. To create a visual class in a Java project use the
New->Visual Class wizard.
> Project.
> Any Ideas?
> Oliver
Rich Kulp
Re: VE install [message #110784 is a reply to message #110355] Thu, 10 November 2005 11:20 Go to previous message
Originally posted by: deankevin.email.com
I have experienced the same problem upon a fresh install of Eclipse. After experimenting for awhile here is what worked for me!
- I reinstalled Eclipse 3.1 from scratch
- I used update manager to install EMF, GEF and VE
http://www.eclipse.org/vep/WebContent/faq.html#install_howto
- Durring the install process instead of clicking "Install All" button I clicked "Install" button for each plugin, I also clicked the "Apply Changes" button instead of restarting Eclipse and "applied changes to perspective". I then had the add "Visual Class" option from the "Create New Class" action. The Visual Class is at the botton of action menu.
Did the steps I performed make a difference? Well all I can say is aftering trying to get the Visual Editor installed trying eveything I could with no luck, the above worked first time and I didn't even restart Eclipse.
Hope this is helpful to someone!
Re: VE install [message #611281 is a reply to message #110355] Mon, 31 October 2005 12:40 Go to previous message
> Project.
> Any Ideas?
> Oliver
Rich Kulp
Re: VE install [message #611314 is a reply to message #110355] Thu, 10 November 2005 11:20 Go to previous message
Previous Topic:Feature Request
Next Topic:Drag and drop CTabItem?
Current Time: Mon Nov 10 10:46:46 EST 2025
Powered by FUDForum. Page generated in 0.24435 seconds
