Home » Archived » IMP » Missing IMP projects available
Re: Missing IMP projects available [message #12261 is a reply to message #10077] |
Thu, 18 October 2007 10:13 |
Originally posted by: sandip.sahoo1980.gmail.com
Hi Stanely,
I did a checkout exactly the same way what you described below.But I am
getting a lot of errors.
"com.ibm.wala.shrike" dependency plugin not found for org.eclipse.imp.smpi
project.
please check the attached figure which shows the projects that are not
built.
Sandip
"Stanley Sutton" <suttons@us.ibm.com> wrote in message
news:ff3e86$6h7$1@build.eclipse.org...
>I wrote too soon: The formerly missing IMP projects have already
> appeared in the IMP CVS repository on SourceForge. Please check them
> out from there. The link mentioned in the previous posting here will
> probably be removed at the next update of our web site.
> Thanks again for your patience!
> Stan Sutton
> Stanley Sutton wrote:
>> Hello All,
>> As many of you are aware, the initial release of the IMP CVS repository
>> to SourceForge was missing three projects. These projects are in the
>> process of being migrated to the IMP CVS repository on SourceForge (and
>> may show up any day now).
>> In the meantime, a zip file containing the three projects is available
>> through the IMP web site at
>> http://eclipse-imp.sourceforge.net/developers/index.html
>> (see the first section, "The Right Stuff.")
>> Thanks for your forbearance with this. If there are any problems,
>> please let us know.
>> Regards,
>> Stan Sutton
Attachment: imp.JPG
(Size: 67.57KB, Downloaded 267 times)
Re: Missing IMP projects available [message #12272 is a reply to message #10077] |
Thu, 18 October 2007 10:19 |
Hi Stanley,
project.
built.
Sandip
> Stan Sutton
>> Hello All,
>> please let us know.
>> Regards,
>> Stan Sutton
Attachment: imp.JPG
(Size: 67.57KB, Downloaded 272 times)
Re: Missing IMP projects available [message #12354 is a reply to message #12296] |
Sat, 20 October 2007 18:36 |
Thanks! I was able to solve the dependency of com.ibm.wala.shrike
But still not able to build the projects. please look into the attached
figure.
"Robert M. Fuhrer" <rfuhrer@watson.ibm.com> wrote in message
news:47178ACC.40402@watson.ibm.com...
> Sandip Sahoo wrote:
>> Hi Stanley,
>> project.
> Hi there,
> The "More of the Right Stuff" section is incomplete. You also need to get
> com.ibm.wala.shrike from the WALA SVN repository at the following
> location:
> http://wala.svn.sourceforge.net/svnroot/wala/trunk/com.ibm.w ala.shrike
> Our apologies; we'll update the web page ASAP.
>> built.
>> Regards,
>> Sandip
> Cheers,
> -- Bob
> Robert M. Fuhrer
> Research Staff Member
> Programming Technologies Dept.
> IBM T.J. Watson Research Center
> IMP Team Lead (http://eclipse-imp.sourceforge.net)
> X10: Productivity for High-Performance Parallel Programming
> (http://x10.sf.net)
Attachment: errors.JPG
(Size: 69.35KB, Downloaded 279 times)
Re: Missing IMP projects available [message #12389 is a reply to message #12354] |
Sun, 21 October 2007 16:12 |
Stan Sutton Messages: 121 Registered: July 2009 |
Hi Sandip,
Look at the IMP Developer's Corner page on the IMP web site:
And check out the section "Building Required Parsers." From what I can
see in the image you sent, this should help you to address the problem.
To explain a bit here:
In the IMP CVS repository we don't usually store generated files that
can be regenerated in the user's workspace. (Of course, this saves on
storage space and download/upload time.) In particular, we don't store
the generated parsers and AST node types for the various languages
(e.g., DSLs) that are part of IMP. There are about half a dozen of
these languages now. The generated classes need to be regenerated
whenever one of the IMP projects that contains one of these languages is
checked out into a workspace.
Ideally, the LPG builder, which is part of the IMP installation, will
run automatically to regenerate the needed classes. However, there is a
problem in that the LPG builder does not seem to run automatically on a
project until after LPG has been run manually on the project. So, for
now, the IMP developer needs to manually run LPG on the grammar files
for each of these languages in order to get the containing projects to
build for the first time. The instructions on how to do this are
contained in the web page cited above.
We know this is a pain, and we apologize. We have to go through the
same process ourselves. We are working to fix it.
Stan Sutton
> figure.
>> Sandip Sahoo wrote:
>>> Hi Stanley,
>>> project.
>> Hi there,
>> location:
>>> built.
>>> Regards,
>>> Sandip
>> Cheers,
>> -- Bob
>> Robert M. Fuhrer
>> (http://x10.sf.net)
Re: Missing IMP projects available [message #14679 is a reply to message #12389] |
Mon, 29 October 2007 13:23 |
Hi Stanley,
Can you please provide me an update on this?
Sandip
news:ffftor$3b2$1@build.eclipse.org...
> Hi Sandip,
> In the IMP CVS repository we don't usually store generated files that can
> be regenerated in the user's workspace. (Of course, this saves on storage
> space and download/upload time.) In particular, we don't store the
> generated parsers and AST node types for the various languages (e.g.,
> DSLs) that are part of IMP. There are about half a dozen of these
> languages now. The generated classes need to be regenerated whenever one
> of the IMP projects that contains one of these languages is checked out
> into a workspace.
> Ideally, the LPG builder, which is part of the IMP installation, will run
> now, the IMP developer needs to manually run LPG on the grammar files for
> each of these languages in order to get the containing projects to build
> for the first time. The instructions on how to do this are contained in
> We know this is a pain, and we apologize. We have to go through the same
> Regards,
> Stan Sutton
>> figure.
>>> Sandip Sahoo wrote:
>>>> Hi Stanley,
>>>> project.
>>> Hi there,
>>> get
>>> location:
>>>> built.
>>>> Regards,
>>>> Sandip
>>> Cheers,
>>> -- Bob
>>> Robert M. Fuhrer
>>> (http://x10.sf.net)
Re: Missing IMP projects available [message #14710 is a reply to message #14679] |
Tue, 30 October 2007 21:24 |
Hi Sandip,
With the Eclipse review for IMP coming up shortly and some other things
going on we haven't been focused lately on fixing bugs. Even so, I took
a look at this again and believe I have found and fixed the problem,
which affected the class org.eclipse.imp.lpg.builder.LPGBuilder in the
project org.eclipse.imp.lpg.runtime. I don't know when there might be a
new release to the update site, but the code with the fix is available
in the CVS repository.
Stan
Sandip Sahoo wrote:
> Hi Stanley,
> Regards,
> Sandip
>> Hi Sandip,
>> into a workspace.
>> Regards,
>> Stan Sutton
>>> figure.
>>>> Sandip Sahoo wrote:
>>>>> Hi Stanley,
>>>>> project.
>>>> Hi there,
>>>> get
>>>> location:
>>>>> built.
>>>>> Regards,
>>>>> Sandip
>>>> Cheers,
>>>> -- Bob
>>>> Robert M. Fuhrer
>>>> (http://x10.sf.net)
Re: Missing IMP projects available [message #567658 is a reply to message #10077] |
Hi Stanely,
project.
built.
Sandip
> Stan Sutton
>> Hello All,
>> please let us know.
>> Regards,
>> Stan Sutton
Attachment: imp.JPG
(Size: 67.57KB, Downloaded 210 times)
Re: Missing IMP projects available [message #567707 is a reply to message #10077] |
Hi Stanley,
project.
built.
Sandip
> Stan Sutton
>> Hello All,
>> please let us know.
>> Regards,
>> Stan Sutton
Attachment: imp.JPG
(Size: 67.57KB, Downloaded 213 times)
Re: Missing IMP projects available [message #567948 is a reply to message #12296] |
figure.
> Sandip Sahoo wrote:
>> Hi Stanley,
>> project.
> Hi there,
> location:
>> built.
>> Regards,
>> Sandip
> Cheers,
> -- Bob
> Robert M. Fuhrer
> (http://x10.sf.net)
(Size: 69.35KB, Downloaded 213 times)
Re: Missing IMP projects available [message #568046 is a reply to message #12354] |
Hi Sandip,
Stan Sutton
> figure.
>> Sandip Sahoo wrote:
>>> Hi Stanley,
>>> project.
>> Hi there,
>> location:
>>> built.
>>> Regards,
>>> Sandip
>> Cheers,
>> -- Bob
>> Robert M. Fuhrer
>> (http://x10.sf.net)
Re: Missing IMP projects available [message #568735 is a reply to message #12389] |
Hi Stanley,
Sandip
> Hi Sandip,
> into a workspace.
> Regards,
> Stan Sutton
>> figure.
>>> Sandip Sahoo wrote:
>>>> Hi Stanley,
>>>> project.
>>> Hi there,
>>> get
>>> location:
>>>> built.
>>>> Regards,
>>>> Sandip
>>> Cheers,
>>> -- Bob
>>> Robert M. Fuhrer
>>> (http://x10.sf.net)
Re: Missing IMP projects available [message #568747 is a reply to message #14679] |
Hi Sandip,
Stan
Sandip Sahoo wrote:
> Hi Stanley,
> Regards,
> Sandip
>> Hi Sandip,
>> into a workspace.
>> Regards,
>> Stan Sutton
>>> figure.
>>>> Sandip Sahoo wrote:
>>>>> Hi Stanley,
>>>>> project.
>>>> Hi there,
>>>> get
>>>> location:
>>>>> built.
>>>>> Regards,
>>>>> Sandip
>>>> Cheers,
>>>> -- Bob
>>>> Robert M. Fuhrer
>>>> (http://x10.sf.net)
Current Time: Fri Apr 26 00:22:22 GMT 2024
Powered by FUDForum. Page generated in 0.04884 seconds
