| Egit Remove Source Code Directory [message #855241] |
Tue, 24 April 2012 12:29   |
Eclipse User  |
Indigo 2 with PDT, JavaScript, all up-to-date. Win XP.
I have a PHP project under C:\...\www\stuff\...  It can't be moved as it disappears from the localhost website.
I added it to git with Team and saw the recommendation to not use a local .git repository, so I let Eclipse put stuff in my %home% (like ~) directory.
After everything is set up, the entire source code directory is missing!  This caused GREAT CONSTERNATION!  Needless to say, alcohol was required.
A source code control system should NOT REMOVE THE SOURCE CODE!
Get it?
It turned out that Eclipse/git had moved everything to a plain directory under my home directory.  I've managed to keep on going by creating a Windows junction (reparse point, symbolic-link-to-directory) to fake the location of the source code.
Meanwhile, after recovery, I keep on working.  But everytime I put something into git, now, I need a few shots for courage, beforehand.
FUDForum. Page generated in 0.12337 seconds
