Re: Problem with Birt Viewer 3.7.1 using Scripted data source [message #855206 is a reply to message #855153] |
Tue, 24 April 2012 15:51 |
Claude,
My guess is that the calculMetrics.performanceMetrics package is not
being found. You could try
importPackage(Packages.calculMetrics.performanceMetrics);
Pack1 = new DataSet();
and add a simple file logger like:
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/temp/scrptds.txt", true ) );
out.println( "Pack1 " + Pack1);
out.close();
to see if it is null.
Jason
On 4/24/2012 11:10 AM, Claude B wrote:
> I've created 2 separated projects: the first is a Java project that generates the report (rptdesign file) and the second is a dynamic web project based on JSF 2.0 which shows the report generated by the first project using jsp viewer taglib.
> In the first project I used a scripted data source and here is my open script:
> dataSetHandle.setOpen( "i = 0;\r\n"
> +"Pack1 = new Packages.calculMetrics.performanceMetrics.DataSet();\r\n"
> +"L = Pack1.getLabels();\r\n"
> +"V = Pack1.extractData(L);\r\n"
> +"Pack2 = new Packages.calculMetrics.performanceMetrics.OpenedW2D();\r\n"
> +"Pack2.openedw2d(V);\r\n"
> +"Pack3 = new Packages.calculMetrics.performanceMetrics.ClosedW10d();\r\n"
> +"Pack3.closedw10d(V);"
> Where L is a list of Strings and V is a vector of classes
> When I run my report in the Eclipse viewer I get no problems, same thing if I run it from a report Engine (using HTMLRenderOption()) I get the HTML report with no problem
> but when I run it in Birt Viewer from the other project I get a strange error:
> Script engine error: ReferenceError: "V" is not defined.
> I attached below the stack trace.
> Here is what I've done exactly in the web project:
> - I created a dynamic web project v2.5
> - I deployed Birt Viewer 3.7.1 in a GlassFish server v 3.1.2
> - I copied the generated rptdesign file in the root directory of the viewer (D:\glassfish3\glassfish\domains\domain1\applications\birt)
> - I copied some libs (SQL Server, Hibernate, ...) into the lib directory
> - I copied the jar file of the first project in the scriptlib directory
> - I tested the viewer using this jsp page:
> <%@ page language="java" contentType="text/html; charset=ISO-8859-1"
> pageEncoding="ISO-8859-1"%>
> <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
> "http ://www.w3.org/TR/html4/loose.dtd">
> <%@ taglib uri="http: //java.sun.com/jsf/core" prefix="f"%>
> <%@ taglib uri="http: //java.sun.com/jsf/html" prefix="h"%>
> <%@ taglib uri="/birt.tld" prefix="birt" %>
> <html>
> <f:view>
> <body>
> <birt:report id="birtViewer" reportDesign="PMetrics.rptdesign" baseURL="/birt"
> height="600"
> width="800"
> format="html"
> isHostPage="false"
> reportContainer="iframe"
> </birt:report>
> </body>
> </f:view>
> </html>
> I tested it with other sample reports and it worked perfectly
> Environment:
> - Eclipse BIRT 3.7.1 (all in one)
> - BIRT runtime 3.7.1
> - JDK 1.7
> - GlassFish Server 3.1.2
> - JSF 2.0
> - Hibernate Tools 3.4.0
> I can't understand why have I to define the vector V in the Javascript code of the second project however it works perfectly in the first one without definition.
> Can anyone help me to solve this problem ???
Re: Problem with Birt Viewer 3.7.1 using Scripted data source [message #856365 is a reply to message #855323] |
Wed, 25 April 2012 15:41 |
Claude,
As a test could you jar the hibernate config file by itself manually and
drop it in the web-inf/lib directory?
Jason
On 4/24/2012 2:12 PM, Claude B wrote:
> Hi Jason,
> Thank you for your quick response,
> First I want to answer your question, I tried this code and the result was:
> Pack1 mailto:calculMetrics.performanceMetrics.DataSet@1778087
> but while doing this I realized that I ignored an important part of the log file, I'm so sorry I thought it was relative to an old execution, I attached the full log this time and I discovered that the problem is due to Hibernate, it can't find the hibernate.cfg.xml file so the extractData() method couldn't be executed and the vector is not created.
> But I'm still confused because I've the hibernate.cfg.xml file in the root dir of my jar file and I can't understand why it can't find it. BTW I'm creating my jar file using Ant and here is the jar tag:
> <target name="jar" depends="compile">
> <mkdir dir="${jar.dir}"/>
> <jar destfile="${jar.dir}/${ant.project.name}.jar" basedir="${classes.dir}">
> <manifest>
> <attribute name="Main-Class" value="${exec_report-class}"/>
> </manifest>
> <fileset dir="src" />
> </jar>
> </target>
> As you can see I added "<fileset dir="src" />" so that I can export my configuration and mapping xml files, the hibernate.cfg.xml file is in the src directory of the first project.
> Any idea please!!!
Re: Problem with Birt Viewer 3.7.1 using Scripted data source [message #857586 is a reply to message #856470] |
Thu, 26 April 2012 17:22 |
Claude this will really depend on what functions you want available to
the user. For example If you do not want to support flat file data
sources you could remove:
org.eclipse.datatools.connectivity.oda.flatfile_version.jar
Jason
On 4/25/2012 1:42 PM, Claude B wrote:
> Jason, I have another question,
> Now I'm going to integrate this web project into another web project
> which contains many other libs so I want to reduce the number of libs of
> the web viewer project. At first, I added all libs that I found in the
> web-inf/lib of the viewer to my project WebContent/web-inf/lib (84 libs)
> and now I want to delete unused libs: So can you tell me what are the
> necessary libs that I need to run the viewer???
FUDForum. Page generated in 0.04349 seconds
