Strage Memory leak in Semantic Highlighting [message #854055] |
Mon, 23 April 2012 16:05 |
We get following strange memory error in out dsl
Has anybody seen this before an can give a hint what could cause this problem
and what todo to solve it?
Christian
!ENTRY org.eclipse.ui 4 0 2012-04-23 17:59:45.187
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.OutOfMemoryError: allocLargeObjectOrArray - Object size: 134217744, Num elements: 33554432
at org.eclipse.xtext.ui.editor.syntaxcoloring.LightweightPosition.merge(LightweightPosition.java:174)
at org.eclipse.xtext.ui.editor.syntaxcoloring.MergingHighlightedPositionAcceptor.mergePositions(MergingHighlightedPositionAcceptor.java:122)
at org.eclipse.xtext.ui.editor.syntaxcoloring.MergingHighlightedPositionAcceptor.mergePositions(MergingHighlightedPositionAcceptor.java:77)
at org.eclipse.xtext.ui.editor.syntaxcoloring.MergingHighlightedPositionAcceptor.provideHighlightingFor(MergingHighlightedPositionAcceptor.java:52)
at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.reconcilePositions(HighlightingReconciler.java:87)
at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.modelChanged(HighlightingReconciler.java:277)
at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler$1.process(HighlightingReconciler.java:249)
at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler$1.process(HighlightingReconciler.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:37)
at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:32)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:78)
at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.refresh(HighlightingReconciler.java:245)
at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.install(HighlightingReconciler.java:200)
at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingHelper.enable(HighlightingHelper.java:82)
at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingHelper.install(HighlightingHelper.java:71)
at org.eclipse.xtext.ui.editor.XtextEditor.installHighlightingHelper(XtextEditor.java:491)
at org.eclipse.xtext.ui.editor.XtextEditor.createPartControl(XtextEditor.java:455)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:66)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:474)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1199)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:494)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:480)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:64)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:226)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:810)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:229)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:252)
at org.eclipse.jdt.internal.ui.navigator.OpenAndExpand.run(OpenAndExpand.java:50)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:186)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:49)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:867)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:176)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:463)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1257)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3755)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:129)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:578)
at org.eclipse.equinox.launcher.Main.run(Main.java:1411)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
FUDForum. Page generated in 0.02716 seconds
